Old 03-09-2012, 08:36 AM   #1
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Default Running JDM STi Ver. 7 EJ207 with USDM 02/03 ECU
I was just thinking about putting a USDM ECU in my car for inspections so it could communicate with the state system. I'm worried about the TGV sensors or lack there of. Will they cause a check engine light? Any other problems that might appear from this? It would only be temporary. AVCS shouldn't cause any problems, right? It just wouldn't function.
garface is offline   Reply With Quote
Old 03-12-2012, 07:57 AM   #2
garface
Member#: 1581
MY00 RS/STi7
bump.
Old 03-21-2012, 04:05 AM   #3
181stLeader
Member#: 184183
1996 Impreza RSTi
V8 EJ207 Aerosim Carbon
Should run the motor just fine with the right map flashed to the 03-03 ecu. You will get TGV codes but they can be deleted with open source tuning software.
181stLeader is online now   Reply With Quote
Old 04-03-2012, 11:48 AM   #4
WhozyerDADDY
Member#: 3420
2001 2.0 Sti Ver.7
Blue ridge pearl
Default me too
I'm curious to know this also, I have a 01 rs with a jdm v7 swap..and need to pass emissions and Cobb tuning isnt far away, and they told me they can't help me as far as my jdm ecu...but they could help me out if I ran a usdm wrx ecu.
WhozyerDADDY is offline   Reply With Quote
Old 04-03-2012, 12:27 PM   #5
mcwc
Member#: 196262
1999 RSTi, Silver
1990 240DL, Gold
As far as I know, with a JDM ECU, you are stuck with ECUTek or open source.
The 02/03 USDM WRX ECU is pin compatible with the V7 harness but you will not get AVCS with the USDM WRX ECU.
mcwc is online now   Reply With Quote
Old 04-03-2012, 12:30 PM   #6
garface
Member#: 1581
MY00 RS/STi7
But he can swap to a usdm ecu for the inspection. Just needs to get rid of the tgv code.
Old 04-03-2012, 03:05 PM   #7
WhozyerDADDY
Member#: 3420
2001 2.0 Sti Ver.7
Blue ridge pearl
I'm pretty sure I have a NON tgv v7...so I don't think it will throw one of those codes
Old 04-03-2012, 03:12 PM   #8
garface
Member#: 1581
MY00 RS/STi7
Ver. 7's don't have tgvs, but the usdm ecu will look for them hence the codes.
Old 04-03-2012, 06:13 PM   #9
WhozyerDADDY
Member#: 3420
2001 2.0 Sti Ver.7
Blue ridge pearl
Ahhh, I got ya....oh, another thing...as far as the avcs on the v7...I don't think my v7 has those either...did they start the avcs on the v8s?
Old 05-13-2014, 04:14 PM   #10
xxst1tch3sxx
Member#: 361810
2010 GSR EVO X
Wicked White
N/a N/a
Last edited by xxst1tch3sxx; 05-13-2014 at 04:15 PM. Reason: Realized this was a post that got bumped from 2012 lol
xxst1tch3sxx is offline   Reply With Quote
Old 04-03-2012, 08:53 PM   #11
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
The issue that you will run into when trying to pass inspection even with a USDM ECU on a V7 is that the emission control circuits need to be added to the harness so that the readiness tests that are part of the emission inspection are present. I'm not sure that you can flash these out. As others have said the TGV functions can be turned off.
Zephyr is offline   Reply With Quote
Old 04-04-2012, 07:57 AM   #12
garface
Member#: 1581
MY00 RS/STi7
Thanks. Do you know which readiness tests specifically?
Old 04-05-2012, 01:29 PM   #13
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
what emission control circuits are you talking about?
I borrowed an 03 USDM ecu, flashed it for my injectors, turned off all tgv related codes and forced readiness to pass NJ inspection. Its straight forward and should be very similar testing in NY state.
Note, the rom has to match the ecu, you may get some weird fuel pump controller CELs if there is a mismatch.
Old 04-03-2012, 09:15 PM   #14
jam007
Member#: 174706
2008 LGT-B
V7 has AVCS
jam007 is offline   Reply With Quote
Old 05-13-2014, 03:54 PM   #15
intrexin
Member#: 280635
2003 EJ207 WRX Wagon
This is very easy with open source tuning and a usdm ecu. Click tgv and force pass readiness. Worked like a charm on NY's new inspection pc's
intrexin is offline   Reply With Quote
FS : JDM STi Ver 7 EJ207 Intake Manifold/TGV deletes Ryan23 Engine/Power/Exhaust 18 11-18-2010 05:08 PM
02 WRX to JDM STi Ver. 7 engine. Do you need more than AVCS harness? garface Subaru Conversions 40 03-26-2010 09:33 PM
FS/T: JDM STI ver.7 spec-c ecu with ecutek license Sideout Engine/Power/Exhaust 3 01-27-2009 04:41 AM
FS NY: JDM STi Ver. 7 ECU and TXS UTEC garface Engine/Power/Exhaust 28 08-28-2008 02:43 PM
FS: JDM STi Ver. 7 RA Spec C AG970 ECU garface Private 'For Sale' Classifieds 4 12-06-2004 05:11 PM
