Old 03-11-2012, 01:39 PM   #1
thebeast
Member#: 170663
2002 wrx
Default P0303 Code
My stage 2 2002 WRX with a 2.5 hybrid engine is throwing code P0303. It idles fine and doesn't show any signs of misfiring in low rpm's. The only time it sputters is when I am over 50% throttle and hitting boost. Any idea what the problem could be? I had the swap done about 30k miles ago and this is the first time I have had any problems.
Thanks,
Scott
thebeast is offline   Reply With Quote
Old 03-12-2012, 12:19 PM   #2
thebeast
Member#: 170663
2002 wrx
I just cleaned up my engine using degreaser and a slow flow of water and if made the problem a lot worse. Now the CEL is flashing. Any ideas of what it could be?
intermittent rough idle, then stalls - P0303 code belacane Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 06-14-2013 06:36 PM
P0303 code, misfire rough idle afcivileng Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 78 10-14-2008 01:14 AM
P0303 code banshee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-19-2006 04:29 PM
P0303 & P0302 Codes, Misfire, Running on 2 Cylinders bigbird Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-01-2004 12:44 PM
P0303 Code common? Quick WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-20-2003 08:07 PM
