#1 |
Member#: 313179
What's the best way to tell if you have the right tension on your alternator belt? I replaced my belt 4 months ago and made a tick mark off to the side to annotate where the old belt tension was that way I didn't have to mess with it. Well when I put on the new dayco belt and tightened it up to that mark that I made it seemed a little tight so I loosened it down. I took my car into the shop a couple of days ago to get an oil change and they said the belt was kind of squealing, so they adjusted it for me, and they brought the tension up to the sharpie mark i made. How can I tell if it has the 1/4'' of play in it? It feels a little tight. do i push up and down on the top or on the side?
#2 |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
I have always tightened it until I can twist the belt 90 degrees at it's longest stretch.
#3 |
Member#: 37359
Vehicle:2003 WRX |
Not sure if this is the correct way, but I did the folllowing:
- Find the middle of the longest run between pulleys - Hold a small ruler against the belt with one hand - Push the belt in with the other hand and see if it deflects by 1/4" The hardest part is keeping the ruler fixed while pushing on the belt. I braced my ruler-hand against something solid. |
#4 |
Member#: 311923
VIC
Vehicle:04 STi WRB |
i tighten just until you can't twist the belt 90 degrees. there are also belt tension gauges available!
| Thread Tools | |
| Display Modes | |
| Alternator Belt Tension Block | SausageOfPower | Service & Maintenance | 2 | 02-20-2010 07:27 PM |
| Need Alternator Belt Tensioning Bolt spec | rage557 | Normally Aspirated Powertrain | 2 | 12-19-2008 01:03 PM |
| alternator belt tensioner broke | SilverSpool | Texas Impreza Club Forum -- TXIC | 4 | 01-04-2007 10:58 AM |
| Need A/C and Alternator belt tension torque specs | Shaitiger | Factory 2.5L Turbo Powertrain | 3 | 02-19-2004 11:59 PM |
| picture of alternator belt tensioner | WRxednEffect | Factory 2.0L Turbo Powertrain | 3 | 02-06-2002 03:29 PM |
