Old 04-23-2012, 12:56 PM   #1
tk1o48
Member#: 291303
Default Help! Random oil pan valve leaking...
So my valve covers were leaking a bit of oil so I thought I would get the covers changed and be good to go. My mechanic instead found the real problem which was a small, rubber like valve that was completely saturated in oil and leaking from the rear of the oil pan.
He mentioned it is an aftermarket pan most likely for turbos but the thing is its a 2.5... Purchased the car as is and previous owner is non-responsive.
I added a picture. Any help, diagnosis, part suggestions will be appreciated!!!! Thanks for your time!
tk1o48 is offline   Reply With Quote
Old 04-23-2012, 03:44 PM   #2
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Looks like someone brazed a drain tube or something in there. Definitely not OEM. I would go to your local parts store with that leaky cap and replace. Maybe get a couple extras and change them every oil change to be safe.
If you're feeling really ambitios have it welded closed, or get yourself a good used pan for cheap and replace that one you've got.
Old 04-23-2012, 06:22 PM   #3
gpshumway
Member#: 43950
07 WRX LTD Wagon
Yea, definitely not OEM. Maybe I'm not seeing that correctly, but it looks too high on the pan to be a drain. It does look like the return line for an aftermarket turbo kit.
Have you taken the rubber cap off to see what's underneath? Is it just a barb fitting? The right size plug and some permanent (bearing retaining) Loc-Tite could be the answer.
Strange to be sure.
gpshumway is offline   Reply With Quote
Old 04-23-2012, 07:34 PM   #4
tk1o48
Member#: 291303
Thanks for the responses. Do you think i can drive ~100 miles on this? Found a cheap used pan online and my buddy in the next town over offered to help. reason i ask is the rubber plug is pretty squishy and soaked completely. but being a little higher up on the pan i think it should be fine..
Old 04-23-2012, 09:27 PM   #5
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
There is some pressure in there. It's a risk, but how much is anyone's guess. I'd spend the $2 on a new cap until you get the pan replaced. Much less hassle if that cap should completely fail... Of course if it's been leaking for the last 6 months, you probably fine to go another 100 miles :P
Old 04-24-2012, 07:13 AM   #6
castper
Member#: 300342
it looks like somebody started to do a turbo conversion in it but gave up at the oil return line. That's what it looks like to me but don't quote me on that. Either way, get a new oil pan. Good Luck
castper is offline   Reply With Quote
Old 04-25-2012, 04:54 PM   #7
tk1o48
Member#: 291303
Does this one look fine?
http://www.rockauto.com/catalog/rafr...878277-1457466
I appreciate all the feedback guys!
Old 04-25-2012, 05:51 PM   #8
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Is that the same pan you've got on there. The 2.5 and 2.0 pans (what is in that link) are different?
What model/year is the car?
Old 04-25-2012, 10:20 PM   #9
tk1o48
Member#: 291303
Its a 2004 2.5rs.
Old 04-26-2012, 08:44 AM   #10
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Then that pan should be good to go.
You can always check here to verify the pan you've got... LINK HERE.
Oil Pan, Valve covers for wrx 2.0 Subie-Gc8 Private 'Wanted' Classifieds 7 08-23-2006 08:01 AM
Oil Pan Gasket leak? (Pic) my3awds Service & Maintenance 4 12-31-2005 09:14 AM
Gunk on oil pan...Oil leak? Agkelos Service & Maintenance 9 07-07-2005 12:22 PM
Residual oil leak at oil pan drain plug?? DanZ Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-08-2004 10:27 PM
NEED HELP! WTB: Oil Pan Drain Plug w/ Oil Temp Sensor Hotrodguru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-01-2004 10:18 PM
