Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 04-25-2012, 10:49 PM   #1
Waterlogged
Member#: 294791
2012 Impreza Sport
Default OEM Camera in 2012 Impreza
I bought a 2012 Impreza in December and wanted to install the OEM camera since the 4.3" non-navi display has (what appears to be ) software for a camera. I picked up a used OEM Forester camera (Clarion) for pennies and was going to install it until I realized that the factory stereo wasn't going to cut it and installed a Pioneer P4400BH head unit.
The pioneer is a dual din video unit that supports a rear view camera and I've decided to put one in even though the Impreza has great visibility compared to other vehicles. The easiest solution would be to install one of the various bolt on units off of ebay or your retailer of choice. I've decided to use the OEM camera since it will look more original and I already have one. I'm sharing this info in case others have the same thought. Remember that the upcoming XV has a rear view camera so parts may become readily available in the coming months.
The first step was to pull the rear panels. No factory wiring is present. The good news is that there is a cutout in the steel hatch behind the plastic panel above the license plate. I believe it will fit the camera but it appears that I'll have to Dremel out a hole in the plastic panel located above the license plate. There are markings in the plastic panel where a camera would be installed but I'm not sure why they are there.
Wiring and power supply are the next challenges. The OEM camera requires a 6V power supply so I've ordered an inexpensive 12v to 6v converter off of ebay. Another option would be to use a 7806 transistor. For a few bucks more, you get wires and probably the same exact transistor inside of a plastic housing.
I wanted to confirm that my used camera worked before I installed everything so I did a bench test with a 6v power supply and hooked the camera up to a tv. I couldn't find wiring diagrams for the camera so I guessed and gave it a try. It worked!
Red +6v
Black -6v
Yellow Video signal
White Video shield
If anybody has other information on the wiring, please reply. I'll continue to add to this thread as I complete the project. Waiting for the power supply at this time.
Waterlogged is offline   Reply With Quote
Old 04-26-2012, 09:07 PM   #2
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Glad to see someone else working on this! Check out my thread on the Forester forums:
2011 OEM rear view camera / CP635U1 HU research
(that talks about the similar HU with 4.3" screen found in Foresters, but the camera signals are the same).
I'm very interested to find out how much current the OEM camera draws. It would be really nice to be able to use the smaller 78L06.
The factory harness has 4 wires: camera video, power, camera detect, and an outer shield. The latter provides the ground for both the video signal from the camera and power supply to the camera. On every Subaru wiring diagram I've seen, the factory harness does not include a wire on the HU's camera power ground lead.
The camera connects the detect line to ground (so the OEM HU can tell when the camera has been installed). The factory harness can't do that, since it is often pre-wired in cars that ship without the camera. But if you were adding the camera to an OEM HU in a non pre-wired car, you can simply connect the HU's detect pin to chassis ground right there at the HU (so you could run one less wire from the HU to the camera).
SVXdc is offline   Reply With Quote
Old 04-27-2012, 07:49 AM   #3
jproy12
Member#: 116315
'12 Forester 2.5X
Looking forward to your testing, I also want to use the factory forester camera, on my 2012 forester, with a Pioneer X930BT HU.
How did you bench test your camera? Did you splice the wires and connected them in a RCA cable and then your TV? Was it in color, or BW?
Looking forward to more of your testing, I want to use the OEM factory camera as well on my forester.
JP
jproy12 is offline   Reply With Quote
Old 04-27-2012, 08:51 AM   #4
Temetito23
Member#: 298669
2007 WRX
pics of the oem camera..
Temetito23 is offline   Reply With Quote
Old 04-28-2012, 12:20 PM   #5
Waterlogged
Member#: 294791
2012 Impreza Sport
I cut the original plug off since I figured it would be difficult to find the matching plug and didn't have original camera wires in the rear door anyway. Then I just hooked up a 6vdc power supply and wired in a temporary rca plug so I could hook it up to a tv. The picture was color and looked decent on a 17" tv. Just an fyi...the label on the camera should be "up" for the correct orientation.
Old 04-30-2012, 09:19 AM   #6
jproy12
Member#: 116315
'12 Forester 2.5X
Would it be possible to give more details on how you did the wiring? This is exactly what I want to do, and I have no knowledge in doing so, but can and I am determine to do it!
Post up pictures and how you did it?
Thanks,
JP
Old 04-30-2012, 02:12 PM   #7
jproy12
Member#: 116315
'12 Forester 2.5X
Can you also post up which voltage reducer you got? So basically, you need to wire the 6v red wire to the reducer and the black wire to the ground?
How about the video signal?
Thanks, and really looking forward to more info!
JP
Old 05-03-2012, 08:06 AM   #8
jproy12
Member#: 116315
'12 Forester 2.5X
Any news? Took my rear hatch appart, and I dont have any wiring, but I do have the place to put the factory rear cam, so just need to wire it up!
JP
Old 05-10-2012, 07:31 PM   #9
ZURCALED12
Member#: 309754
2012 Impreza Sport L
Ice Silver Metallic
Any pictures of the OEM camera or Installation instructions from SUBARU AMERICA?
ZURCALED12 is offline   Reply With Quote
Old 05-17-2012, 04:51 PM   #10
jproy12
Member#: 116315
'12 Forester 2.5X
Bump? Any news? Pics?
JP
Old 05-29-2012, 08:00 PM   #11
jproy12
Member#: 116315
'12 Forester 2.5X
Any updates?
Old 05-30-2012, 12:26 AM   #12
Waterlogged
Member#: 294791
2012 Impreza Sport
Still trying to find time. It will happen, just not sure when.
Old 06-14-2012, 09:28 PM   #13
ZURCALED12
Member#: 309754
Ice Silver Metallic
Any pictures yet?
Old 07-15-2012, 08:23 PM   #14
jproy12
Member#: 116315
'12 Forester 2.5X
Any updates :P
Retrofit rear camera into 2012 Impreza? BrysImpreza Car Audio, Video & Security 231 01-01-2016 08:00 PM
WTF!? 2012 Impreza commercials tornado542 General Community 30 04-29-2012 08:32 PM
OEM Sirius in 2012 Impreza Waterlogged Car Audio, Video & Security 0 03-24-2012 11:49 PM
PCSing back to USA; cross country ride in 2012 Impreza or 2012 Odyssey? tlminh Newbies & FAQs 11 03-14-2012 03:03 PM
XM Radio in 2012 Impreza guitarfish Car Audio, Video & Security 15 03-05-2012 12:37 AM
