Old 05-14-2012, 01:01 AM   #1
wrxeffex
Member#: 287196
2004 WRX 4eat
Default Car won't start 04 WRX
Now car won't start. It won't crank. Makes a fast clicking noise though.
Changed battery and still the same thing. Cleaned off terminals and put dialectric grease on them too. I have power and everything still when I turn the ign. key. Also I have an auto. Alt? starter? connections? Never had a prob like this.
wrxeffex is offline   Reply With Quote
Old 05-14-2012, 01:08 AM   #2
JRCrutc
Member#: 309978
2012 WRX hatch
Ice Silver Metallic
Have you put a DMM on the battery terminals to verify that you have enough voltage? Also find a nice paint free section inside your engine compartment and put the negative probe of the DMM on that with the positive probe on the positive side of the battery. This will verify that you have a good ground in the system.
Any other issues that happened right before this symptom? Anything else go wrong recently? This sounds like an electrical issue. If it were mechanical usually you would hear the system try to crank over. The only mechanical (also technically electrical) issue that I can think that would cause this is a bad starter or bad section on your starter.
The clicking could be the starter trying to crank. I haven't tried this on your car but you might be able to rotate the starter motor to another spot on its rotation. Sometimes the contacts within the Starter go bad and you can get it to start by rotating it a 1/4 turn or so. Good luck.
JRCrutc is offline   Reply With Quote
Old 05-14-2012, 01:49 AM   #3
wrxeffex
Member#: 287196
2004 WRX 4eat
Nope. No other issues that I know of. I just recently swapped my upper coolant reservoir to the new oem plastic tank since my was rusting and seeping coolant just under the cap. I spilled a little antifreeze but nothing substantial. My car was fine right after and started fine then when I took it for a test drive for leaks and to see if would overheat. Everything was fine.
Old 05-14-2012, 01:52 AM   #4
wrxeffex
Member#: 287196
2004 WRX 4eat
Not sure what a DMM is. Sorry.
Old 05-14-2012, 02:11 AM   #5
JRCrutc
Member#: 309978
2012 WRX hatch
Ice Silver Metallic
DMM is a digital multi meter, same thing as a Digital Volt Meter. Anything that will read voltage. Sounds like it might be time to take it (tow if necessary) to a repair shop. You might call AAA if you have them or get a friend with Jumper cables to try to jump the car (extra power might be what you need).
Old 05-14-2012, 03:47 AM   #6
wrxeffex
Member#: 287196
2004 WRX 4eat
Don't have a DMM but wasn't sure but I thought that's what you meant. Is it possible the contacts have worn out in the starter? I've always had the warm start problem with this car though that some seem to have. Where out of the blue once in awhile after I've driven awhile and parked the car somewhere and came back tried to start the car and it wouldn't start. Then it would on the next try. It would crank but not start. Then after switching it off an then starting again it would start. This happend for years.
Old 05-14-2012, 03:55 AM   #7
OUScooby
Member#: 100449
'04 WRX 0whp 0tq
'99 Imp L, '72 MGB
The "click click click" and no crank makes me think this is an electrical problem. Have you had your battery and alternator tested? That would be the first place to start. Most auto parts stores like auto zone will test it for you for free.
Edit: Just read your last post about the warm start. I was having similar problems with my car before finally tracing it back to a bad MAF. My car would always crank though, just not turn over, I never had it just click and not crank.
OUScooby is offline   Reply With Quote
Old 05-14-2012, 04:20 AM   #8
JRCrutc
Member#: 309978
2012 WRX hatch
Ice Silver Metallic
I'm not an expert on starter motors, but I have that they can have bad spots. That could help explain your warm start issue. If the spot was not too big it might not start at first but when you stop cranking it, maybe it came to rest in a position that would work the second time. Now that spot might be too big for you to actually get it to turn over. I would still try to get the car started with Jumper cables hooked up, if that doesn't work then someone with troubleshooting tools will have to take over.
By the way, I think you can get a cheap DMM from radio shack for about $20, might be worth it for the future.
Old 05-14-2012, 05:51 AM   #9
wrxeffex
Member#: 287196
2004 WRX 4eat
I feel stupid now. Since it's an auto all I had to do is jiggle the gear shifter a little and voila car starts right up. What does this mean in the long run? Is my solenoid going on me? Cause the stick was clearly in P but the neutral terminal on the solenoid was still engaging preventing the car from starting. It's actually a safety thing on the starter. So are the contacts sticking?
Old 05-15-2012, 12:00 AM   #10
JRCrutc
Member#: 309978
2012 WRX hatch
Ice Silver Metallic
How did you come to this conclusion?
Originally Posted by wrxeffex View Post
...Cause the stick was clearly in P but the neutral terminal on the solenoid was still engaging preventing the car from starting. It's actually a safety thing on the starter...
Usually the problem lies in the Neutral Safety Switch, but that doesn't usually let the ignition get to the point of trying the starter (thus no clicking, just dead silent).
The second problem, where the shifter won't move out of "P" usually denotes a brake sensor issue. The brakes need to be fully depressed to move from "P" into "R" and if you are pushing the brake and it won't budge usually that means that the brake position sensor is going out. Sometimes you can get lucky and pump the brakes and it will work, but usually this means a new brake position sensor.
Old 05-15-2012, 12:54 AM   #11
wrxeffex
Member#: 287196
2004 WRX 4eat
Could it be loose or dirty? neutral safety switch.
And thank god, with lockup issue, thought maybe my transmission was starting to go on me.
Old 05-14-2012, 11:11 PM   #12
wrxeffex
Member#: 287196
2004 WRX 4eat
It happend again. Car wouldn't start had to fiddle with automatic shifter in P position. Also every once in awhile when the car is P, I start it and the shifter locks up won't shift back to get in D. Is this the starter going on me?
Old 05-15-2012, 12:55 AM   #13
lavid2002
Member#: 226864
2005 PSM WRX
18.5lb. 93 oct, DP, UP
I have tons of parts for this car, if it turns out that you need a starter or a relay or anything just PM me and I will sell it to you cheapskies
Thanks!
-Dave
lavid2002 is offline   Reply With Quote
Old 05-15-2012, 01:35 AM   #14
JRCrutc
Member#: 309978
2012 WRX hatch
Ice Silver Metallic
At this point you need professional troubleshooting done on the car. Its Time to take it to a shop. The car can be driven and started, so drive it to a local shop or stealership.
Like I said, it doesn't sound like a Neutral Safety Switch to me because it clicks, and if the switch were bad, I don't think that it would even click. Sorry but this is all the help we can provide from a Forum point of view. If you had the ability to do actual electrical troubleshooting you could try to figure out what is actually wrong, but it doesn't seem like that is in you bag of tricks currently. Best to let a pro take care of this for you.
Old 05-15-2012, 02:10 AM   #15
wrxeffex
Member#: 287196
2004 WRX 4eat
What about a loose connection?
Old 05-15-2012, 02:16 AM   #16
JRCrutc
Member#: 309978
2012 WRX hatch
Ice Silver Metallic
not likely, but possible.
Old 05-15-2012, 04:21 AM   #17
wrxeffex
Member#: 287196
2004 WRX 4eat
ok been hearing a sound when I first start the car I don't think I've heard before. Just to let you know the car was cold. Listen to the sputtery type sound at the beginning when the car starts. What is that?
http://www.youtube.com/watch?v=KR54D...ature=youtu.be
Old 05-15-2012, 03:11 PM   #18
wrxeffex
Member#: 287196
2004 WRX 4eat
Anybody? Click on the video link. Does anybody know what sound that is?
Old 05-15-2012, 10:42 PM   #19
wrxeffex
Member#: 287196
2004 WRX 4eat
THe starting problem persists. I get the clicking and no crank. I saw a vid on YT with a mechanic saying the clicking is from the starter not getting enough power from the battery but if the battery is new or charged it's either a corroded wire to the starter solenoid. What about battery terminals? My last battery was pretty coroded with dry white acid around the terminals.
Old 05-15-2012, 11:33 PM   #20
JRCrutc
Member#: 309978
2012 WRX hatch
Ice Silver Metallic
You need electrical trouble shooting tools (DMM, $20 from radio shack Found HERE) and the ability to sit down and logically work through the electrical path from the battery to the starter to see where current is falling off (if at all).
If this is too difficult for you, then a professional will be required. There is no one that can tell you with %100 certainty what is wrong with your car until more troubleshooting is completed.
It looks like you have multiple issues as well (Can't start, can't shift out of P, unknown noise from engine when starting). Either you are trolling (in which case you have really gotten me good ) or you really need more help than a forum can provide someone at your technical level.
Old 05-16-2012, 12:26 AM   #21
Onejamasubaru
Member#: 312346
2012 WRX
Satin White Pearl Sedan
Jump start the car then go from there? I don't know much about all these technical terms "DMM" etc but if it starts, then you know whats working and whats not? That maybe bad advice but just my .02. Good luck sir!!
Onejamasubaru is offline   Reply With Quote
Old 05-16-2012, 01:07 AM   #22
wrxeffex
Member#: 287196
2004 WRX 4eat
What about ignition coil?
Old 05-18-2012, 01:52 AM   #23
wrxeffex
Member#: 287196
2004 WRX 4eat
ok found out it seems to start ok in neutral. does anybody know what white tab is called to the right of automatic shifter that's in the center console? you can depress it and seems to unlock the shifter from P even when the car is off, which is how I can get the car in neutral to start it.
Old 05-18-2012, 01:59 AM   #24
ineedasubaru
Member#: 215509
2003 Wrx
Orange
Exact ssame thing happend to me. I changed the battery and the starter and still had the same problem. As it turns out the ground on the bracket that attaches to my starter was lose and caused all me problems, so you might want to take a look at that.
ineedasubaru is offline   Reply With Quote
Old 05-18-2012, 02:06 AM   #25
wrxeffex
Member#: 287196
2004 WRX 4eat
yours auto? what part of the starter is it attached to?
Fuel pump won't start, blown fuse SBF 2, car won't start ClassicGC Factory 2.0L Turbo Powertrain 5 06-29-2008 09:18 PM
Car won't start - cranks but won't start dave_88 Factory 2.0L Turbo Powertrain 4 12-12-2007 10:29 PM
Car won't start. Won't crank, but lights will turn on Gorge Service & Maintenance 9 01-09-2007 01:23 AM
car won't start! 02 wrx bouncingsoul23 Factory 2.0L Turbo Powertrain 8 12-02-2004 04:43 PM
V6 STI longblock in an 04 WRX: Car won't start cjm04WRX Factory 2.0L Turbo Powertrain 21 11-09-2003 10:17 PM
Message Board Statistics All times are GMT -4. The time now is 06:27 PM.
