Old 07-02-2012, 07:32 PM   #1
02skoobywrx
Member#: 312035
Default 02 Subaru Wrx Ls1 build
Well, after 3 months, Im finally getting around to showing my project. I picked up a 02 wrx with 56k miles in early march originally planning to put a 4cyl. turbo back in. (previous owner took the engine out). Well, changed my mind and went for the ls1 since I seen it done before and had to do one myself. This is my 3rd wrx btw. Anyways, finally picked up a complete ls1/t56 in late march and got started. This has not been a easy swap at all. The pics aren't that good because apparently my iphone doesn't take good pics anymore.
Custom fab'd crossmember I made. Stock steering rack bolts right up. Unfortunately, I had to drop the rack 2-3" to clear the oil pan so i'll have to get the spindles fixed so the tie rod ends are in line with the control arms to minimize or eliminate bump steer.
02skoobywrx is offline   Reply With Quote
Old 07-02-2012, 07:33 PM   #2
02skoobywrx
Member#: 312035
This is where it sits as of now. The motor turns over, but still have a little wiring left, and im waiting on a fuel pump unit and deatschwerks high flow pump.
Old 07-04-2012, 12:51 PM   #3
treystoys
Member#: 97436
03 toyota tundra
gray..missing my WRX's :(
Awesome project man what are your plans for the rear end/axle set up? Any way you could set up the oe subaru ac compressor into the bay?
Trey
treystoys is offline   Reply With Quote
Old 07-05-2012, 09:11 PM   #4
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
Nice swap!
Trey
It would be easier to use the GM compressor and make custom lines. Custom lines are necessary either way.
eastcoastbumps is offline   Reply With Quote
Old 07-04-2012, 02:27 PM   #5
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
You sick bastard, you better finish this thing and post pics.
and a burnout video!
lukeskywrx is offline   Reply With Quote
Old 07-05-2012, 06:00 PM   #6
machineica
Member#: 319539
2002 WRX,EJ20,VF30'd
PSM,5MT DCCD,RPF1 18's
that looks factory! jealous...
machineica is offline   Reply With Quote
Old 07-05-2012, 10:01 PM   #7
TrunkMonkeyManiac
Member#: 175898
2002 Impreza
Awesome!
TrunkMonkeyManiac is offline   Reply With Quote
Old 07-06-2012, 01:07 AM   #8
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Gorgeous !
sense of nature is offline   Reply With Quote
Old 07-06-2012, 01:47 AM   #9
02skoobywrx
Member#: 312035
Thanks guys. And yeah, I'm using the gm compressor. I just need to get lines made.
Old 07-13-2012, 11:22 AM   #10
lockmedic
Member#: 314893
That's . . . just SICK!
Love it! subscribed!
lockmedic is offline   Reply With Quote
Old 07-14-2012, 03:20 AM   #11
05subysti
Member#: 268190
2005 STi
Can't wait to see this done! I've been wanting to do this swap. Can't beat ls motors. I'd be happy to make 500whp naturally aspirated! Finish the car already! And I'll pay you to make a copy of the sub frame and mounts etc like a swap kit lol.
05subysti is offline   Reply With Quote
Old 07-16-2012, 04:26 PM   #12
wittmer25
Member#: 102970
2004 STi gt30r
I can't wait to see a 1/4 mile pass and some nasty sideways burnouts!
wittmer25 is offline   Reply With Quote
Old 07-18-2012, 02:30 AM   #13
klaus_b2
Member#: 318411
17 WRX
CWP
this thread neeeds videos
klaus_b2 is offline   Reply With Quote
Old 07-18-2012, 03:06 AM   #14
amroof
Member#: 211224
2005 Saabaru
Who knows
this thread needs more updates! more pics!
amroof is offline   Reply With Quote
Old 07-19-2012, 11:16 PM   #15
TerArex
Member#: 325260
03 Wrx
AW
Single or dual exhaust? Single would be legit. Sound like a big cammed ej
TerArex is offline   Reply With Quote
Old 07-20-2012, 01:21 AM   #16
9K RACING
Member#: 273908
Legit idea.
Engine plus header clearance looks good. How close are those thing to the steering rack?
Update more if possible!
I'm interested to see how the driveshaft and exhaust system turns out.
Are you also making a custom gauge cluster?
9K RACING is offline   Reply With Quote
Old 07-21-2012, 02:38 AM   #17
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Its been done a few times guys...... the stock cluster and shifter location look normal when done. Plenty of videos on youtube of LS powered WRXs. That guy who put a procharger on his LS7 powered WRX was wicked fast!
The rear end will need just as much swapping as the engine hahaha. Civette put a 10" Supra rear diff in his to hold the power of a stock LSx engine and 6 speed. The stock subaru rear diff only lasted a couple days.
Old 07-25-2012, 07:40 PM   #18
02skoobywrx
Member#: 312035
I'd like to know where you saw an ls7 powered wrx. I've only seen 2 on youtube...one was the blue 03 with the 6.0 LS and an yellow 03? with an ls2, which I only saw idling, so I dont know how that turned out. The motor sat too high for the stock hood to fit. And I think I saw a newer legacy with some sort of LS in it...maybe an LS7...not too sure.
He actually dyno'd the car and made I think it was around 370hp at the wheels with a cam on that stock diff. And I think I remember seeing it lasted about 4k miles of spirited driving, so it'll hold up a little better than you think, but he end up having to put an r200 skyline diff in it.
Originally Posted by MNBD View Post
That looks awesome! Props on the clean install!
Do you LS swap guys modify the stock rear subframe for the rear end?
Yeah I believe the subframe will have to be modified somewhat to mount a new diff. Not looking forward to it as axle shafts will not be cheap.
Old 07-24-2012, 11:21 PM   #19
02skoobywrx
Member#: 312035
I dont have much of an update but I did a few things and fired it up only to realize i didn't have oil pressure, which is what i've been working on the past few evenings after work. Turns out, the engine just needed to be primed, which took awhile. If everything goes smoothly, I might be able to finish it up and drive it this weekend. Anyways, heres a pic...looks a little more finished.
And yes, I plan on running single 3" exhaust. The headers are pretty close to the steering rack. I'll probably wrap some of it to shield it from the heat, but everything has good clearance. I'll be using the stock cluster so the interior looks factory.
Old 07-25-2012, 04:30 PM   #20
MNBD
Member#: 323432
1998 Legacy GT
Green
MNBD is offline   Reply With Quote
Old 08-09-2012, 10:48 PM   #21
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Rotated BW S200sx-56
Suscribed!
DerekB707 is offline   Reply With Quote
Old 08-10-2012, 05:17 AM   #22
Grusselgrosser
Member#: 286859
2011 WRX Hatch
dude that is sick
Grusselgrosser is offline   Reply With Quote
Old 08-10-2012, 01:47 PM   #23
wtyree
Member#: 29879
2002 WRX Wagon
subscribed
wtyree is offline   Reply With Quote
Old 08-12-2012, 09:51 PM   #24
cineris
Member#: 263329
2011 Impreza WRX
Also subscribed.
cineris is offline   Reply With Quote
Old 09-07-2012, 09:20 AM   #25
o4wrxwagon
Member#: 213945
04 wrx wagon
subscribed.
o4wrxwagon is offline   Reply With Quote
02 Subaru WRX Hybrid Build - Start Up NoobSack Built Motor Discussion 3 11-15-2011 10:46 AM
PERRIN - 2008WRX: Perrin 2008 Subaru WRX Hatchback Build PERRINJeff NASIOC Project Cars 44 03-09-2010 12:38 PM
Trade: 02 Subaru 2.5Rs for 02+ Subaru WRX (Plus Cash) Cky47 Private Vehicle 'For Sale' Classifieds 14 12-05-2006 04:14 PM
FS: 02 subaru WRX (reduced price) GenMaster Canada Region Forum 0 09-19-2003 06:43 PM
00 Audi S4 vs 02 Subaru WRX AmirWRX General Community 2 03-29-2002 09:01 PM
