#1 |
Member#: 295776
BAIC
Vehicle:2005 SAAB 9-2x Aero |
I probably should have posted this here, my bad:
OK so I've been wanting to restore the dull look to my headlights and was looking at the various products (ie 3M, Meguirs, Turtle Wax, etc.) to see what works best. Mind you, my headlights weren't horrible but they were starting to get the yellow oxidation and I tried using some cleaner wax and it didn't work so great so while searching on youtube I found people have been using toothpaste(since it's mildly gritty sorta like fine grade sandpaper)! I decided to give it a shot since my headlights weren't too bad and worst case scenario I would just buy a restoration kit if necessary. Here are some before and after pics of the toothpaste method. Oh, first wash the headlights before proceeding. Before Pics (top): ![]() front ![]() Mask painted area: ![]() Toothpaste, I used a .85 oz tube and used all of it. I split the amount between the two headlights and rubbed in a circular motion for about 2-3 minutes for each side : ![]() ![]() ![]() I then rinsed off the area with water, dried them off, and applied a coat of wax and then a coat of sealer glaze. I've used Klasse for about the last 10 years with great results. This stuff is awesome!! Here are the final results: ![]() left: ![]() right: ![]() Both: ![]() It took me a total of about 20-30 minutes to complete the task and I'm happy with the results. |
#2 |
Member#: 291738
Vehicle:2005 wrx blue |
Nicely done! What do u rub the headlights with beside the toothpaste? Like a bush or something?
#3 |
Member#: 295776
BAIC
I just used a cotton terry towel and used some firm pressure.
#4 |
Member#: 329774
Vehicle:2009 Mazda 6 Silver |
How does it work long term? I know they sell the headlight restoration kit at autozone and I've seen it personally work pretty well, I've actually used toothpaste on a LCD screen due to getting crayon on it.
#5 |
Member#: 295776
BAIC
Not sure, this is my first time trying this so we'll see. I know the wax and sealant glaze I use is good stuff.
#6 |
Member#: 278870
SCIC
Vehicle:2005 Stage 2 WRX Obsidian Black Pearl |
i use plastx, it was only 6 dollars and it works great and lasts
#7 |
Member#: 111653
Vehicle:2011 WRX STi SWP |
You're doing the same thing as using any mild polish.
#8 |
Vehicle:OK Houston we have an Uncle |
it usually last mine a month or so.....when i get the time, ill clean them up good and hit them with some ratte can clear coat and be done
