Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 08-21-2012, 11:31 PM   #1
black out
Member#: 319773
2005 wrx sti
Default meth question
Thinking about getting a aem meth kit but I want to know if I need a special tune or if I can just hook it up and go? I have a cold air intake a full tbe exhaust and Cobb ap stage 2 tune. And should I get any other mods before I get a meth kit? Or am I fine with what I have? Any input is great as to what I should do
black out is offline   Reply With Quote
Old 08-22-2012, 01:01 AM   #2
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
You will want to get it tuned. I suppose you may be able to run the smallest nozzle without any danger of harming your engine. But you will not see any power gains until it's tuned.
2010 WRX Limited is offline   Reply With Quote
Old 10-03-2012, 06:08 PM   #3
Member#: 278263
A tune is always recommended with added mods on these cars.
Meth is a fuel, so if you install it and drive it w/o a tune you will be running rich on WOT. If your too rich, you'll get bore wash & murder your motor slowly.
The tune is needed to adjust your fuel trims to make it a tad leaner (since you can w/ meth) & increase boost to make more power. It burns hotter thus, creating mad torque & spool.
A tune tells the ecu how to compensate for the meth & make it work with your car, not against it.
Hellchaser is offline   Reply With Quote
Old 10-08-2012, 06:34 PM   #4
Member#: 290921
2010 Impreza WRX prm
WR Blue
I'm thinking of doing the same do to Alaska not having above 90 oct. just curious on what every one thinks about the meth kits, any issues, problems, likes, dislikes. Right now I have a full setup on my 2010 WRX
336 WHP / 343 WTQ 2010 Subaru Impreza WRX tuned at COBB Tuning's facilities in Plano, TX. ProTuned using the COBB AccessPort on 91 Octane.
Primary Power Modifications:
COBB AccessPort
Tomioka TD05-20G
SPT Carback Exhaust
Perrin FMIC
COBB SF Intake + Box
ID1000cc Injectors
Walbro 255lph FP
Crawford AOS
3-Port EBCS
91 Octane
Click below to see this dyno graph on our Dyno Database:
Frmrbob is offline   Reply With Quote
Old 10-08-2012, 06:47 PM   #5
NASIOC Storefront Vendor
Member#: 329319
Meth is awesome for people who don't have access to higher octane fuels. You have to be careful when tuned for it to not run out during a pull, but as long as you are mindful of how much you have in the tank, it makes for a great way to safely increase power.
EdgeAutosport.com is offline   Reply With Quote
