Welcome to the North American Subaru Impreza Owners Club Saturday December 3, 2016
Old 09-02-2012, 11:58 AM   #1
Type2
Member#: 200436
2004 Forester XT
Default Any DIY rotated turbo with TMIC out there?
Ok - first off, I believe I've searched enough to warrant a new thread:
1. This subject looks like it was first broached HERE on NASIOC in 2005:
2. AMS came out with a kit in 2008:
a) NASIOC HERE
b) clubWRX.net HERE
3. IAG Performance also came out with a kit in 2008 - I don't see a price anywhere
a) HERE
4. P&L came out with a kit in 2008 - kit starts at $3,449
a) iwsti.com HERE
5. It was again discussed on iwsti.com in Feb of 2012 -- they mention P&L and ETS kits
a) HERE
6. It was discussed on NASIOC in Aug of 2012 -- a soon to be released kit by MPS was mentioned
a) HERE
7. The AMS kit HERE starts at $3,899 and goes up to $4,449 and it does NOT come with custom piping to get from TMIC to turbo.
8. I can't find the MPS kit by Googling. It may be out there, not sure.
9. The P&L kit is still being sold HERE for $3,449
All of these kits come with a turbo, look fantastic, well built but are extremely expensive (for me). I am wondering if I could do this myself and for much cheaper. I think I could source the rotated bits used in the classifieds, as well as a used GT30r or GT35r. Now, I'm definitely not an expert, but I think the biggest sticking points would be:
a) The turbo to Y pipe elbow
b) Intake with integrated MAF adapter
Does anyone have any experience or know exactly what I would need to do this? Am I over simplifying this? BTW, I drive a 2004 FXT. I am not interested in FMIC.
Thanks!
Type2 is offline   Reply With Quote
Old 09-02-2012, 12:29 PM   #2
gotsugg
Member#: 204014
02 02 WRB Bugeye
GTX3582 front mount turbo
It's a lot of work piecing a kit together, but it can be done. What kind of experience with this sort of stuff do you have? I ask because the full kits make this project pretty easy. Piecing it together will mean you need to be able to fabricate a few things along the way, as well as be able to have your car out of services for a much longer period of time.
Also, what type of TMIC would you be running?
gotsugg is offline   Reply With Quote
Old 09-02-2012, 12:34 PM   #3
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Type of TMIC and cars use are important questions. You are going to get more heat soak, which is why a lot of guys run meth with bigger turbo TMIC setups.
This is difficult for me to say, but if you are set on staying with a TMIC, stock location may be cheaper and more logical.
aboothman is offline   Reply With Quote
Old 09-02-2012, 01:31 PM   #4
Type2
Member#: 200436
2004 Forester XT
Not really any experience fabricating anything. I had a feeling I was over simplifying things. I didn't realize anything needed to be fabricated except the elbow from the turbo to the Y pipe. Are the rotated pipes different from other rotated pipes? Are the turbos in those kits different from regular rotated turbos?
I was planning on using my STi TMIC. I don't necessarily need a huge turbo, I was just looking at rotated b/c it seems easier to wrench on my engine, plus it looks like fitting the intake to the turbo is easier than using a regular inlet which gets quite cramped.
I was making the assumption that the only thing really different was the intake with integrated MAF adapter (which I was thinking about buying and not fabricating) and the turbo to Y pipe elbow.
I appreciate the feedback.
Old 09-02-2012, 04:47 PM   #5
fr0st_wrx
Member#: 126717
2006 WRX
I had an sti tmic on a rotated perrin 30r kit. Wasn't that hard, bought the couplers off ebay. Think I needed a 45 degree bend coupler and a piece of aluminum to hook the stock ypipe to the bend and that was about it.
fr0st_wrx is offline   Reply With Quote
Old 09-02-2012, 06:07 PM   #6
Type2
Member#: 200436
2004 Forester XT
Do you have any pics of your old setup? Re: aluminum piece - how long and what diameter? What about the 45 degree bend coupler? Where did you source the intake w/ integrated MAF? Did you get it from Perrin? How did your setup run? Did you run EWG?
Thanks!
Old 09-03-2012, 12:53 PM   #7
fr0st_wrx
Member#: 126717
2006 WRX
Thanks!
There may have been 2 aluminum pieces I forget, the way it was setup looks kinda like the way perrin adapts their fmic to rotated.. like a """\__
The aluminum piece was about 3 inches long 2in diameter(same as the compressor outlet to the ic),it was long enough to get 2 clamps on the ends for the silicone pieces. the 45 bend came with about 6inches on each side of the bend and I trimmed it to fit. I dont have any pictures but it was setup with maf on a cold air intake, purchased from KStech designed for the perrin kit. It had an EWG on it, but I never got it fully tuned with the tmic, got a base tune and ended up going fmic because the tuner didnt wanna tune the sti tmic. It has been done though and will work.
If youre going to do it Id get a larger tmic to do it with. Or at least a GR sti tmic.
Gl
Old 09-02-2012, 07:40 PM   #8
Ilovecugars
Member#: 299442
2005 Forester XT
This is a great thread because I'm am in the exact same host as the op. I even have an FXT as well.
I've done a fair bit of searching as I'm planing a turbo upgrade soon and would love to take advantage of the better priced turbos that work with rotated setups as well as ease to work on. But I also want to keep a tmic setup.
You can pick up a turbo xs kit of just the up and down pipe new for a fairly good price but I feel that setup might sit the turbo to high to plumb to a tmic. Perrin told me there to setup will work with tmic and you can buy just the up and dp. The also told me there new intake was made to be Maf based and has inlet to plumb you bpv back into so that takes car of that.
If you google "sti rotated adapter" a thread from itwsti will come up with a vender that makes a rotated adapter to a stock uppipe to help cut cost.
It would be great to see some pics of some pieced together setup of the tubing from the turbo to tmic.
I'd love to figure out a good plan and I would totally take the rotated route.
Ilovecugars is offline   Reply With Quote
Old 09-02-2012, 08:27 PM   #9
Type2
Member#: 200436
2004 Forester XT
How much was the Perrin setup -- the up pipe, down pipe and intake w/ MAF? Any links? If they say their setup will work with TMIC then I'm super interested. Although I am still unsure if these pipes are special in any way to a regular rotated pipe. Do you have any idea?
P.S. I don't have a stock up pipe but I checked out the iwsti.com thread HERE anyway. Pretty interesting. It's a couple years old - I wonder if he is still in business.
Thanks for the info and hopefully some people who have done this before will chime in with some pics. I'm surprised this option isn't discussed more often.
Old 09-02-2012, 10:14 PM   #10
Ilovecugars
Member#: 299442
2005 Forester XT
I don't think the Perrin site has just the pipes listed but I have been in contact with them. I believe just the up and down was $1299 and the inlet was $250 or around there. They did not claim it to be it to be bolt on for a tmic but said it wasn't very hard to do and that it had been done already with there newest version rotated kit. I would have to guess it keeps the turbo down lower making it easier to line up with the tmic y pipe.
The turbo xs kit looks quite nice and is alot better price at $800 but it seems to sit the turbo high. I may to some searching around and see if a tmic has been done with it.
Yes I was in contact with the guy on itwist about a month ago and he will still make them. I have heard his quality is very good. But you will need a custom down pipe I believe to line up with his adaptor. I have not seen many pictures of it setup in a car so I'm not sure how high it sits.
No problem with the info were in the same boat on this one it seems.
Old 09-02-2012, 10:24 PM   #11
207STi
Member#: 197062
1998 Swapped Impreza
black
If you look past the first page in the thread I posted there are a ton of installed pictures. I plan on having a local exhaust shop fab something up for the downpipe.
207STi is offline   Reply With Quote
Old 09-02-2012, 11:57 PM   #12
Ilovecugars
Member#: 299442
2005 Forester XT
Do you you feel you would be best off to take a regular down pipe to an exhaust shop and get them to modify it to a rotated style or is it probly easier to start from scratch? I have some fab skills but I've never done any exhaust header work that really involved changing the original shape alot so I'm kinda out of my element here.
Old 09-02-2012, 09:01 PM   #13
207STi
Member#: 197062
black
Funny you mention this, just paypaled Dave his money earlier today! Im really excited to see it in person when it is finished. His craftsmanship seems to be top notch from all the pictures in the iwsti thread.
and a link to the thread : http://www.iwsti.com/forums/engine-p...-adaptors.html
Old 09-02-2012, 10:53 PM   #14
gotsugg
Member#: 204014
02 02 WRB Bugeye
That looks like a pretty nice inexpensive option. Also search for "Rotated" in the classifieds, there are several full kits there as well as a Perrin Rotated uppipe for $250.
Old 09-03-2012, 10:38 AM   #15
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Contact Tigwerks (SN on here) He is a fabricator out here in CA that does really nice work, and I believe he has a sale on rotated piping right now if you want to piece it together.
There are several threads displaying his work.
Old 09-03-2012, 10:45 AM   #16
Type2
Member#: 200436
2004 Forester XT
Awesome, thanks. Maybe he has a turn key solution for a reasonable price.
Old 09-03-2012, 11:23 AM   #17
gotsugg
Member#: 204014
02 02 WRB Bugeye
^^ he has a very nice looking rotated kit and the price was right when I was looking at it.
Old 09-04-2012, 01:27 AM   #18
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Kelly at Tigwerks can fab up anything you need adapter wise... And it will be similar in cost with better fitment than Perrin
Old 09-04-2012, 12:19 PM   #19
Cleveralias
Member#: 96804
2006 WRX STI
I went with the TurboXS rotated kit earlier this year with the intent of using their TMIC. Also couldn't find an example and was concerned about the height but figured I'd have to leave it an unknown until I got the turbo in. I now have a FMIC with the TMIC resting comfortably in a box.
I saw this kit mentioned earlier in the thread and I'm Just hoping I can save someone the trouble in case they're thinking of going this route - TMIC is not happening with the TurboXS kit.
Cleveralias is offline   Reply With Quote
Old 09-04-2012, 07:45 PM   #20
Ilovecugars
Member#: 299442
2005 Forester XT
Damn! I really liked that kit but from studying pictures of it installed on cars and measuring on my own car it really didn't seem it was going to work.
Thanks for helping us rule one kit out.
Old 09-04-2012, 08:02 PM   #21
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
just have it made locally custom. Usually cheaper than a premade kit and fits your exact needs. Why you would want a turbo that large trying to breath through a oem tmic is beyond me though.
scby rex is offline   Reply With Quote
Old 09-04-2012, 10:11 PM   #22
Type2
Member#: 200436
2004 Forester XT
Hey! That's a totally legit question. Why the heck would I go through all that trouble just to constrain a larger turbo on a heat soaked contraption that the TMIC is??!
Here are my bare necessities:
1. I want to keep my fog lights
2. I want to to keep my windshield washer bottle
3. I want to keep the factory battery in the factory location
4. I need the factory bumper beam intact and in place?
Unlike yall'z snazzy STi's, I drive a 2004 Forester XT. If you've ever sniffed around subaruforester.org (you probably wouldn't unless you're a Fozz addict like me) you will realize there is a complete dearth of kits for 2004/2005 FXT FMIC. See THIS thread. Strange, because there are a million simple bolt on FMIC's for WRX's & STi's -- you'd think that it would be like LEGOS... but then where are the 04/05 FXT direct bolt ons? None! lol! I would LOVE to have an FMIC but the way these cars are designed, it's nigh impossible to meet my basic criteria without taking my car to the butcher and I'm not prepared to do that. I'll go bolt on Dom 4xtr before I do that - which btw, I may very well do just that.
Old 09-04-2012, 08:17 PM   #23
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
The pic with the cosworth manifold is phatron's, the rest are my brothers (he built), same kit, built at Alliance Fab in Anaheim, CA
Irv Weissmanhowerton is offline   Reply With Quote
Old 09-05-2012, 12:14 PM   #24
Type2
Member#: 200436
2004 Forester XT
Irv - those kits look amazing! Any idea on price for the up pipe, down pipe intake and the elbow adapter that hooks up to the Y pipe?
Old 09-04-2012, 10:25 PM   #25
scby rex
Member#: 104878
02 wrxbastardchild
well have fun with that.
You could also have a reputable shop build a fmic for about the price a spearco tmic would cost and be alot less cussing everytime the elbow blows off the turbo when you go wot.
