Old 09-02-2012, 01:33 PM   #1
Subbie n00b
Member#: 324558
2004 Impreza WRX
Lightbulb Transfromation of a WRX winged trunk to Wingless
Hey guys so I have been looking for a wingless for quite a while now and it seems that wingless are SO rare! O.O
So I thought maybe I might just do a DIY and post pics for you guys to see and comment/guide me
I purchased a PSM winged trunk off another nasioc member here for $50 . Note: I own a 2004 WRB WRX, and I do realize that I bought a PSM. The trunk was around a 7/10 quality there were some rust on the left side.
When I got them from him, he already sold the spoiler, and subaru badge so two less job to do
I already started to sand
will keep updating
Subbie n00b is offline   Reply With Quote
Old 09-02-2012, 01:37 PM   #2
Subbie n00b
Member#: 324558
2004 Impreza WRX
I finished sanding using 150 grit and took me around 30 mins becuase I forgot I have a sander :/
I sanded layer by layer starting around the holes. Im going to be welding the holes up so I sanded around the holes until it was bare metal. And I got rid of the rusted left side too
Old 09-02-2012, 01:40 PM   #3
Subbie n00b
Member#: 324558
2004 Impreza WRX
And this is what I have so far
Since I don't know how to weld, ima be doing some research around town. I heard that some people use vinyl screening + bondo, straight bondo, and some use fiber glass.
If anyone has any experience plz help? thanks :3
Old 09-02-2012, 06:25 PM   #4
church207
Member#: 269152
93 legacy ss
good job hope turns out good for u thanks for the good deal
church207 is offline   Reply With Quote
Old 09-02-2012, 07:19 PM   #5
Subbie n00b
Member#: 324558
2004 Impreza WRX
Thanks! Did u give me some feedback btw? I left u some feedback already
Old 09-02-2012, 07:36 PM   #6
Wussman24
Member#: 157283
2003 2.5RS
Rattl'd white
I pop-riveted a piece of metal on the backside of my keyhole. I drilled 3 holes around the original, hit them with a ballpeen hammer to countersink them, put the piece on with the rivets, and filled with filler. BOOM. It was done.
Wussman24 is offline   Reply With Quote
Old 09-02-2012, 08:51 PM   #7
Subbie n00b
Member#: 324558
2004 Impreza WRX
Speak English plz ? My username explains...
Old 09-02-2012, 09:12 PM   #8
Subbie n00b
Member#: 324558
2004 Impreza WRX
Sorry, I actually did some googling and pop riveting sounds pretty good. Did you put the metal interior or exterior?
Old 09-03-2012, 09:29 PM   #9
Subbie n00b
Member#: 324558
2004 Impreza WRX
So I went to home cheapo today and got some bondo
I got the fiberglass mesh thingy and i add it to both sides of the trunk. I did some cutting made like 20 small squares.
Applied some bondo around the hole then put the mesh on so it would stick. After that, I covered the whole mesh thingy with bondo.
Left to go eat! enjoyed some labor day steak
Old 09-03-2012, 09:33 PM   #10
Subbie n00b
Member#: 324558
2004 Impreza WRX
After i came back, the bondo were as hard as rock O.O
Used 80 grit sand paper and starting to sand, via hand and sweat since I couldn't fine my sander >
I sanded it down until i could see little parts of the mesh, I realized that primer is going to smooth everything out, so a little teeny weeny bump wont be that bad
Old 09-03-2012, 11:56 PM   #11
DONx3
Member#: 214050
2007 WRX
World Rally Blue
So you place the mesh (1 for each side) between the holes and applied the bondo? It looks pretty good can't wait to see the final product!
DONx3 is offline   Reply With Quote
Old 09-04-2012, 10:25 AM   #12
Subbie n00b
Member#: 324558
2004 Impreza WRX
Yup, and thanks! Will keep going!
Old 09-04-2012, 10:34 AM   #13
RustyHinge
Member#: 299742
2007 STI Limited#382
07 WRB STI sold 9/28/12
Looks like a good project that could really turn a profit as long as you have the time to spend. I might look into doing this as well. Might even create my own doluck trunk. Hmmm
RustyHinge is offline   Reply With Quote
Old 09-04-2012, 10:43 AM   #14
PSM_02_WRX
Member#: 197108
2003 Ford Mustang GT
Cool write up. Can't wait to see more. I been wanting to do something like this for a while or least start getting used to some body stuff. That way I can add another thing for our performance shop to do.
PSM_02_WRX is offline   Reply With Quote
Old 09-04-2012, 12:46 PM   #15
Subbie n00b
Member#: 324558
2004 Impreza WRX
So I just picked up my white primer yesterday and found a little paint roller
I sanded the whole trunk with 80 grit sandpaper then washed it and waited it to dry, don't want anything to mess up :O
I found some old drape and put it under the trunk! Here's my first primer layer waiting to dry!
Old 09-04-2012, 01:02 PM   #16
Just1More
Member#: 319078
2005 STi
I don't mean to nit pick but having a layer of fiberglass over each hole will be very noticeable.. regardless of how smooth you transition it into the old paint. i would only use it on the inside. Make sure that rustoleum primer is compatible with whatever base coat you decide on also. Good luck
Just1More is offline   Reply With Quote
Old 09-04-2012, 01:08 PM   #17
youngxlos
Member#: 232169
2002 Hawkeye
World Rally Blue Pearl
That bondo is going to start sinking over time, the best and only way of doing this is getting the hole welded closed.
I did the same exact thing to my old car after about 6 months you could clearly see where the bondo had sinked and the trunk looked like ass.
I would remove that bondo and take it to a shop they can probably weld close the holes for under $100
youngxlos is offline   Reply With Quote
Old 09-04-2012, 03:01 PM   #18
Subbie n00b
Member#: 324558
2004 Impreza WRX
Thanks for the heads up guys! Unfortunately i have already started to primer and sand if the bondo shrinks...can't i paint like a "rubber" layer over my trunk first before i paint the actual body paint? Also wont the clear coat hold?
I was doing do research about the whole weld the holes / fiberglass it.
My theory was that if i covered the bottom of the holes and put an entire layer of tough coating before the actual body paint plus clear coat, it wouldn't sink.
But then again I am a complete noob at the stuff and years of experience might be better...
Old 09-04-2012, 03:18 PM   #19
SparkSilver10NM
Member#: 302438
10 WRX
SS DMrally tuned!
I think over time it will sink, but every other step you've taken is right on target. I'm glad to see a noob really gettin his hands dirty! Good write up!
SparkSilver10NM is offline   Reply With Quote
Old 09-04-2012, 03:19 PM   #20
ezael
Member#: 326560
Nice job!
ezael is offline   Reply With Quote
Old 09-04-2012, 10:53 PM   #21
Subbie n00b
Member#: 324558
2004 Impreza WRX
Update: turns out this method doesn't work
Unless I leave bumps on my trunk, the bondo is actually going through the hole
I'm re-sanding the bondo off and calling local auto shops to see if they can weld for me. I called one already and they said that without access to the backside of the hole, it's going to be a very difficult job .
Old 09-04-2012, 11:01 PM   #22
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
If you go buy some metal adhesive from lowes then you can glue a coin over the inside or a thin sheet of metal then fill from the outside and sand smooth.
Just a suggestion for a cheap way without welding.
JavaBot is offline   Reply With Quote
Old 09-04-2012, 11:04 PM   #23
Subbie n00b
Member#: 324558
2004 Impreza WRX
Is it kinda like panel bonding, epoxy, etc? I was think about that, but couldn't find info on it
Old 09-05-2012, 12:32 AM   #24
youngxlos
Member#: 232169
2002 Hawkeye
anything you use other than welding will be temporary, in time even using the coin.
It will not be a 100% seal and the outline of the coin will be visible over time.
believe me I've tried it, it just doesn't work in the long term.
but you guys are welcome to try it
Old 09-05-2012, 09:15 AM   #25
Subbie n00b
Member#: 324558
2004 Impreza WRX
Ok, does anyone know how I should prep it for welding? Do I have to cut the bottom out so the welder can access the back?
