Old 09-07-2012, 04:41 PM   #1
DSM Goat
Member#: 313071
1998 Forester L
Default EJ20 w/VF48 into 1998 Forester
I bought a 98 Forester last fall and drove it for a couple weeks and discovered it had bad headgaskets (big surprise, I know). I was going to just get the heads resurfaced and replace the headgaskets until I happened across an 02 WRX on my local craigslist. It came with the motor and transmission and it was pretty cheap, so I decided to go get it,
Instead of just replacing the headgaskets on the Foz (where's the fun in that? ) I thought I might as well just get rid of the pos Forester 2.5L,
And put in the WRX EJ20,
So, I pulled the 2.5L,
And got to work...
DSM Goat is offline   Reply With Quote
Old 09-07-2012, 04:44 PM   #2
DSM Goat
Member#: 313071
1998 Forester L
Jeez, look at that dirty engine bay, gross!
Really nasty. So I decided to strip the engine bay,
Clean up some problem (rusty) areas
And repaint the engine bay,
On to the interior...
Old 09-07-2012, 04:54 PM   #3
DSM Goat
Member#: 313071
1998 Forester L
Got the dash off,
Locating dash harness,
Removed the dash bar,
Time to get the dash harness out of there...
Old 09-07-2012, 05:02 PM   #4
DSM Goat
Member#: 313071
1998 Forester L
Unplugging,
Getting closer,
Got it out! Whew! PITA.
Now what? Get ahold of Brian at iWire.
Old 09-18-2012, 08:12 PM   #5
DSM Goat
Member#: 313071
1998 Forester L
Since the Foz is going to be motivated by forced induction the old crossmember had to go.
Out of there!
Sourced a crossmember from an early-90s turbo Legacy.
Better get that bolted up...
Old 10-04-2012, 10:05 PM   #6
DSM Goat
Member#: 313071
1998 Forester L
Whew, been busy! Got the crossmember bolted up...
Decided I'm going to run e85 (got an e85 station just a few blocks from my house), so a fuel pump swap was in order (along with injectors and a tune).
Out with the old fuel pump..
And...
Old 10-04-2012, 11:18 PM   #7
omz
Member#: 232060
Dude, as awesome as this is, your pictures are all out of wack.
omz is offline   Reply With Quote
Old 10-05-2012, 09:16 AM   #8
Dr. octagon
Member#: 171127
62XX Rotated
*Mo Displacement
As you were,
Keep going
Old 03-18-2013, 09:15 AM   #9
DSM Goat
Member#: 313071
1998 Forester L
Long time, no post. Busy, busy, busy!
Time for updates...
Now that the Walbro fuel pump is installed, it's time to focus on the engine...
Got the EJ20 up on the engine stand:
Old 03-18-2013, 09:19 AM   #10
DSM Goat
Member#: 313071
1998 Forester L
The stock TD04.
Say by-bye!
Old 03-18-2013, 09:21 AM   #11
DSM Goat
Member#: 313071
1998 Forester L
Here today, gone tomorrow.
Old 10-05-2012, 07:25 AM   #12
subieguy87
Member#: 153412
1998 Impreza wrxRS
How do you say?
subieguy87 is offline   Reply With Quote
Old 03-19-2013, 07:50 PM   #13
civichx97
Member#: 280149
2004 Impreza WRX
blue
nice thread, I'm doing a wrx into my sf foz soon too
civichx97 is offline   Reply With Quote
Old 03-20-2013, 07:43 AM   #14
DSM Goat
Member#: 313071
1998 Forester L
It's fun. But it can get a bit more expensive than you were expecting.
Old 03-20-2013, 08:08 AM   #15
DSM Goat
Member#: 313071
1998 Forester L
Installed TGV deletes:
Replaced the stock inlet with a Samco piece:
Larger intercooler:
Old 03-19-2013, 11:39 PM   #16
monkeyposeur
Member#: 333468
93 SS
Black Pearl
Sweet swap! I'm building a 22T to swap in my 95 L wagon. It's going slowly and expensively, lol.
monkeyposeur is offline   Reply With Quote
Old 03-20-2013, 01:52 PM   #17
amiexploited
Member#: 251061
2002 wrx
wrb
SWEET, subscribing.
amiexploited is offline   Reply With Quote
Old 03-20-2013, 02:22 PM   #18
veightkiller
Member#: 78967
2011 335i
Nice project!
veightkiller is online now   Reply With Quote
Old 03-21-2013, 10:06 AM   #19
DSM Goat
Member#: 313071
1998 Forester L
Thanks!
Meanwhile...I had sent the Forester dash harness and the WRX engine harness off to Brian K. at iWire to be merged. Brian did an amazing job and was a great help when it came time to reinstall the harnesses:
Whew! Glad THAT's done!
Old 03-21-2013, 11:50 PM   #20
SilverBullet745Li
Member#: 343518
looking great. my forester is also on its way to being as badass as yours.
SilverBullet745Li is offline   Reply With Quote
Old 03-24-2013, 09:36 AM   #21
DSM Goat
Member#: 313071
1998 Forester L
Thanks. Feel free to hit me up if you need any advice on your swap.
Time to install a boost gauge. Pulled the upper cover off the steering column and marked where the gauge is going to go:
Installed the gauge cup:
Gauge installed:
Old 03-24-2013, 09:44 AM   #22
DSM Goat
Member#: 313071
1998 Forester L
Reassembled the engine bay after cleaning and painting:
Installing a Mishi radiator. Test fit:
Old 04-24-2013, 10:23 PM   #23
wrx614
Member#: 71848
2003 WRX
Getting ready to start the same project soon. My wife's boss has a Forester shell and my WRX has some body damage. Does anyone know how much of the interior is swappable? I would like to keep my WRX dash, pedals, and steering wheel.
wrx614 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 07:42 PM.
