#1 |
Member#: 12263
TXIC
Vehicle:'02 WRX SRP 4EAT XPT Stg II |
Question: What are the possible mechanical reason my car is pulling timing?
Car: 2002 WRX w/4EAT and 160,000 miles Background: I have had an OTS Stage II map on my car for the past 5 years. When I first flashed it, I did some logs and everything was fine. Recently I started logging it again just to check it and the car was pulling timing from about 4000 RPM. IAM is also reading very low. I changed to some thicker gaskets on the uppipe, thinking that I might have a boost leak. but it was still pulling timing. I also recently began having issues with my Factory Boost Controller, so I replaced it with the Grimspeed BCS and flashed a new OTS map that was specifically for the Grimspeed BCS. It's still pulling timing and IAM dropped from 15 when I started the car to 0 when I did my run. The car seems to be running pretty good though. I'm not hearing any pinging or ticking, it pulls hard and smooth. Here is a log I took today. https://docs.google.com/spreadsheet/...HdESksySEZiQ1E |
#2 |
Member#: 152261
SCIC
Vehicle:2007 WRX 2.5 Crystal Gray Metallic |
Check MAF
#3 |
Member#: 12263
TXIC
#4 |
Member#: 152261
SCIC
For me, the o-ring that seals it was cracked causing a leak @ high rpm. Check it for leaks. Borrow another fellow subie's MAf and test it on your car. See if problem goes away.
#5 |
Member#: 268354
Vehicle:02 WRX 05 LGT Slow Automatics |
Yikes! It looks to me to be a post MAF leak or boost leak. How does the inlet look where it connects to the turbo?
#6 | |
Member#: 12263
TXIC
One other thing I forgot to mention was, awhile back I accidently stripped out one of the bolt holes that holds the BOV to the intercooler. I re-tapped the hole, but I had to go with a bigger bolt. The new bigger bolt wouldn't go through the gasket, so I just used liquid gasket. I checked for leaks, and there wasn't any. I haven't checked for leaks since then though. |
#7 |
Member#: 117489
Vehicle:03 wrx 284hp/269tq |
You will hear a boost leak from the bpv, sounds like you ran over a pack of squirrel
#8 |
Member#: 12263
TXIC
#9 |
Member#: 3536
SCIC
Vehicle:2013 SWP BRZ Limited 2002/2003 AW/PSM WRX |
Try replacing your crank position sensor.
#10 |
Member#: 151045
Vehicle:2013 Subaru STI CBP |
#11 |
Member#: 12263
TXIC
Ok .. as requested, here is the new log with cooler (76 degrees) air. I also reset the ecu prior to the run and did the quick-learn trick.
https://docs.google.com/spreadsheet/...203YWlCNXJsYlE |
#12 |
Member#: 268354
How are you resetting the ECU? Through RR or pulling the battery terminal? Also, you need FLKC, FBKC, and IAM in your logs.
I would really like you to pull a learning view image for us. If it ran better before, why don't you get a new 2 port solenoid and flash the old map back? |
#13 | |
Member#: 12263
TXIC
I think that when I put the new 3 Port EBCS on, it just amplified the issues I am having with the car. I'm hoping that if I can get this all sorted out it will work better. |
#14 |
Member#: 223137
Vehicle:13' super ultimate race car project |
are you running a stock intake system? anything other than a cobb short ram could cause issues
#15 |
Member#: 12263
TXIC
OK, so I inspected and cleaned the MAF, took out the Crank Position Sensor, and reset the ECU. I took it for another spin and I have the log below.
I didn't see anything really on the MAF, it was a little dirty, but not that bad. I did notice a small crack on the thin frame that goes around the brown bulb part, but otherwise, the rubber o-ring was fine. The car would also stall as soon as I disconnect the MAF. I'll see if I can find someone who will let me borrow their MAF though. The CPS was very dirty, but no scratches or dents. I cleaned it up and put it back in. The car seemed to run a bit smoother afterward. Here is the log I took. I did notice that the car pull timing until after 6000 rpm, which is higher then normal. Usually it starts pulling 1000rpm sooner. https://docs.google.com/spreadsheet/...kZBVEVlOUVfUUE |
#16 |
Member#: 12263
TXIC
#17 |
Member#: 152261
SCIC
Make sure you reset the ecu too if you make a change/fix something/log
#18 |
n00b Moderator
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
please double check the green connector as well as flash connector.
to make sure you did not leave either on connected. if not, thats not good..pulling timing means there is knock.. |
#19 | |
Member#: 12263
TXIC
I'm also not hearing any pinging or knocking from the engine either? |
#20 |
Member#: 118500
Vehicle:02 Silver Wagon "Stage 2" |
You are in San Antonio... It's hot. Are you sure it's not pulling timing due to IAT? Where were you when you data logged 5 years ago?
The ecu could be pulling timing due to knock. High IAT, or low octane fuel, can cause levels of knock that are imperceptible to the naked ear. It's normal operation for this to happen. |
#21 | |
Member#: 12263
TXIC
#22 |
Member#: 128115
South East
Vehicle:2004 4EAT Wagon PSM enginuity is cool |
How old are the spark plugs?
I'd try lowering the timing by a couple of degrees and seeing if that clears it up. I've had many maps that look good at first, but after a period of time, issues will settle out that need to be dealt with. |
#23 |
Member#: 118500
Why is it a problem that it's pulling spark? This is a normal function. Does your car feel down on power? Is your check engine light on? ALL cars will pull spark at some point. That's why they have knock sensors, and why so much time is spent developing the algorithms to read the knock sensor signals.
#24 | |
Member#: 268354
#25 |
Member#: 152261
SCIC
Any updates? reset the ecu and do the ecu learning trick.
http://forums.nasioc.com/forums/showthread.php?t=302047 do a pull and let us know if it still pulls timing. |
