#1 |
Member#: 236866
Vehicle:2011 WRX WR BLUE |
its a 2011 wrx only mod a invidia catback, running a stage1 93 octane Cobb OTS map.
is it knocking ? and what are my options should i try a different map?https://docs.google.com/spreadsheet/...EcwVVh6RS1iSlE |
#2 |
Member#: 297565
Vehicle:2011 WRX hatch Silver |
None of your log is useful. YouTube Wrx Cobb Datalog How to. You need to be in 3rd gear, just above 2k rpm and go WOT till redline. And where date to do so. Watch the video though and others. Great learning tools.
#3 | |
Member#: 236866
lol |
#4 |
Member#: 307624
Vehicle:2008 WRX Hatch 380XT: 325/343 @ 20 PSI |
Touch the gas pedal only very slightly when you're under 2000 RPM at 3+ gear!
You don't have any boost/torque there. Better yet, stay above 2000 RPM in 3+ gear all the time unless you're cruising. |
#5 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#6 |
Member#: 236866
i tried the best i could , but its a hard thing to do in NYC, here are 2 more datolgs i did today
https://docs.google.com/spreadsheet/...2tKSjFRaGlibUE https://docs.google.com/spreadsheet/...1k1QmNadXlYdlE |
#7 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#8 | |
Member#: 236866
https://docs.google.com/spreadsheet/...mR5anIxYnlmMEE https://docs.google.com/spreadsheet/...3pac2NNNTBlZHc https://docs.google.com/spreadsheet/...3BQME5qVHlSNEE |
#9 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#10 | |
Member#: 236866
this is a datalog i did today, stage 1 91 octane.https://docs.google.com/spreadsheet/...kt4bktuUzNleWc |
#11 |
Member#: 239335
W. Canada
Vehicle:2011 WRX WRB |
Change your map to the 91oct map. You're getting fine knock learn in the high rpm's which isn't good. Post logs of the 91oct map.
#12 |
Member#: 134005
Vehicle:2004 WRX Premium PSM |
I literally just swapped over to the 91 oct map after experiencing some FKL in the 2-3k range. Mine took effect immediately after driving and I had no knock. I'll log again after a week of driving, but in my opinion, what you were experiencing with the 93 oct map should have gone away after switching.
#13 |
Member#: 236866
I don't really know what to do at this point :/ .How bad is it? Would a protune fix this ?
#14 |
Member#: 297565
its not that bad. You're DAM is still at 1 which is good. This is basically saying you are on the optimal timing map.
Like said before, continue to get through this tank of gas, fill up with the best gas in town and log again. |
