Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 10-01-2012, 03:58 AM   #1
Ikant
Member#: 235925
Default Undarkening tail lights
Is it possible to remove to dark tint from tail lights that people use to darken them? I just bought my car and the taillights are dumb.
Ikant is offline   Reply With Quote
Old 10-01-2012, 04:30 AM   #2
FugitiveChris
Member#: 299017
2011 Impreza STi 5DR
Dark Grey Metallic
Is it paint or is it an overlay? If its an overlay you should be able to peel it off. If its paint then you could try paint thinner BUT it could damage the car's paint so remove taillight from car. Also it could harm the plastic so use a little at a time and work slow.
You could also wet sand till you hit the light then polish.
FugitiveChris is offline   Reply With Quote
Old 10-01-2012, 06:07 PM   #3
siadyang
Member#: 329715
2012 WRX Stockish
1992 300ZX TT Swap
You could also damp a dry cloth with brake fluid and wipe the paint off if it is painted. Just don't use too much. After you wipe all the paint off, you should be able to clean and polish it.
siadyang is offline   Reply With Quote
Old 10-01-2012, 06:40 PM   #4
cegan09
Member#: 302222
2012 WRX Hatch
just be warned that the same chemicals may also strip the UV protective coating on the plastic causing it to haze over like headlights do. If they're painted you might be better off just finding someone to trade with.
cegan09 is offline   Reply With Quote
Old 10-01-2012, 07:09 PM   #5
ivanbih
Member#: 227738
02 WRX
sittin' tall
isopropyl alcohol, 90% +
ivanbih is offline   Reply With Quote
Old 10-02-2012, 09:28 PM   #6
silmarilion
Member#: 191270
04 STI-R.I.P
06 STI-ALIVE & WELL!
Use brake fluid believe it or not. Take them off the car because the brake fluid will ruin your paint. Rub it in with a rag. The paint comes off the lenses without causing harm to the plastic lenses. Polish or wax them up and you're done.
silmarilion is offline   Reply With Quote
Old 10-02-2012, 09:36 PM   #7
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
+1 on brake fluid, what I used to take the paint off on one of my old emblems
alt14 is offline   Reply With Quote
Old 10-03-2012, 06:56 PM   #8
Ikant
Member#: 235925
I'll try it
Old 10-03-2012, 07:01 PM   #9
scoobySTi06
Member#: 334064
I used gas it worked great. Mine were just smoked not sure how dark yours are.
scoobySTi06 is offline   Reply With Quote
Old 10-03-2012, 10:23 PM   #10
bbun
Member#: 184554
02 ghettoFABness
bugeye rolling.
bbun is online now   Reply With Quote
Old 10-07-2012, 12:24 AM   #11
BLUEBATOVERLAYS.COM
Member#: 312664
Overlays ftw .
B@t™
BLUEBATOVERLAYS.COM is offline   Reply With Quote
Old 10-07-2012, 01:00 AM   #12
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
Brake fluid and nothing else. Rub your heard out. Just reclear with UV protectant. Easy.
Smurftastic is offline   Reply With Quote
