#1 |
Member Sales Rating: (15)
Member#: 124875
Vehicle:2002 WRX-MBP 1992 240sx coupe sr20 |
specs:
18x10 et21 square They were purchased for a Subaru fitment, not VW so they will work on your WRX wagon/sedan/04 sti they are 5x100 from work, they have work lips, and they have not been split. need to sell fast, 3k with tires im located in north new jersey ![]() ![]() ![]() Last edited by E_Jay_Twenty; 10-04-2012 at 12:16 PM. |
#2 |
Member Sales Rating: (62)
Member#: 95337
Vehicle:2008 Spec.B |
If they're VW specific, that means a Subaru owner would need lug nut adapters since VW's have a rounded lug seat and Subaru's have a conical lug seat.
I almost found out the hard way here: http://forums.nasioc.com/forums/show....php?t=2334886 |
#3 | |
Member#: 124875
#8 |
Member#: 124875
They are 5x100 I don't know if you could make them work, you'd have to do your own research.
Just talked to my friend I'm selling these for. He told me they were bought for a Subaru fitment. They were on a WRX wagon before he got them. |
#9 |
Member#: 95337
Fitting on a Subaru just means they have the same lug pattern. Were they made for Subaru fitment, or VW? Like I said in my prior post, it's not just the lug pattern that matters, but the actual contour or the lug holes.
#11 |
Member Sales Rating: (5)
Member#: 194062
Vehicle:2003 Impreza WRX PSM |
I'm sure they use standard tuner lugs like most aftermarket wheels. most of the ftermarket wheels on vw's aren't ball seat anymore. They usually swap to standard taper seats. Only problem might be whether they're 14 or 12 mm holes.
However they will be anything but easy to fit on a Subaru especially a wagon. Stretched tires, lots of camber and heavily pulled fenders will be the only way you get them close to fitting. Last edited by cowboy_Rob; 10-04-2012 at 02:21 PM. |
#13 | ||
Member#: 306287
not much, they were on one before i got them ![]() ![]() no, they are 5x100 not 5x114.3 Quote:
thanks guys ![]() |
