Old 10-04-2012, 12:45 AM   #1
polaks
Member#: 305714
Default Best Oil
Tried searching and everybodies answers are diferent... I drive a 1996 subaru sti, it has 71,000kms... I live in Manitoba, Winter is coming quickly... It gets real cold down here, it can hit -40 to -50... I just recentely changed the oil to Mobile 1 5w30 Synthetic. Is this one of the better, safer oils to go with? Should it be okay or is there something that might do the trick a little better? I read alot that these subarus love some thicker oils though....
Also not many people have talked about filters... I know 2002 wrx usdm filters fit these jdm sti's but which brand does everyone perfer?? I got stuck with a good old fram synthetic filer..
Thanks alot for any help!
polaks is offline   Reply With Quote
Old 10-04-2012, 04:13 AM   #2
AgentJ17
Member#: 306411
1995 STi RA
very eg33 such braap
Most of us use rotella t6 in our cars. The first guy I heard praise it is from Saskatchewan. So if it worked for him, it should work for you.
Subaru OEM, then wix or purolator for filters.
AgentJ17 is offline   Reply With Quote
Old 10-04-2012, 05:04 AM   #3
vic-gc8
Member#: 298909
1995 STi VII type-RA
White, on white wheels
Seconding the roltella t6,
vic-gc8 is offline   Reply With Quote
Old 10-04-2012, 11:59 AM   #4
polaks
Member#: 305714
Next oil change ill get some good old roltella t6 than !!
and ur saying oem subaru filter is better than wix?
also isnt t6 5w40? Wouldnt that be really really thick for winter? I will have to look into that in a bit.. (found my anwser, says it should be fine through winter) so I am good to go than
Old 10-04-2012, 02:26 PM   #5
Aphex28
Member#: 11506
2015 WRX
I would avoid Mobil 1 5w30 like the plague. It runs exceptionally thin and breaks down faster than most other oils I've tried.
There are plenty of threads on it, but just a quick synopsis is that Mobil 1 5w30 specifically should be avoided. The other weights are ok for it, but I myself have tried it on multiple engines and more of it gets eaten than other oils i've used.
Aphex28 is offline   Reply With Quote
Old 10-04-2012, 03:00 PM   #6
AgentJ17
Member#: 306411
1995 STi RA
Yes, I hear subaru filters are about the best. Wix and purolator also make a good filter. I've also heard to avoid fram filters almost as much as you should mobil 1 5w30.
Only thing bad I hear about rotella is that because it's a diesel oil, the zinc content will destroy catalytic converters.
Old 10-04-2012, 03:10 PM   #7
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
This is only an issue if you are burning oil.
TommyAtomic is offline   Reply With Quote
Old 10-04-2012, 05:45 PM   #8
subi400
Member#: 216984
1996 Impreza outback
Green
Polaks, I would also take a look at the Mobile 1 0w40 for use in the winter there. The T6 is similar, but the m1 0w40 will have just a little better cold flow capability when it gets as cold as you described.
subi400 is offline   Reply With Quote
Old 10-04-2012, 08:01 PM   #9
vic-gc8
Member#: 298909
Or running a catalytic converter.
Old 11-19-2012, 11:44 PM   #10
subi400
Member#: 216984
Green
I have to chime in here....I have been running the rotella T6 5w40 in my 96 2.2 impreza outback for the last 20k miles and it has 201,500 or so miles right now. Yeah, the engine burns some oil because of bad piston slap in cylinder 4 and when I engine break more. I got the p0420 code twice, but I suspect that was due to the crappy blend of ethanol and gas here. So, I have been running the 92 none ethanol here and the code hasn't come back. Original cats too....
So, I know for a fact that this oil doesn't really cause a cat problem unless the engine is drinking oil like someone drinking a slurpee on a hot day.
Old 10-05-2012, 01:08 AM   #11
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
oh jesus christ you HEAR???
HEAR...from WHERE......EXACTLY??!!!?!?!
post the link....SHOW US WHERE
THIS IS A MYTH
if anybody actually took the time to find and READ what was published on this testing
it was ONLY an issue with cars using enough oil that they are essentially blowed up.....and have cats
at which point it wont matter
this is one of the wives tales of the internet
Old 10-05-2012, 03:56 AM   #12
AgentJ17
Member#: 306411
1995 STi RA
That's why I said "hear" and not confirmed fact...
Either something I heard on jdmvip or bobistheoilguy. Didn't make it up myself.
Old 10-25-2012, 02:19 PM   #13
alanm474
Member#: 328599
The Best Oil is Motul 300V 15W50
alanm474 is offline   Reply With Quote
Old 10-27-2012, 03:27 PM   #14
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
I use Rotella T6 on all of my cars and motorcycles. No problems. For oil filters, I use K&N.
sizzflair is offline   Reply With Quote
Old 10-27-2012, 03:58 PM   #15
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
I run 15w40 Rotella or Delvac diesel grade fuel in all four Subarus in the driveway.
It doesn't get to -40 to -50 here, but cold cranking wasn't an issue last year near zero degree temps. Sure, the cars cranked slower than normal, but even my 84 BRAT had no problems starting up. Oil pressure was built up a little slower as well, but the pressure was there so that doesn't really pose an issue.
But if it does get that cold it is very possible running a higher grade oil can lead to cranking issues.
As stated above, diesel grade oils with the zinc components will not destroy your cats unless it is excessively getting into your combustion chamber, and making its way into the exhaust.
2 of the Subarus in the driveway are OBDII and I've been using 15w40 oils for a while now and have yet to get a cat inefficiency/P0420 code or any other cat related codes yet. The cats are just fine.
Jessekrs123 is offline   Reply With Quote
Old 10-27-2012, 04:16 PM   #16
ColeBerkenbile
Member#: 316278
2010 WRX Sedan
Wives tails? I wouldn't wife a woman with a tail.. but rotella all the way. It's great for turbo motors and also does well in small engines such as dirtbikes and whatnot
ColeBerkenbile is offline   Reply With Quote
Old 10-29-2012, 01:25 PM   #17
STillaredneck
Member#: 336419
2007 STi
I also run the Rotella 15w40 problem free all summer. But at the ski hills plugging it in isn't an option, so as much as I wanted to keep it simple and just go with Rotella 5w40 I instead chose Redline 0w40, noticed a huge difference starting it up these last few cold days.
STillaredneck is offline   Reply With Quote
Old 11-09-2012, 09:46 PM   #18
arangov3
Member#: 278414
Thin on start thick on running temps t6 for the win I run it in my na subby gfs honda and my gokart lol
arangov3 is offline   Reply With Quote
Old 11-16-2012, 04:31 AM   #19
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
wow didnt know this many people use rotella t syn.
i use GTX 5 30 with mobile 1 (m1-108) filter. altho i am kinda on a new-ish build with about 9k mi.
soon to be switching to AMS.
azn0boi04 is offline   Reply With Quote
Old 11-16-2012, 09:18 AM   #20
scoobay38
Member#: 337666
1994 gc8
peral white
Because of temp. in the caribbean i use Redline racing oil 10-40
scoobay38 is offline   Reply With Quote
Old 11-16-2012, 09:43 AM   #21
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
I used a soil for a while but that stuff is pricey. Now it s the T6 still holds up well.
Old 11-16-2012, 11:57 AM   #22
Strider327
Member#: 131280
2004 Impreza WRX
I've always used Rotella T6, its great, cheap and can be found at walmart. However, with my new build I have use a thicker weight so I'm switching over to Schaeffer's 5w50 Synthetic. In my opinion the best oil is one that has high zinc and protection additives that won't break down so easily.
Strider327 is offline   Reply With Quote
Old 11-19-2012, 09:21 PM   #23
impreza03WRX
Member#: 84975
I recently moved to Reno, NV and winters here get down to the 30's, summer highs in the 90s I believe. I am ok to just run Rotella 5w30 year round? Or is it optimal to use a certain viscosity in the summer and a certain viscosity in the winter? This is for a bone stock 2011 STI.
impreza03WRX is offline   Reply With Quote
Old 11-19-2012, 11:37 PM   #24
subi400
Member#: 216984
Green
Run the rotella T6 5w40 and don't sweat it, everything for both winter and summer will be fine
Old 11-20-2012, 12:32 AM   #25
impreza03WRX
Member#: 84975
cool will do, thanks!
