Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Old 10-04-2012, 04:51 PM   #1
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
Default '04 EJ20 to '04 EJ257 long block..
Swappin my Ej20(stock except for ACL rod & main bearings) for a built '04 EJ257 long block.. fresh bore/hone, manley rods, wiseco pistons 8.9:1 CR / 100mm, stock '04 EJ257 heads & cam gears. Not running AVCS.. utilizing ej20 manifold harness/ecu.. Currently im running a Cobb catless VF39 tune, with STi pink injectors, and VF39 turbo. Supporting mods, TGV deleted, oem 2004 STi cat back, 3" catless invidia DP, perrin catless UP, Perrin turbo inlet, AEM short Ram, step colder NGK plugs etc..
Question.. Can I get a tune from COBB that will compensate for the larger displacement still using my ej20 ecu or do I have to open source/etune or smthn.
Also, what clutch setups are people runnin on EJ257 swaps still using the 5spd wrx trans..? Was gonna replace the whole thing with an exedy kit & flywheel.. THis is my daily driver so I dont need anything crazy but a little extra holding capabilty is always nice.
99imprezd is offline   Reply With Quote
Old 10-07-2012, 11:11 AM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
You will need a custom tune to deal with the extra displacement.
The EJ257 can use the same flywheel and clutch as the EJ205's use when using a 5 speed.
Old 10-07-2012, 11:38 PM   #3
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
I was thinkin about loading a cobb 04 STi stage 1 tune for break in on low boost.. wouldnt an sti tune make correct adjustments for 2.5 litres? Not sure if the ecu will let me load an EJ25 map on my EJ20 ecu but worth a shot?
Old 10-08-2012, 03:00 PM   #4
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
hmm.. nothin? does anyone have or know of a standard tune for EJ257 swapped wrx's?
