Welcome to the North American Subaru Impreza Owners Club Tuesday June 30, 2015
Old 10-04-2012, 06:33 PM   #1
Rodrigohc
Member#: 294042
Default 03 wrx with sti pink injectors ?
Just installed a set if pink injector on my 03 wrx, the car ran fine before the swap now the car send to hesitate at 4000rpm the car has a big 16g turbo swap as well.. Does it mean I need a bigger fuel pump or are the injectors no good? Ps I did change the filters and o rings before install
Rodrigohc is offline   Reply With Quote
Old 10-04-2012, 08:09 PM   #2
fmars62
Member#: 290517
2008 Impreza 2.5i
Dark Grey Metallic
a fuel pump wouldnt hurt it, but did you tune it when you put them in or reset it?
fmars62 is offline   Reply With Quote
Old 10-04-2012, 08:14 PM   #3
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
pinks are NOT...no possible way...big enough for a 16g....and the pump is **** on the bugeyes
...replace that for sure, too
and you can not just throw parts on a car and not tune it
this is a disaster waiting to happen
Old 10-04-2012, 08:32 PM   #4
Rodrigohc
Member#: 294042
I was planning on getting it tuned !! I just didn't understand why the car was chocking the way it was!! I just wanted to make sure that the injectors weren't bad before I take it to get tuned and I also have a fuel pump to install it
Old 10-04-2012, 08:48 PM   #5
quazimoto
Member#: 70395
That's because you are a complete buffoon. Try reading the FAQ's and researching before you mod next time. You can not install larger injectors without changing the scaling in the ECU.
Old 10-04-2012, 08:33 PM   #6
Rodrigohc
Member#: 294042
Would a Cobb tuning accessPort help?
Old 10-05-2012, 10:55 AM   #7
JMSok8
Member#: 309967
2003 WRX PSM vf34
No. An AP will only give you a limited amount of maps which include a vf39/vf34 for a stage 3 map. I dont believe there is a map for a 16g. That would be a protune. Your injectors are definately maxed out. I would suggest selling your 16g and getting a vf39/34.
JMSok8 is offline   Reply With Quote
Old 10-05-2012, 11:05 AM   #8
art@grimmspeed
Member#: 301037
2004 Forester XT
I am surprised the car idles right. As others have stated you can not just put bigger injectors and larger turbo on the car and expect it to run right without a tune. There is a map for an FP 16g in the Accessport for an 03 WRX that uses 565cc injectors. Take a look at the map notes and see what it requires.
art@grimmspeed is offline   Reply With Quote
Old 10-04-2012, 08:51 PM   #9
briankyle97
Member#: 298271
2015 WRX base
^ why no "like" button
briankyle97 is offline   Reply With Quote
Old 10-04-2012, 09:08 PM   #10
JRsleeper
Member#: 94791
2002 WRX wagon WRB
Ver 8 EJ207 4.44's
What is done to your car?
JRsleeper is offline   Reply With Quote
Old 10-04-2012, 09:04 PM   #11
Rymaster
Member#: 296277
2002 Impreza WRX
yeah, you could have an amazing setup but it can run like complete poopoo if no tune ;(
Rymaster is offline   Reply With Quote
Old 10-04-2012, 09:46 PM   #12
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Old 10-05-2012, 09:09 AM   #13
Dirty_WRX
Member#: 258491
2002 VF34'd Bugeye
My Other Ride's your MOM
Your probably maxing out the pinks or at least close too it.....as for the pump....I had issues that little thing feeding my Td04 so I'm sure the 16g needs a pump upgrade
Dirty_WRX is offline   Reply With Quote
Old 10-05-2012, 09:16 AM   #14
Uncle Scotty
OK buy Nates beans
probably????
my p&p td04 @18psi maxed out the pinks
any decent tune with ANY 16g will max the pinks at stupid low power
PROBABLY???
NO 'probably' about it
Old 10-05-2012, 04:55 PM   #15
Rodrigohc
Member#: 294042
Thanks for the info guys !!
