Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 10-05-2012, 10:14 PM   #1
Bulldogg5
Member#: 334027
Default Bov
Got a stock 2011 wrx want to get BOVjust for the now before I start any major work on the car. want to know if I have to get a recirculating one?
Bulldogg5 is offline   Reply With Quote
Old 10-05-2012, 10:19 PM   #2
scx89
Member#: 269388
2011 Impreza WRX
obp
do a search on BOV's
it's also in unabomber's manifesto
read it
scx89 is offline   Reply With Quote
Old 10-05-2012, 10:25 PM   #3
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Stop.
Read UNABOMBERS MANIFESTO (stickied in this section) right now.
Read it again.
Learn.
Put new smarts to use.
Simply, you don't need one AT ALL. At least not now. When the time comes, if ever, that your stock BYPASS VALVE fails, you will want to get a replacement BYPASS VALVE that recirculates into the intake.
Old 10-05-2012, 11:49 PM   #4
Malin726
Member#: 310950
2004 WRX
WR Blue
I'm pretty sure there's another sticky up there that basically says that they're ok to use.
Malin726 is offline   Reply With Quote
Old 10-06-2012, 12:03 AM   #5
jimbosv650
Member#: 261307
04 wrx wagon
I'm pretty sure that there are probably hundreds of members here, myself included, who have at one point run a bov and can tell you they suck. Don't do it on a stock car. If you need the noise, change the intake. I don't know if you can modify the factory bpv on your year, but I did on mine and it makes quite a loud sound.
jimbosv650 is offline   Reply With Quote
Old 10-06-2012, 12:00 AM   #6
Thunderpaw
Member#: 242205
2009 wrx
blue
Oh Lord...please search first. I know you're new but there is a ton of info about this. At least you posted a question about it before doing it
Thunderpaw is offline   Reply With Quote
Old 10-06-2012, 12:13 AM   #7
cpz1987
Member#: 307403
2012 WRX HATCH
WHITE
Just did a bov on my car, and 1 week later I went back to stock. Yeah woohoo the sound is cool,but ur car will run like crap. Stay with ur stock and get a Cobb Sf intake if u want noise.
cpz1987 is offline   Reply With Quote
Old 10-06-2012, 12:16 AM   #8
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
All of you talking about 'get an intake' are leaving out the main component in that suggestion -
GET A TUNE FOR IT.
I agree on 'No' on the BOV, get an intake for some noise, but get a tune as well. (IT IS CRITICAL TO GET PROPER TUNES FOR ANY MODIFICATIONS TO THESE CARS WITH A FEW MINOR EXCEPTIONS) Then since you're doing all that, you may as well just get a downpipe and tune for all of that and be done with it.
Throwing a BOV on there will just cause you problems.
Napalm3nema is offline   Reply With Quote
Old 10-06-2012, 02:20 AM   #9
DONx3
Member#: 214050
2007 WRX
World Rally Blue
BOV and EWG should be priorities!
Just Kidding!
DONx3 is offline   Reply With Quote
Old 10-06-2012, 03:50 AM   #10
neo8222
Member#: 311321
2002 WRX STI
Until you boost over 20PSI stock valve is good to go. One of these days when I can stop buying parts for the car for a few months I would like to get a aftermarket BPV that can hold the boost I'm running, but for now I'm stuck with my BOV. Fair warning, buying upgrades gets addictive. A "simple turbo swap" for me turned into a major mod.
neo8222 is offline   Reply With Quote
Old 10-06-2012, 09:26 AM   #11
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
For any Subaru with a metal bpv, you can do a simple 5 cent modification that stops it from failing. 20 psi is low for the metal ones to fail though.
The plastic ones on the 08+ WRX's can be junk, but others have held just fine.
Old 10-06-2012, 11:22 AM   #12
Barnold
Member#: 318142
2012 WRX
Dude, you guys are retarded. a BOV is the ONLY way to go.... jeez.... it makes a pshhhh sound and everything. you guys know the pshhh makes your car faster right? like when civics rev at you , you just make your car go pshhh! its just like sayin "pshhh your car aint ****, i got NOZ man. quarter mile at a time, thats how i live my life."
For real tho, BOVs get annoying as **** after 10 shifts...... dont do it unless its necessary man.
Barnold is offline   Reply With Quote
Old 10-06-2012, 05:42 PM   #13
STi410
Member#: 158800
2010 STi
please please please do yourself a favor and save that money and do not buy a BOV until you actually need one.
STi410 is offline   Reply With Quote
Old 10-06-2012, 06:17 PM   #14
cvillesti
Member#: 286843
welcome to nasioc haha. the subaru is designed with a pull through MAF and a bypass valve..not a blow off valve. so the way the system works is that when the throttle plate closes the valve opens and diverts the air back into the intake. it does this because the air is "metered" and your MAF has accounted for the air already. If you put a BOV you will be releasing this "metered" air and your car will run rich every time you let of the throttle. Rarely will you need to change the valve until you have quite a few modifications. If you get an intake (with a tune of course) you will hear the BPV and it will give you that sound you are looking for..i have the perrin BPV and its quite loud actually. the only time you would want to use a BOV in a subaru set up is if you change to a Blow through MAF set up and the BOV is pre-maf. I suggest that you take the money you were going to sink into a BOV and get a Cobb intake w/ an access port and do stage 1+. you will hear the turbo spool up and the bpv. the other thing you can do which requires no money is to remove the intake silencer from your stock air box, you will hear a little bit of the turbo and bpv that way also. hope this helps, happy modding!
cvillesti is offline   Reply With Quote
Old 10-06-2012, 07:05 PM   #15
Barnold
Member#: 318142
2012 WRX
^ not trying to come across rude, just a friendly correction. There is no intake silencer on the 2011 WRX i think it stopped in 08?
Old 10-06-2012, 10:02 PM   #16
swpshgnwgn
Member#: 150494
11 WRX
SWP Torqued Stg II
Interesting. I know when I took mine off on my 07 the turbo was loud as hell compared to stock. The 2011 that I have now is louder than my stock 07, but not nearly as loud as the 07 without the silencer. That was definitely a fun little mod
swpshgnwgn is offline   Reply With Quote
Old 10-06-2012, 11:04 PM   #17
cvillesti
Member#: 286843
No problem..I have an sti, don't have a lot of experience with the wrx..I guess I just assumed
Old 10-07-2012, 09:24 AM   #18
Barnold
Member#: 318142
2012 WRX
It's the same between the STI and WRX, no intake silencer
Old 10-07-2012, 01:48 PM   #19
cvillesti
Member#: 286843
I had one in my 2010 sti.
Old 10-07-2012, 01:53 PM   #20
cvillesti
Member#: 286843
I had one in my 2010 sti. I guess they have redesigned the intake.
Old 10-07-2012, 02:06 PM   #21
NYC5
Member#: 278891
11' WRX
I just bought an 11' wrx and it has a turboxs bov, i want the stock one back on. That "tsssss" sound gets annoying very quick.
NYC5 is offline   Reply With Quote
Old 10-07-2012, 03:28 PM   #22
Barnold
Member#: 318142
2012 WRX
I stand corrected 08+ wrx does NOT have an intake silencer, but the 08+ sti does.
Old 10-07-2012, 05:42 PM   #23
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
I can confirm that my '12 WRX did not have one.
Old 10-07-2012, 10:23 PM   #24
Epsubie
Member#: 300905
2011 Wrx limited
Satin white pearl
Instead of learning about my wrx I rushed and bought a bov then a week later learned about nasioc and read about this. Don't buy a bov , buy something else. Alot of these people are right even if they tell u in a dbag way lol
Epsubie is offline   Reply With Quote
Old 10-07-2012, 10:39 PM   #25
Member#: 51961
2005 STi
2012 WRX
LOL
Yes, we can be dicks sometimes. It mostly comes from seeing two things:
1) the same exact thread posted literally every other day
2) newbies asking for advice, ignoring it COMPLETELY, then complaining that their car runs like ****
It doesn't take a lot of this before we start to lose our minds. I try to take a break from the Newbie forum whenever this happens to me, but sometimes I forget, and sometimes other people forget too, and you end up with completely over-reactive psychopath answers to relatively simply questions. It helps to have a thick skin here. If you can get past the bull****tery, there is an absolute goldmine of knowledge on this forum. As much as I know, I'm still in awe of the knowledge of many other members here.
