Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 10-31-2012, 10:18 PM   #1
silverboost0303
Member#: 83266
2011 WRX Sedan
Default Need for an aftermarket bpv at stage 2?
I already have the flame suit on so I'm prepared lol. Can't really find anything on my specific question. My question is, would an aftermarket bypass valves such as the COBB XLE or GFB benefit my vehicle in terms of holding boost better/longer than the oem piece? Let it be known I'd run the bpv full recirculating. As stated I am full stage 2, protuned holding 18.5 psi consistently, and sometimes spiking around 20. I also (flame on) want a different sound than the stock bpv provides with the Cobb sf intake. Any info regarding this, or if some of you are running the same setup I'd love to hear about it
silverboost0303 is offline   Reply With Quote
Old 10-31-2012, 10:21 PM   #2
HinshawWRX
n00b Moderator
Member#: 140114
06 18G Semi Built
SGM WRX
The sound difference will come more from venting to the air then just changing out the BPV. And if your BPV is holding boost, which it appears to be doing, there is no NEED to change it. If it were to be failing, then you would NEED to change it.
Old 10-31-2012, 10:36 PM   #3
drewvdw
Member#: 255776
2010 LR WRX
MPS and PAR powered.
Benefit, no, precaution, yeah. It isn't something you need to worry about now, but don't be surprised if it begins to fail. The plastic ones are really crappy.
Old 10-31-2012, 10:49 PM   #4
silverboost0303
Member#: 83266
2011 WRX Sedan
I plan on adding injectors, a fuel pump, and a process west ic in the spring. I'm assuming I'd be pushing slightly higher boost at that point. I posted this because I'm looking down the road and would like to plan accordingly.
Precaution for the future. Exactly my thoughts. Thanks for the input guys.
Old 10-31-2012, 11:02 PM   #5
WRXSteye20008
Member#: 175565
2005 STI CGM
Built 351whp/368tq
Higher horse power does not always mean higher boost**
I am at 21psi and spike sometimes around 23 when it's cool with 18gXT, Spearco TMIC, Perrin big MAF intake, DW850cc injectors, Tail 38mm EWG, WB 255 Fuel pump, and the list goes on holding fine with the stock bpv, well it is crushed a little but, it holds pressure fine at 346awhp/378tq, oh yeah this is on a car with 123,890 miles.
WRXSteye20008 is offline   Reply With Quote
Old 10-31-2012, 11:05 PM   #6
BigRob74
Member#: 305107
2012 wrx
satin white pearl
i dont think yours is plastic
BigRob74 is offline   Reply With Quote
Old 10-31-2012, 11:25 PM   #7
silverboost0303
Member#: 83266
2011 WRX Sedan
Yeah it isn't plastic because he was able to crush it. I understand higher hp doesn't mean higher boost. I'm pretty positive though when I go for a retune it'll be raised. I'm just basically looking for people with the same set up, same generation, and I want to know if its a smart investment for the future.
Old 10-31-2012, 11:02 PM   #8
BigRob74
Member#: 305107
2012 wrx
satin white pearl
the forge one seem to be recommended, mines not leaking yet, 19psi. lets see how long it lasts..
Old 11-01-2012, 01:39 PM   #9
dangyo
Member#: 289786
2011 WRX Hatch
it's plastic on the wrx. that's why everyone upgrades once they're stage 2/plus. i highly recommend the forge cause it's a quality product and priced the best. i also have the same exact set up now and plan on doing pw ic & ebcs next then injectors/fp. it sounds perfect to me.
dangyo is offline   Reply With Quote
Old 11-01-2012, 03:30 PM   #10
SeeeeeYa
Member#: 129681
2014 FXT Touring
Not "everyone."
http://forums.nasioc.com/forums/showthread.php?t=454965
YMMV, but this has served me and MANY other for many years.
Forge is good if you need AM, but it is no better, just costs more and provides a talking point.
SeeeeeYa is offline   Reply With Quote
Old 11-01-2012, 04:38 PM   #11
silverboost0303
Member#: 83266
2011 WRX Sedan
Adding injectors and a fuel pump doesn't exactly add power/boost. Even with a retune you might only sqeak out a few more ponies. Don't get me wrong, precatutionary steps are great. And in context now, with plans to move forward it is NOT a bad step to take.
It's not. STI's have always had metal.
You know who would be the BEST person to ask if this is a good mod? Your tuner.
Dude lol, I understand about those modifications not adding a boat load of power. My main concern was the strength and durability of the oem bpv because I'm getting up there. And I would ask my tuner, but he passed away RIP Chris....
Thanks bro I might just look into the forge. It's slightly cheaper than what I'm looking at, but that really isn't a focal point of mine. I had a forge bpv on my 03 GTI. Sounded pretty good.
Originally Posted by SeeeeeYa
Not "everyone."
Lol I gotcha. Welp, decisions decisions lol.
Old 11-01-2012, 09:00 PM   #12
silverboost0303
Member#: 83266
2011 WRX Sedan
Anybody hear good things about the turbo smart dual port?
Old 11-01-2012, 09:12 PM   #13
drewvdw
Member#: 255776
2010 LR WRX
Never heard anything about them, I'm running the Forge unit. Haven't had a probem with it since I got it.
Old 11-01-2012, 10:10 PM   #14
silverboost0303
Member#: 83266
2011 WRX Sedan
That might be what I go with.
Message Board Statistics All times are GMT -4. The time now is 04:50 AM.
