11-05-2012, 10:30 AM | #1 |
Member#: 331145
Brand New Timing belt- check out pics
Threw a rod bearing and tore the engine down over the weekend to rebuild it. I bought the car only 5,000 miles ago and the dealership showed me the work log of replacing the timing belt and components as part of the pre-sale repairs.
What would cause this; as it ruined a brand new water pump pulley and all the other pulleys. (checked all the pulley's and none of them were bound up) Should I go after the dealership since in my opinion it looks like they effed this up! If it wouldn't have thrown the rod bearing I would be looking at costs of complete head and engine build! |
11-05-2012, 12:48 PM | #2 |
Member#: 290592
South East
Vehicle:15 Outback, 15 WRX 6MT CWP |
Abso-freakin-lutely go after the dealership. You can see exactly what they did and it's an amateur mistake.
11-06-2012, 06:46 AM | #3 | |
Member#: 165749
11-06-2012, 10:17 AM | #4 |
Member#: 34361
Vehicle:04.7 STI WRB IG @got2boostit2 |
Crank pulley guide set too close to the belt. In other words the timing belt guide was not set to the proper clearance.
11-06-2012, 01:28 PM | #5 | |
Member#: 337170
Vehicle:2003 wrx silver |
+1 on that. take it back to the dealer and demand assistance. ive had them do $1,000 of work to my truck even when the extended warranty was out (by only 15 miles) and costed me a mere $100 including rental |
11-06-2012, 03:56 PM | #6 |
Member#: 25194
RMIC
Vehicle:2008 Forester XT 5mt Dark Gray |
casaus19 - From the photos I'm left with a question. Was the tolerance from the crank sprocket guide to the belt the thickness of 1-2 business cards? This is in assumption all of the gunk was washed off to take a good measurement. There is a slight chance the tensioner is failing, or has failed. I saw this on a motor once before and the damage was pretty similar except the idlers' bearings were worn out too. This too was with a new timing kit. It turns out the tensioner failed and allowed the belt to have a slight amount of slack, which then allowed the belt to slip over the idlers and burn their bearings in the process. More thoughts on the tensioner, if the install tech had to compress the piston back into the tensioner then there is a chance it was damaged in the process.
Since the motor is removed from the car and torn down I would push for a replacement belt as well as new tensioner, and all idlers. They may hard ball you a bit since the motor has been removed, but it is worth a shot. Best of luck with the rebuild as well as the dealership. Stephen Clark IA Performance www.iaperformance.com www.facebook.com/iaperformance |
11-06-2012, 07:06 PM | #7 |
Member#: 217563
South East
Vehicle:2006 Sti 12.68 @ 108 321WHP 422WTQ dynojet SAE |
Did you find bad rod bearing, cause bad tensor will cause noise very similar to rod knock.
11-08-2012, 10:30 AM | #8 |
Member#: 331145
I did not measure the clearance between belt guide and belt. All the pulleys and tensioner were replaced by the dealership.
And I did call the dealership. Their run around is this. the work was done prior to me buying the car as part of the pre-sale repairs; and since They have been bought out by a new company they will not warrantee the work. They tell me there is nothing they can do since they are not waranteeing the old business' clientele. yes a rod bearing did fail, lost oil pressure and developed a knock. |
11-09-2012, 10:27 PM | #9 | |
Member#: 118086
Vehicle:2003 WRX WRB |
11-12-2012, 10:57 AM | #10 |
Member#: 331145
So I mentioned the words Better Business Bureau complaint, and the dealership said email them pics. A new dealership shouldn't want a negative better business complaint against them for being new. They should be lucky I am only going after them for 450 in parts with no labor vs 7k plus when that timing belt would have broken and killed the entire eng.
11-14-2012, 04:20 PM | #11 |
Member#: 118086
Where is this dealer Again?
11-14-2012, 06:40 PM | #12 |
Member#: 290592
South East
Glad you went after them- hope it ends well.
11-23-2012, 10:12 AM | #13 |
Member#: 149262
Vehicle:03WR rallycarFXTleg PrimerGrey |
Wow those guys are imbeciles.
11-27-2012, 09:07 AM | #14 |
Sammo Hung
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
looks like factory belt guides where too close to the timing belt.
the gates is thicker than factory belt too. |
