Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 11-12-2012, 01:15 AM   #1
Ebranch
Member#: 328457
2012 Impreza WRX
Dark Gray Metallic
Hey guys
I'm in the market for an aftermarket IC and I haven't seen much feedback on the Perrin.
-PW is amazing, but pricey.
-Spearco is oversized and has quality issues?
-never enjoyed the lag from front mounts.
I have the kit to bulletproof the factory piece which should be enough for my "needs", but I love my Perrin exhaust and everything else I've seen is top notch. Just curious...
Thanks,
Eric
Ebranch is offline   Reply With Quote
Old 11-12-2012, 03:41 AM   #2
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Ya I was recently in the market for a bigger top mount, trying to avoid a fmic. The ow is the way to go its cheaper than most front mounts and just the quality and fitment will be worth the price. For me this was the only option all the others seemed to get bad reviews. I desired to stick with the stock top mount tho and keep my power goal below 350 so I don't actually have experience with any of the aftermarket tmics. But from research the pw is the way to go
Coreycarlile911 is offline   Reply With Quote
Old 11-12-2012, 06:10 AM   #3
GrumpyPitbull
Member#: 313311
2012 WRX 5 Door
Plasma Blue
Originally Posted by Ebranch View Post
Hey guys
Thanks,
Eric
The Perrin is good quality, but will still cost you around 700 bucks. As you seem to already know, the PW is the way to go for a TMIC.
If your penny pinching the Perrin is a good option .... but IMO, why not just go with the best available and be done?
Old 11-12-2012, 06:27 AM   #4
Dat8687
Member#: 243261
2004 WRX
Java black pearl
I have the Process west... really nice.. However an alternate option would be the ETS top mount.
Im happy with the process west
Dat8687 is offline   Reply With Quote
Old 11-12-2012, 06:32 AM   #5
Ebranch
Member#: 328457
2012 Impreza WRX
Dark Gray Metallic
I haven't seen the ETS for sale anywhere. I had one on my MS6 before I went front mount and loved it. I'll do some more looking around today
Old 11-12-2012, 07:04 AM   #6
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
I remember seeing somewhere that the Perrin has fitment issues. More specifically hitting the master cylinder.
Also, I believe ETS only has IC's for the STI for 08-13.
Save your pennies, go with the PW.
DurtyB is offline   Reply With Quote
Old 11-12-2012, 10:45 AM   #7
xluben
Member#: 261612
2011 WRX 5 Door
NF Performance Stage 1
Correct, the Perrin is a real tight fit and it can rub on the bottom side of the core.
Old 11-12-2012, 09:39 AM   #8
Wrexflex
Member#: 326301
2012 wrx sedan-stg2+
red
I'm in the same boat and have done much research on this, if you're going to spend $700on the Perrin, why not just spend $800+ on the PW? I've been quoted the PW shipped for somewhere in the 8-900 range so I would just do it right and not risk it and put in a cpl extra hours of work for the PW.
Wrexflex is offline   Reply With Quote
Old 11-12-2012, 10:26 AM   #9
1QUIKV6
Member#: 9427
2006 WRX STi
ETS makes em for earlier cars too. I have one on my 06. Very happy with it. Does pretty good for a TMIC.
1QUIKV6 is offline   Reply With Quote
Old 11-12-2012, 11:06 AM   #10
Ebranch
Member#: 328457
2012 Impreza WRX
Dark Gray Metallic
Come to think of it, I have seen a photo of a used Perrin TMIC that had fin damage on the bottom side.
Hopefully not shooting myself in the foot.... there is a slightly used Spearco unit for sale here that I've been entertaining, but I've only read complaints about the whistling and the massive size. That got me thinking about the Perrin. My car is a DD and I don't have any immediate intentions of trying to make a bajillion HP. It bothers me that after an 18 minute highway commute, I pull into Starbucks and can see heat coming out of my hood scoop. I may be better served by getting a turbo and dp blanket and doing the bulletproof mod.
Old 11-12-2012, 11:36 AM   #11
Scuby04STi
Member#: 328635
2004 STi
Rally Blue
I would always say blanket that turbo, easy and a MASSIVE change in engine bay temp from every heat gun video of them. As far as the top mount, before I switched my stock out to a Perrin front I went and fixed the gaps that are between the stock top mount and the scoop as well as made a head protector to deflect the heat from rising into it. that made a significant difference. Not sure the flow rates on them all but having a good seal there and protecting it from heat in my opinion are the key and those are both easy DIY projects that cost next to nothing, think my total was $50-80 and that got enough heat blanketing to make a turbo blanket as well.
Took it off a wile ago and donated it to my buddies budget build so it looks nothing like it did (non subi build) otherwise I would toss up a pic.
Scuby04STi is offline   Reply With Quote
Old 11-12-2012, 11:24 AM   #12
scoobySTi06
Member#: 334064
The ets tmic is for sale on rallysportdirect.com for anyone who was wondering where to get them. Seems like a pretty good alternative to the pw.
scoobySTi06 is online now   Reply With Quote
Old 11-12-2012, 06:03 PM   #13
BigRob74
Member#: 305107
2012 wrx/TP Stage 2
satin white pearl
as stated above, they only make it for the 08-13 sti..
edit, there is also an AVO one, not sure about how good that one fits. im just gonna get an ets fmic when its time to upgrade..
BigRob74 is online now   Reply With Quote
Old 11-12-2012, 07:13 PM   #14
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
It would be great if ETS made TMIC for your platform (it is in the works from what I can see on FB). Their work is fantastic and is what I am running on my STi.
A bonus of the ProcessWest from what I know is that it will allow you to run STi style turbos without much more work which opens the door to many more turbos. But they are $$$.
tazswing is offline   Reply With Quote
Old 11-12-2012, 08:37 PM   #15
BigRob74
Member#: 305107
2012 wrx/TP Stage 2
satin white pearl
i asked them about it a few weeks ago and they said no, is this recent? i didnt see anything on their fb..
Old 11-17-2012, 10:04 AM   #16
theotherguy
Member#: 191514
'05 FXT
Originally Posted by BigRob74 View Post
OP has a 2012 WRX, there is no ETS TMIC for it, so i am not mistaken. and why would someone post a link to an 04-07 when the OP doesnt have that model?
Because you said...
ETS is a great company, just wanted to make sure that it was known that they make intercoolers for other years too...
It's not that big of a deal.
theotherguy is offline   Reply With Quote
Old 11-12-2012, 11:31 AM   #17
GrumpyPitbull
Member#: 313311
2012 WRX 5 Door
Plasma Blue
I would definitely stay away from the spearco. It is huge ... So huge that it hangs over the turbo and heatsoaks like crazy.
Since your undecided, just do what you mentioned and think it over some while you research ... Can never go wrong with that.
Old 11-12-2012, 04:58 PM   #18
omega145
Member#: 283017
I recently had the Perrin TMIC installed, $720 for the part from the shop and about $80 in labor. Nice aftermarket intercooler for the price and was nice along with the other mods, intake/exhaust/bov.
omega145 is offline   Reply With Quote
Old 11-12-2012, 05:33 PM   #19
fenderpicks
Member#: 287694
When i had my perrin, i struggled for like days to get it fit, until i was like screw this junk and sold it and bought the PW
idk why the perrin wasnt fitting.
All i know is it is BIG and it probably required u to put it in at a certain angle or something.
I never figured out why it didnt fit.... it was just either touching the throttle hose and not the turbo
oR touches the turbo and dont touch the hose lol....
fenderpicks is offline   Reply With Quote
Old 11-13-2012, 06:34 PM   #20
theotherguy
Member#: 191514
'05 FXT
Old 11-13-2012, 07:03 PM   #21
BigRob74
Member#: 305107
2012 wrx/TP Stage 2
satin white pearl
Originally Posted by theotherguy View Post
and you posted this why>? wrong car, wrong tmic and wrong year. thanks for playing
Old 11-13-2012, 07:37 PM   #22
424wrx
Member#: 171948
08 wrx prem sedan
vf52 swap. bilstein susp
ive had my perrin for about 3 years at least. only issue i had was it hitting the slave cylinder. perrin made me a spacer for the turbo flange. its all good now. underhood temps are real nice with the addition of my ptp turbo blanket. that works very well. if i had to buy again, i would buy the process west setup. i just like that better and the hood splitter is a nice touch.
Old 11-13-2012, 08:53 PM   #23
Ebranch
Member#: 328457
2012 Impreza WRX
Dark Gray Metallic
Haha... I bit the bullet yesterday and bought the ptp blanket and dei tape. Did my spt heatshieldmafter work today.
http://imageshack.us/f/94/imageiho.jpg/
Old 11-15-2012, 11:54 AM   #24
thisisntjared
Member#: 177891
06 wrx wagon
child seat/tow hitch cgm
easy yoda...
thisisntjared is online now   Reply With Quote
Old 11-17-2012, 07:44 AM   #25
BigRob74
Member#: 305107
2012 wrx/TP Stage 2
satin white pearl
Your the one who said they only made it for the 08-13 just proving that you were mistaken. So why are you now giving a response like this? Simply he is just showing that it does exist for the 04-07s.
Originally Posted by thisisntjared View Post
easy yoda...
Message Board Statistics All times are GMT -4. The time now is 12:28 PM.
