Old 11-12-2012, 01:41 PM   #1
GTS Jeff
Member#: 120262
09 WRX
Lightning Red
Default Most concave fitment of Rota Grid??
I'm looking for the maximum concavity possible out of a set of Rota Grids with no clearance/rubbing issues.
I have an 09 WRX sedan at stock ride height. I want to keep it at 17" with stock tire diameter.
So I'm wondering what width and offset to order...thanks.
GTS Jeff is offline   Reply With Quote
Old 11-12-2012, 01:55 PM   #2
sc00by4life
Member#: 97135
all 9" grids have the same face.....
all 9.5" grids have the same face.....
the 17x9 +42 is going to be the easiest for you to fit, but you'll still need to roll fenders at the least.
Old 11-12-2012, 09:52 PM   #3
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
If he goes with the 17x9 +42...
He'll only need to roll the rears. Maybe not even if he stays at stock ride height. He said he wants to stay with stock tire size too. 225/45/17 will stretch a good amount on a 9" rim
I ran/run 17x9 +44 Work CR-Kai with 245/40/17 tires. Lowered about an inch on epic springs, and then again on RCE blacks, I did not have to roll any fenders. It was VERY close but I did not have to roll for fitment and nothing rubbed.
However, after I installed my white line rear subframe and differential bushings (solid poly, not inserts) it started to very slightly rub in the rear so I had them rolled.
Hope this helps.
gsrcrxsi is offline   Reply With Quote
Old 11-12-2012, 02:00 PM   #4
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
19x10 +10 is the best....ya know ya want 'em
Old 11-12-2012, 02:34 PM   #5
hakira
Member#: 74211
SSM WRX 4DR
There is none
hakira is offline   Reply With Quote
Old 11-12-2012, 10:24 PM   #6
GTS Jeff
Member#: 120262
09 WRX
Lightning Red
Sounds like I should be going for 17x8...don't want to roll fenders either.
Old 11-13-2012, 12:20 AM   #7
Uncle Scotty
OK buy Nates beans
say it aint so.....
Old 11-13-2012, 01:40 AM   #8
GTS Jeff
Member#: 120262
09 WRX
Lightning Red
What's the big deal?
Old 11-13-2012, 01:46 AM   #9
Uncle Scotty
OK buy Nates beans
oh man......you did the right thing.....
THAT is the big deal
