Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Old 11-17-2012, 03:09 PM   #1
Rizzo314
Member#: 42215
2002 WRX being built
and going for 10s :evil:
Default Will 5mt Axle Stubs work in a 6mt?
I have searched for the answer to this, but I have not found a post or thread dealing directly with my question/issue.
I have a 2002 WRX with a 5mt. The front axle ends are female, mating to the trans with male axle stubs.
I just grenaded 3rd gear and am going to swap in a 6mt.
The 6mt I am looking to get is an 05 with male axle ends and the trans is female.
I know I can get 38415AA110 (04 STi axle stubs) to essentially convert the trans to an 04 and allow me to use my female axles, but since I already have a 5mt with axle stubs can I just remove those stubs and use them in the 6mt?
The only issue I can see is that I would need to install the stubs while the trans is open since they use a snap ring (that must be accessed from inside the diff) as opposed to just sliding in with a circlip. I will be replacing the synchros and adding Spec B gears. So the inside of the diff will be accessible to install the snap rings for the 5mt axle stubs.
This should work, but am I missing something?
Rizzo314 is offline   Reply With Quote
Old 11-17-2012, 03:39 PM   #2
lappit
Member#: 283660
07 wrx
Why not just do it right rather than mess with everything. I mean there not cheap cars id do everything how its made to work
lappit is offline   Reply With Quote
Old 11-17-2012, 04:24 PM   #3
Rizzo314
Member#: 42215
Originally Posted by lappit View Post
Why not just do it right rather than mess with everything. I mean they're not cheap cars id do everything how its made to work
Whose to say one way is right compared to the other?
The only reason people opt to go with the 04 STi stubs is because they can just push them in without needing to take apart the transmission or rob them from their stock transmission (which requires taking it apart as well).
I have a broken 5 speed with stubs and I will be taking my 6 speed apart. I see no reason not to use my stubs if they will work.
Your response did nothing but add 1 to your post count.
Old 11-18-2012, 09:53 AM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I checked this out with part numbers with the dealer. Came out to be the same part number.
I'll have to check if it was the auto or was it the 5spd WRX.
Old 11-18-2012, 10:19 AM   #5
Rizzo314
Member#: 42215
Thanks, let me know what you come up with.
If they are the same, it's possible I could just get circlips to replace the snap rings and be able to just slide them in and out at my leisure.
Old 11-18-2012, 01:14 PM   #6
Rizzo314
Member#: 42215
According to this http://opposedforces.com/parts/impre...llustration_1/
The 5mt stubs are 38415AA100, as opposed to 110. Maybe this has something to do with the groove for the circlip?
The 4eat stubs seem to be the same though and this lists them as 38415AA110.
Old 11-18-2012, 09:57 PM   #7
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Yes the auto!
Old 11-19-2012, 12:24 AM   #8
Serkan
Member#: 180514
2004 Sti
the 5mt stubs and 6mt stubs are different. Yo won't be able to secure the 5mt stub in 6mt. The groove and length of the studs are different.
You need to order 38415AA110
Serkan is offline   Reply With Quote
Old 11-19-2012, 01:34 AM   #9
Ioku
Member#: 164864
95 Impreza coupe
Yes, in short you cant use snap ring stubs in place of circlip stubs and no you can not put the circlips into the snap ring stubs.
Ioku is offline   Reply With Quote
