Old 12-02-2012, 07:20 PM   #1
Fbmpedalpusher
Member#: 319722
04 sti
Blue/gold
Have a Nice Day? 04 ej257 motor goes kablamo
Ok so i bought an 04 sti thats knocking like the police. Paid 4000$. Many mods and upgrades. The story is dude blew it up and had a new short block put in by subaru and 4 days later its knocking. Local shop tore down for me to reveal spun main ( obviously ) also shavings throughout the whole thing (bottom end, and heads). So i bought a brand new bottom end a good used set of heads an oil pump and a 20g turbo(its what it had). So basically id like a list of other things i may need, things i shouldnt reuse and precautions to take before proceeding. Thanks.
Fbmpedalpusher is offline   Reply With Quote
Old 12-02-2012, 08:52 PM   #2
GruppeOne
Member#: 278705
04 STi
Change the oil cooler. Its not too expensive and is almost impossible to clean out.
GruppeOne is offline   Reply With Quote
Old 12-02-2012, 09:40 PM   #3
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Get a tune.
Old 12-02-2012, 10:21 PM   #4
Fbmpedalpusher
Member#: 319722
04 sti
Blue/gold
Point taken on the cooler. Tunes down the road gotta get her goin first but yes for sure
Old 12-02-2012, 11:08 PM   #5
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
I don't think you understand...If you blow 2 motors right after another, you better make sure the tune isn't causing problems.
Old 12-03-2012, 07:50 AM   #6
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
Congrats, regardless. $4k is a great deal.
Zackbo is offline   Reply With Quote
Old 12-03-2012, 08:35 AM   #7
04ScoobyWtf
Member#: 287974
Tune ASAP if you got a big turbo you got big injectors and Im sure fuel is just washing your cylinders walls down. You'll be burning oil at the least if not have another engine failure
04ScoobyWtf is offline   Reply With Quote
Old 12-03-2012, 09:22 AM   #8
sexyyrex
Member#: 128022
2015 Mustang GT
alot of great advice in here.
at the very least, change the oil cooler, and check the calibration with some data logs.
sexyyrex is offline   Reply With Quote
Old 12-03-2012, 11:00 PM   #9
Fbmpedalpusher
Member#: 319722
04 sti
Blue/gold
Ok so i ordered the oil cooler today. I talked to the previous owner. He wasnt much help he purchased the car already modded out and tuned up from florida. When he purchased it, it had meth inject an upgraded turbo and many other things. It came with dyno sheets for 480hp. Idk why but he removed meth inject and swapped out the turbo. So i believe a tune is in order. Any reputable tuners in the upstate ny area or nearby?
Old 12-03-2012, 11:06 PM   #10
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Ding ding ding...Thars yer problem.
Old 12-04-2012, 10:50 AM   #11
tuzzio
Member#: 292532
05 STI
Tunetunetune
tuzzio is offline   Reply With Quote
Old 12-04-2012, 03:51 PM   #12
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Ray with turbotek tuning is awsome and out of the albany area if thats any help he also will etune as well.
nate_fisher is offline   Reply With Quote
Old 12-05-2012, 01:54 AM   #13
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
New oil pump and pick up while you are at it. Oil cooler, oil pump & pickup are a MUST! Many like to replace the oil pan too because bearing material gets stuck behind all the baffles and you can never get it 100% clean no matter how hard you try. A new pan is only $84 and I wont rebuild a engine without a new one if it had spun bearings. Also, make sure all the oil galley plugs are removed from the block and flushed out in a parts washer. Then flush them again, and again. Same goes for all engine bearing oil supply galleys. They all need to be spotless! If you dont remove the galley plugs and flush them, chances are there is some bearing material sitting in there just waiting to flow back into the system on first start up.
Old 12-05-2012, 07:23 PM   #14
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
this is really good info here,and someone who cares,good luck on your build!^^^^^^^^^^
EROCS04SBRUSTI is offline   Reply With Quote
Old 12-05-2012, 07:35 PM   #15
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
Do you know what injectors are in it?
If not, probably would make sense to send em out for a cleaning and flow testing. Your tuner will probably appreciate that as well.
Gfunk720 is offline   Reply With Quote
