Old 12-04-2012, 03:17 PM   #1
FLEX'N WRX
Member#: 163672
GV
Same color as veneers
Default Flexed WRX (GV) STi | Rallispec | BPT | RCE | Whiteline | WedsSport | 450awhp ...
TheAttack, RallySport Direct: http://theattack.rallysportdirect.co...-aka-flexn-wrx
Engine (Rallispec):
- Cosworth Forged Pistons 8.2:1cr
- Manley 4340 H-Beam Rods
- King Bearings (main & rod)
- Nitrided Crank
- ARP Head Studs
- Cosworth Headgaskets
Performance:
- KSTech 83mm Intake
- Perrin 3" Inlet
- Blouch Dom 1.5 XT-R: 10cm Turbine Housing
- Process West Top Mount Intercooler
- Forge Bypass Valve
- TGVs removed
- Walbro 460 Fuel Pump
- FiveO 1200cc Injectors
- Equal Length Header (wrapped)
- Grimmspeed Up Pipe (coated)
- Tial 44mm External Waste Gate
- Catless Down Pipe (DEI wrapped)
- Moroso Catch Cans
- Omni 4bar Map Sensor
- Grimmspeed 3-port Boost Control Solenoid
Accessory:
- Grimmspeed Ceramic Coated Heat Shield
- PTP Turbo Blanket
- COBB EWG Bracket
- Cosworth Air Pump Delete Plates
- STi Oil Cap
Driveline:
- 6 Speed
- Viscous Center LSD
- Exedy HDS1 Clutch
- Kartboy Short Throw Shifter
- Kartboy Front Shifter Bushings
- Kartboy Rear Shifter Bushing
- Kartboy Pitch Stop Mount
Suspension:
- Racecomp Engineering Tarmac II Coilovers: KW Variant 3s to RCE Spec | Springs: Front- Hyperco, Rear- Swift 400/400lb
- Vorshlag Camber Plates
- Whiteline Steering Rack Bushings
- Whiteline Roll Center/Bump Steer Correction Kit
- Whiteline Anti Lift Kit/Caster Correction Kit
- Whiteline Control Arm Bushings
- Whiteline Front Sway Bar 22mm
- Whiteline Rear Sway Bar 22mm
- Whiteline Rear Sway Bar Braces
Brakes:
- Brembo Gold Gran Turismo 4-Pot Calipers: Front
- Brembo Gold Gran Turismo 2-Pot Calipers: Rear
- Brembo Slotted Rotors
- Brembo Street Pads
- Goodridge Stainless Steel Lines
Exterior:
- STi Front Lip (extended ver.)
- STi Side Skirts
- STi Side Fender Badges
- STi Rear Fog Light
- STi Sport Muffler S206
- SPT Vortex Generator
- Gloss Black Roof
- Cusco Antenna
- LED Tail light Housing
- Headlight Amber: Black
- Subaru Emblems: Black
- 20% Tint
Interior:
- STi Push Start
- STi/Subaru Boost Gauge
- STi/Subaru Oil Temperature Gauge
- SMY Gauge Cluster
- JCS A-pillar Gauge Pod
- AEM UEGO Air/ Fuel Ratio Gauge
- STi Shift Knob (200g)
- AM Ice White Pearl Shift Knob (671g)
- WC Lathewerks Stainless Lockout Ring
- WC Lathewerks Copolymer Boot Collar
- Subaru AV Panel
- Pioneer AVH-X5500BHS
- Audio Control LC2i Line Output Converter
- Kicker BassStation 10” Sub
- Misc: Scosche AP holder, LED Lighting
Wheels/ Tires:
- WedsSport TC105N 18x9.5 +35 | Gunmetal
Dunlop Direzza ZII 265/35
- RAYS GramLights 57Xtreme 18x9.5 +40 | Semi-Gloss Black
Bridgestone Potenza RE-11 265/35
The OEM original Subaru/ STi parts are excellent quality
*The STi Side Skirts slip on, quality hardware, smooth and flawless appearance.
*The STi Front lip. 31mm extended compared to Vlimited. Same quality as skirts.
*The STi Rear Fog fits well and is beyond easy to install. Used as 4th brake light.
*The STi Oil Cap is nice, inlcudes allen for access to use a socket for removal.
*The STi Shift Knob is leather and weighs in at 200g
*The STi Push Start button is simply style and convenience
*The Subaru Boost and Oil Temp. gauges are a perfect match to the cluster, responsive, and accurate.
*The STi Sport Muffler/ S206 Exhaust. STi engraved on all (4) tips, 3.75" diameter. No competition… One fine specimen of exhaust.
Considering the route of modifications, in some ways the base trim offered a better starting platform than the WRX STi. Beginning with a base model allowed modification to stay unique. The decisions were made to incorporate what Subaru Tecnica International would to the WRX trim, at my discretion. The most difficult part to my modification plan, is balance. Being unique, without taking the car out of character is the task. That means being pragmatic, still creative enough to achieve an aesthetically pleasing and powerful car.
Modifying... The mind set is to take the car to the next level. That is achieved without losing the essence of the STi. The addition of throwback gold Brembo calipers, and acquisition of original STi parts transformed this WRX into a car not available from the factory. The performance aspects of the car exceed expectations. Minus a few factory items, the car incorporates most bolt-on modifications, relying on the Dom 1.5 XT-R and E85 to stay competitive.
__________________________________________________ ____________________________
Past Pics: Page 2 (Top), Post #17, #61(Past Power Level), #79-85, #150-60(Build)
FLEX'N WRX is offline   Reply With Quote
Old 12-04-2012, 03:18 PM   #2
FLEX'N WRX
Member#: 163672
GV
Photos@: POST 17 and 26
Old 12-04-2012, 03:33 PM   #3
FLEX'N WRX
Member#: 163672
GV
The Go:
Build Pics: Post 150-160
Previous VF52 and 1.5XT-R Power Levels: Post #61
http://forums.nasioc.com/forums/show...7&postcount=61
Old 12-04-2012, 11:06 PM   #4
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by FLEX'N WRX View Post
Power Output:
- 93oct: 314 awhp and 340 ft-lbs
- E85: 340 awhp and 370 ft-lbs
*DYNO SHEET
Each tune has reliability in mind. The original E85 pulls were 370/400 range and not too aggressive.
*Reference: Stock 2009 GTR 380/380 same dyno- http://forums.nasioc.com/forums/show...&highlight=gtr
You should try a 50-100mph pull sometime. I'd be interested in seeing how it stacks up.
http://forums.nasioc.com/forums/show....php?t=2349792
Old 12-04-2012, 11:42 PM   #5
FLEX'N WRX
Member#: 163672
GV
Old 12-05-2012, 07:32 AM   #6
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
That thread always entices me to get some top end flow going. My car handles its business well in that range for having the stocker.
Making a to do list:
- 50-100mph thread, when I can, I will
- Video/sound exhaust clips, ASAP
- Video gauge clips, ASAP
- Proper photo shoot, need a tripod and location, perhaps a real photographer
I missed the opportunity to complete photo ops with the items uninstalled. I'm going to snap more when the car is up in the air.
It would be fun to get our two cars together for a shoot sometime if you are ever in the Atlanta area (or if I am where ever you are). I know my way around a camera...and your car needs a rig shot.
rsutton1223 is offline   Reply With Quote
Old 12-13-2012, 12:24 AM   #7
J Holden
Member#: 340482
Loving the stance! Looks great
J Holden is offline   Reply With Quote
Old 12-14-2012, 02:01 PM   #8
Soulless
Member#: 263667
2002 WRX Sedan
Wrb
Well done.
Soulless is offline   Reply With Quote
Old 02-11-2014, 08:57 PM   #9
RubyTheScooby
Member#: 381172
09 Fozzy
Red
Super clean man!
RubyTheScooby is offline   Reply With Quote
Old 12-04-2012, 03:41 PM   #10
Engineer99
Member#: 310668
Car looks fantastic! Really like the stance, very functional looking. How is the ride quality on the RCE Tarmac II's?
Engineer99 is offline   Reply With Quote
Old 12-04-2012, 03:59 PM   #11
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
Win.....nuff said
INKMAN is offline   Reply With Quote
Old 12-04-2012, 03:41 PM   #12
mwichtendahl
Member#: 182944
2011 WRX Limited
Nice! Very clean
mwichtendahl is offline   Reply With Quote
Old 12-04-2012, 04:08 PM   #13
1VIPWRX
Member#: 107554
yellow
awesome
1VIPWRX is offline   Reply With Quote
Old 12-04-2012, 04:25 PM   #14
DDabs
Member#: 339686
2013 WRX Sedan
I love those wheels. Beautiful setup.
DDabs is offline   Reply With Quote
Old 12-04-2012, 04:44 PM   #15
Jive Turkey
Member#: 219492
about time you made a thread
Jive Turkey is offline   Reply With Quote
Old 12-04-2012, 05:38 PM   #16
mkvaron
Member#: 326317
2011 WRX hatch
SSM
Absolutely great build & the car looks amazing!!
How do you like the tarmac II's? And maybe I am misreading it, but what did you build up to KW variant 3 spec? Just the rears?
I am running the GTworx/Bilstein coilovers with RCE springs and I love it, but it lacks the adjustablity & am window shopping my next move haha
mkvaron is offline   Reply With Quote
Old 12-04-2012, 05:53 PM   #17
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
^ This!
Car looks great. Super clean. Love the wheels.
Old 12-04-2012, 06:07 PM   #18
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Very nice ride! all of the parts compliment each other very well
Mike
GrimmSpeed is offline   Reply With Quote
Old 12-04-2012, 07:29 PM   #19
2011mwgwrx
Member#: 300784
2011 WRX Limited
How does the STi S206 exhaust sound in comparison to the spt?
2011mwgwrx is offline   Reply With Quote
Old 12-04-2012, 07:57 PM   #20
low-n-slow
Member#: 313818
2002 wrx hybrid
Very sharp!
low-n-slow is offline   Reply With Quote
Old 12-04-2012, 08:01 PM   #21
felya589
Member#: 201073
2004 WRX STi
where did you get the s206 exhaust?
felya589 is offline   Reply With Quote
Old 12-05-2012, 11:14 AM   #22
thenick
Member#: 199580
i been hatin'
Hellas since 2012
Twice
thenick is offline   Reply With Quote
Old 12-05-2012, 12:07 PM   #23
FLEX'N WRX
Member#: 163672
GV
Originally Posted by thenick View Post
Twice
http://www.sti.jp/e/parts/catalogue/...4300ZR030.html
There's the direct link to the exhaust and entire assortment. PM me if you are seriously interested in getting anything.
Old 12-04-2012, 08:17 PM   #24
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
amazing build!!!!!!
bluemax189 is offline   Reply With Quote
Old 12-04-2012, 08:51 PM   #25
FLEX'N WRX
Member#: 163672
GV
thanks... Thread was due.
Tarmac 2s are a fantastic option. I do not DD, and may be switching to 500/500lb springs. They would be very tolerable for most under DD conditions. Pay attention to the road and don't put them through unnecessary abuse. They'll be smooth and responsive as ever on the, eh, tarmac.
The STi S206 exhaust does not sound like the SPT. The SPT(I have never owned, just heard) is throaty and hollowed sounding, where the STi has been refined to eliminate gurgling and produces a much more fluent tone/bass. Decibel level is similar to SPT, quieter aftermarket exhaust options.
POST EDIT TO CONTAIN OTHER PICTURES:
