Old 12-06-2012, 09:54 AM   #1
db97
Member#: 7140
2009 WRX
satin white pearl
Default went for an oil change, and distress ensued...
Took my 09 WRX to the dealership Monday for an oil change. I supplied them with the Mobil 1 Syn oil. They do the service, and I pick it up later that evening after they close (wife paid for the service and got the keys from them during the day). I drive it 12 miles home. The next day, I drive our minivan, and the WRX isn't driven. Yesterday, I drive the WRX to work, out to lunch, and then back home. On the way home, white smoke starts to come out of the engine and around the air scoop. I call up the dealer stating i'm seeing smoke coming out of my engine, and tell them i'm headed over there (this is around 5pm). While on the phone, the engine becomes very rough, then lethargic, then rough again...makes strange noises, and then basically explodes (I hear a loud banging noise), and the car dies...in the middle of the street. I restart it momentarily to get it over to the curb, but then dies again. AAA takes 5 hours to come, and then finally tows my car back to the dealership at 10pm. While there, I fill out the dropbox paperwork stating what happened, and then checked out the dipstick. It appears to be completely dry! I take pics using my camera phone, and video as well. I drive back to the dealership this morning, and talk to the service guy...he is apologetic, and acknowledges that there indeed is no oil on the dipstick. His exact words were, "Yeah...there's not a drop of oil on this dipstick" - ya think!!! Anyway, he says he needs to push the car back to the lift and find out what happened. Fast forward two hours. They call me back and tell me that the oil filter has a blown seal and oil leaked out?? He said there was oil in the engine, and that it was down 2 qts (so basically about 2.something quarts of oil remained). My question is this...I can already see them saying, "Ohh, we'll just put more oil in it and you'll be fine...blah blah blah" ...b/c I heard this loud bang...is my engine toast?
db97 is offline   Reply With Quote
Old 12-06-2012, 10:09 AM   #2
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
Well the upside is that a dealer did the service and they supplied the oem filter. Your 5yr 60k powertrain should still be intact, they probably will take care of you and I would focus your attention to the service manager and subaru of America at this time.
Old 12-06-2012, 10:11 AM   #3
guroove
Member#: 129833
2005 Forester XT
Obsidian Black Pearl
This sounds like BS from the dealer. I would guess that it was down more than 2 quarts. It's hard to say what the extent of the damage is, but one thing for sure is that putting the right amount of oil in is not going to fix this.
guroove is offline   Reply With Quote
Old 12-06-2012, 10:47 AM   #4
leecea
Member#: 37359
2003 WRX
Was there no oil pressure warning light?
It's very hard to imagine a scenario where you lose your oil, you get loud banging noises from the engine, it dies, but no damage is done. I hope they give you a new engine.
leecea is offline   Reply With Quote
Old 12-06-2012, 11:06 AM   #5
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
Subscribed to see how this turns out, local to you and was about to start using them instead of Neil Huffman since it is closer.
KOJAK-02-WRX is offline   Reply With Quote
Old 12-06-2012, 06:58 PM   #6
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
With a join date of 2009? Things that make you go Hmmmmmm...
G-Omaha is offline   Reply With Quote
Old 12-07-2012, 11:33 AM   #7
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
Huh? Why are you questioning me? Because I posted to subscribe? Was getting his opinion on Neil Huffman if Bachman was in deed bad.
Old 12-07-2012, 12:14 PM   #8
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
In my opinion, if you're down on power and you lost oil pressure, your turbo may be toast. Reset your ecu, take off the battery terminal and see if you get some power back. I would switch from mobile 1 oil to a different synthetic also. From here on out if you keep it, continue to get it serviced by subaru and look into an extended warranty if you decide to keep it. Maybe that way you can avoid any deniability on their part.
Old 12-06-2012, 11:21 AM   #9
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^^^^If you EVER see the oil light while your engine is running..............it is OVER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
At the 2.2 psi it takes for the light to come on......bearings will suffer if not fail completely.
Paidfor is offline   Reply With Quote
Old 12-06-2012, 12:08 PM   #10
db97
Member#: 7140
2009 WRX
satin white pearl
Default still waiting to hear back from them...
service guy Neal says they "have it up on the lift, took pictures of the blown seal, and may try to restart it" ????
i know from past experience (bought a 02 WRX from them), that they always throw up a big stink about having to pay for anything...even warranty work. all i know is they're saying the filter seal failed and that was the cause of the oil leak. labor and parts are covered under any service work...so if the filter failed, SOA is on the hook. i'm not sure what's taking so long right now...since i told them about the loud bang, i imagine they're gonna have to open up the engine to poke around. my car doesn't have an oil pressure gauge?? i see the engine temp gauge...is there an oil pressure light? when this all happened, the check engine light started to flash, and then came on. i don't recall seeing any other light. also, the service guy told me that there is a variable valve timing thing on the engine that if it senses low oil pressure, it shuts the engine down?? not sure if that makes any sense?? what i'm most afraid of was the loud bang noise. it sounded like a mini explosion??? i've taken my subies to them since 2002...never had any service issues like this whatsoever...neal did tell me they are a good dealer, and that they felt awful, and would make it right??? their definition of right and mine is probably two different things. ughhhhh!
Old 12-06-2012, 12:13 PM   #11
db97
Member#: 7140
2009 WRX
satin white pearl
Default as for Neil Huffman...
when i had my 2002 WRX, i bought the accessory gauge pod thing...and had them install it. those idiots ended up messing up the wiring somehow, and caused the interior dash dimmer switch to not work anymore...then said it wasn't them that broke it??? that's why i never have gone back to huffman for anything...my kingdom for a competent subaru dealership!!!
Old 12-06-2012, 12:53 PM   #12
db97
Member#: 7140
2009 WRX
satin white pearl
Default update
just got off the phone with the neal the service guy. he tells me that subaru engines have a failsafe system whereby if the engine oil pressure gets low, then the engine shuts itself off (something to do with the variable valve timing??). his service mgr sherry is talking to subaru engineers to confirm this. he goes on to say that the loud bang i heard was that vvt thing shutting down (??? ...not sure i believe that, but that's what he said). additionally, they put more oil back in the car and have driven it 20-30 miles...and it is running w/o issue. i asked them about what's gonna happen when say in a month or so, the engine breaks or something goes awry...he said 2 things...1) the failed SOA filter is fully documented, and SOA stands behind anything that could potentially go wrong in the future?? and 2) i still have the 5 yr/60k powertrain warranty...i'm at 48k right now. once they confirm the failsafe system did indeed save the engine, they would then release it back to me. now i don't know about all of this, but i guess i really have no choice...once i get it back and start driving again (if i feel anything out of the ordinary then back to the dealer i go)...i guess i better drive it harder from now to 60k miles??? this chain of events has been disheartening to say the least. i've never heard of an oil filter seal blowing???
Old 12-11-2012, 04:29 PM   #13
ringe
Member#: 49998
2007 WRX CT Stg 2
Sometimes (most times) the oil light won't come on till the oil is effectively gone.
Always best to check using the eye-0-meter.
ringe is offline   Reply With Quote
Old 12-11-2012, 04:59 PM   #14
swirljello
Member#: 334890
Man that was like an awesome movie with a terrible ending
swirljello is offline   Reply With Quote
Old 12-06-2012, 12:40 PM   #15
SpamBot
Member#: 287534
No offense intended, but don't you think you should have shut the engine off, called the dealer, and had the car towed back?
SpamBot is offline   Reply With Quote
Old 12-06-2012, 12:55 PM   #16
db97
Member#: 7140
2009 WRX
satin white pearl
i was about to...from the time the smoke started becoming more pronounced...until when the engine ceased to run was about 5 seconds...and i was on the phone with the dealer while this was happening. the guy said, "oh, that smoke is probably some oil spilled on the manifold that is burning...it should be okay"...then BAM...car dies.
Old 12-06-2012, 12:57 PM   #17
db97
Member#: 7140
2009 WRX
satin white pearl
plus the check engine light didn't come on until the engine shut off. that's why i didn't feel like it was super urgent to react b/c i have had oil spilled on a manifold and make smoke like that...in a previous car (honda).
Old 12-06-2012, 12:53 PM   #18
Paidfor
Member#: 267815
Be in awe
dont hate .)
VVT isnt gonna cause the engine to shut down.............maybe if the tbelt jumped several teeth......maybe. All that mumbo jumbo about VVT maybe being the cause is absolute BS!!
Old 12-06-2012, 12:56 PM   #19
Paidfor
Member#: 267815
Be in awe
dont hate .)
Id be tempted to drive the piss out of it.......hopefully run it low on oil enough to burn a couple of bearing up......top it off and call em for a tow. If they wanna play hardball and give you a compromised engine that has been starved for oil.........then they deserve to buy a new engine.
Period.
Old 12-06-2012, 01:03 PM   #20
db97
Member#: 7140
2009 WRX
satin white pearl
Period.
i've thought about the new engine thing...i called my insurance to file a potential claim against the dealer. she said if dealer ends up having to replace your engine, then they would most likely put a used/junk motor in it????? ...which is worse than what just happened to it (imo). she also said the insurance company would do the same (put a motor that is comparable to pre loss state)...since it wasn't brand new?? apparently in KY, a car dealer isn't obligated to put a new motor in a car that they destroyed or was responsible for?????? she said had i lived in IN (which is right across the river), than the consumer has that option...FREAKIN KY and their backward legislators!!!
Old 12-06-2012, 01:11 PM   #21
Knotsure
Member#: 41730
1415 Legacy/Forester
D.Grey/White
I think it would be really smart to call Subaru in this and get it all documented with them.
Knotsure is offline   Reply With Quote
Old 12-06-2012, 01:27 PM   #22
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
time to sell or trade and get a new car, why take the risk really
Old 12-06-2012, 01:40 PM   #23
db97
Member#: 7140
2009 WRX
satin white pearl
that is something i haven't even thought about...i could probably get decent trade in value (20k) for a new WRX.
Old 12-06-2012, 03:19 PM   #24
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
So you started a thread before even getting the first update from the service department dragging this dealership through the mud and titling your thread "Bachman Subaru killed my engine" for all of NASIOC to read. GOTTA LOVE IT!
If the engine is running fine it is not blown. If anything, I would demand leakdown and compression test results and go from there. If you have lost faith with the dealership then take it some where else and have the tests performed. If there is still wind in the hole then you're good to go.
Period.
Paidfor are you a trained subaru tech? I'm just wondering what makes you more qualified to tell the OP what has happend to his engine and what the dealership needs to do to make things right? Why do they need to replace his engine if the oil pressure light never came on and the dealership says it was only down a couple quarts? Did they PM you his compression and leakdown test results before calling the customer? Can you define your use of "compromise"? As in what components have the excessive wear and how are you coming to your conclusion? Did you hear the same noise the OP is stating to have heard prior to the car turning off? If it was not the AVCS (which I'm sure runs off of oil pressure which sounds like took a sudden drop) then what, in your expert opinon, was the noise?
Steve.804 is offline   Reply With Quote
Old 12-06-2012, 04:02 PM   #25
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
I agree with Paidfor ...if subaru takes my money to change my oil somehow fails at this simple task and my car dies due to lack of oil 2 days later i would want a new engine or at least them have to pay to test everything that needs to be tested to make sure it is in good shape. How fair is it to the OP if the car would have lasted 100k miles but at 63k miles he gets on it and it blows up due to past mistreatment from the dealer?
Shortpersonbk is offline   Reply With Quote
