Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 12-14-2012, 10:17 PM   #1
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Lightbulb Help me turbo my Outback
Hey all, I probably just need you to actually talk some sense into me.
I'm currently driving my '96 Outback from San Ramon to Hayward at least 3 times a week. I am a student and don't have much money to really work with but if things came together for cheap enough I would consider doing this.
My car is super reliable and gets decent mileage. I have done all my own maintenance and big jobs like clutches and headgaskets and whatnot. It currently has 265k miles and shows no real signs of wear. It doesn't eat oil etc.
Here's a short list of what I need. The goal would be no more than 5psi on stock everything.
Oh and budget would be $500 or less.
Turbo crossmember or modified stock
'06 wrx td04 (has 5psi wastegate?)
'06 wrx tmic/recirc valve
Exhaust
Intake bits
oil feed and drain
water feed and drain
I'm kicking myself right now for not keeping a vf10 I had and sold since that would work great here.
Not sure what I would do about exhaust since my car has single port headers. Maybe look for a set of subachad up and down-pipes.
I feel like I just got bit by the turbo bug again.
geronimo81 is offline   Reply With Quote
Old 12-14-2012, 10:53 PM   #2
slayer44wagon
Member#: 300834
03 wrx wagon
265k......
slayer44wagon is offline   Reply With Quote
Old 12-15-2012, 09:21 AM   #3
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Originally Posted by slayer44wagon View Post
265k......
What could possibly go wrong?
Old 12-16-2012, 09:16 PM   #4
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
seriously people.....who can hook me up with a tmic and help me solve my exhaust problem? This is an ej22 if it helps.
Anybody out there that can fabricate? I can pay but obviously not much.
Old 12-16-2012, 10:14 PM   #5
josedwrx
Member#: 199988
2002 wrb bugeye
vf39 12.3 @113
Idk about ur exhaust issue but i have my stock td04 and tmic just laying in my garage.
josedwrx is offline   Reply With Quote
Old 12-17-2012, 08:15 PM   #6
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
I am interested although I don't think your tmic will fit. I did find a deal on a slanty for $40 though.
What kind of shape is your td04 in and what mileage? I assume it is the pre-06?
Old 12-16-2012, 11:10 PM   #7
CatchMyDrift
Member#: 54523
You would make about the same amount of power if you just went with a high compression build (10.5:1 roughly). 5psi isn't much.
Here is what you need:
EJ251/3 (Phase 2) block + EJ25 head gasket
Your stock heads + Delta cams
That should put you in the 180-200 hp range with 200+ torque.
CatchMyDrift is offline   Reply With Quote
Old 12-17-2012, 08:14 PM   #8
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
hmmm. Another interesting thought. I think I would have to use the ej25d though because pistons on the phase II ej25 do protrude slightly from the deck. I have done quite a bit of reading on the high cr frankenmotors in the past but for some reason I don't like it.
In all honesty I would sooner swap a full ej25 in than do the frankenmotor.
Old 12-17-2012, 08:20 PM   #9
CatchMyDrift
Member#: 54523
The phase I EJ25D clears the deck, not the Phase II EJ251/3. Which is why I suggested that block instead of the D.
Old 12-18-2012, 12:22 AM   #10
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Ahhh, well that does make it a more attractive option since i don't have to rely on an old overheated 2.5. Still though, I just love turbos
Old 12-21-2012, 12:48 AM   #11
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Can anybody here weld? I was thinking maybe it would be possible to hack the flanges off my stock header and swap them onto a dual port header. I know it's not ideal but this is for a simple 5psi setup
Old 10-09-2013, 06:01 PM   #12
harrymaneuvers
Member#: 212088
This is EXACTLY what I did and I LOVE IT. I used Delta's Torque Grind and also swapped the 4EAT out for a 2010 5MT with 3.9 final drive with Exedy stage 1 organic clutch.
Tons of low end power.
harrymaneuvers is offline   Reply With Quote
Old 01-06-2013, 12:18 AM   #13
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I have a stock header for a turbo that would fit on the ej18 heads and I would give it to you if you build a turbo motor.
Old 01-06-2013, 10:33 PM   #14
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Thanks man, if I go with ej18 heads I don't think I will be turboing it. I might want the manifold though to see if I can use it and adapt it to my stock exhaust
Old 01-23-2013, 02:37 PM   #15
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
I decided to go turbo so I will be needing that header. I pm'd you.
Thanks again!
Old 01-17-2013, 04:43 PM   #16
adamohurd
Member#: 276227
I like this threadddddd
adamohurd is offline   Reply With Quote
Old 01-20-2013, 09:48 PM   #17
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Adam + Jereme = twin turbo wagons
Old 02-02-2013, 10:51 AM   #18
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I need you to get ahold of me today I am bringing that manifold down to your town.
Old 02-18-2013, 05:46 PM   #19
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
I am almost done acquiring parts. Here is my list:
'04 wrx hood scoop
'07 wrx TD04
'07 wrx TMIC
'05 STi BPV (with elbow and hose)
JC Sports UP
JC Sports DP
Tial 44mm EWG (for sale soon)
Mid-pipe
Total cost so far including shipping is $440 but I will be selling the EWG and getting the pipes patched up. I should maybe come out $100 ahead after that which means total cost would be $340 for everything so far. That leaves me $160 in my budget.
Car already has:
'02 wrx oil pump
'07 wrx fuel pump
Things left to do:
-Oil lines (will probably T into oil pressure sender)
-Water lines (will probably do the throttle body bypass and use this as feed and return) (If I find out this doesn't flow enough water I will T into heater core hoses)
-Buy gaskets for exhaust and turbo.
Old 02-18-2013, 06:39 PM   #20
BLITZKRG-RS
Member#: 1332
2004 STi
contact LIC Motorsports. Ask for Adam/Noah
BLITZKRG-RS is offline   Reply With Quote
Old 02-19-2013, 11:44 AM   #21
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
I will do that.
Old 03-07-2013, 02:13 PM   #22
mutydog
Member#: 319484
1998 OBS-T
black/grey
for my Obs turbo, i used a t off the oil pressure sender, and for the oil return, i bought another driver sides valve cover(that has the oil filler spout), and i welded a hose barb onto a piece of metal that screws directly where the oil filler spout screws into. it worked perfect! make sure you use hydrolic hose for the oil return, or else the rubber will desintegrate! for the cooling, i didnt even hook it up coolant lines to the turbo....i might someday, but egt's stay below 900 degrees at the turbo...so for now its fine.
mutydog is offline   Reply With Quote
Old 10-08-2013, 02:23 PM   #23
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Don't you need to hook up the oil for lubrication purposes?
I just finished my build. You can find a post under NA with bolt on forced induction.
Old 10-09-2013, 10:17 AM   #24
JAC WAGON
Member#: 264294
2002 WRX Wagon
Rally Blue
In for results. <grabs the popcorn>
JAC WAGON is offline   Reply With Quote
Old 10-10-2013, 12:11 PM   #25
JAC WAGON
Member#: 264294
2002 WRX Wagon
Rally Blue
I just found a guy with an 02 WRX and traded my outback
