Old 01-04-2013, 12:56 AM   #1
silvercookie
Member#: 180033
2005 WRX
Default 2005 WRX 4eat. Hybrid. 280whp/390wtq.
Ok so it's not much to brag about, but thought it would gather some interest.
Please share your thoughts and opinions.
Facility: Performance Auto Solutions. Deer Park, NY.
Tuner: Dave Brown
Tuned with : Cobb Accessport.
Type of Dyno: Mustang Dyno
Year: 2005
Model: WRX
Transmission : 4EAT
Baseline # for a stocker at the dyno:-
Boost: 20psi
Fuel:BP 93oct.
Target AFR: ~11.0:1
SAE Corrections:-
Peak HP at RPM: 281 @ ~5350
Peak Torque at RPM: 389 @ ~3500
Mods:
Engine
2011 STi Shortblock.
Factory STi Forged Rods.
Factory Nitrided Crank.
11mm STi Oil pump.
Stock 2.0l heads.
Wiseco 99.5mm Pistons.
VF-48
Grimmspeed EBCS
Grimmspeed EWG 38MM Up-pipe.
TiAl MVS 38MM EWG.
08+ STi TMIC
Perrin silicone turbo inlet
KStech 83mm Short Ram with Spectre filter
DeatschWerks 750cc Injectors.
Walboro 255lph
Invidia 3" bellmouth catless down-pipe.
S-RS SP2 replica catback
GroupN Engine mounts
Torque Solutions v3 pitch stop.
Suspension/Wheels
BC BR coilovers
Carbing rear strut bar.
Rear diff bushings
outrigger bushings
cusco 21mm rear sway bar on medium
Kartboy endlinks Front and back.
Ebay H-brace.
Advan RG-2's 17x8 +45
225/45/17 kumho all season's temporary.
Crappy pic of dyno sheet.
Final Dyno run.
Current pic of how it sits
And engine bay shot. wiring is a mess but im going to take everything out and clean everything up once it warms up a bit.
silvercookie is offline   Reply With Quote
Old 01-04-2013, 03:06 AM   #2
acheung
Member#: 118389
any tranny work (i.e. modded tc or vb)? If not, are those coming next?
acheung is offline   Reply With Quote
Old 01-04-2013, 09:26 AM   #3
silvercookie
Member#: 180033
2005 WRX
Stock trans. Don't plan on doing anything to it at the moment.
Old 01-05-2013, 12:17 AM   #4
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Man that tq spike is gnarly for a vf48. That has got to be a blast. To bad the hp isnt a little closer to the tq but in my opinion the tq is where all the fun is. Nice build tho Im at 300hp 325 tq on my stage 2 sti and would give my left but to have 380 tq.
Coreycarlile911 is offline   Reply With Quote
Old 01-05-2013, 01:09 AM   #5
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Sounds off to me. That's a significant loss of power in the topend to the point where it has to be deliberate. Edit: auto. Yeah... I don't buy it.
Old 01-05-2013, 01:18 AM   #6
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
Damn auto trans is causing some serious wtq with that torque converter. Nice!
achavez is offline   Reply With Quote
Old 01-05-2013, 04:08 AM   #7
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
I didn't even know there was such thing as auto trans in wrx. Is that pretty rare or just very undesirable cuz this is the first ive seen.
Old 01-05-2013, 04:50 AM   #8
mikeydrives1
Member#: 262117
Dave does wonderous work on these things.
FYI, as a forester guy, i have been in other modified FXT's with 4EAT trans, pushing similiar torque. Yes the auto trans does something strange and puts the power down at the low end, there is no BS there folks. Dont be so quick to judge. You always see splits like this among the builds of forester XT's, Baja XT's, Outback XT's , Legacy GTs (5eat) and the occasional rare 4EAT wrx, only made up until 05. Plus its 2.5 bottom end.
mikeydrives1 is offline   Reply With Quote
Old 01-05-2013, 08:58 AM   #9
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
They actually made them up intill 2010 for the newer models they are called impreza GT which has a 4eat and a td04 turbo instead of a 5 speed and a vf52.
nate_fisher is offline   Reply With Quote
Old 01-05-2013, 09:13 AM   #10
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Nice Vinny, glad to see your happy. These numbers are as real as it gets. Autotrans for you... most all the autos Ive seen really shift the power too the left. 4.11 gears...
Ian @ Performance Auto Solutions
Old 01-05-2013, 10:28 AM   #11
tachrev
Member#: 115260
04 WRX
205/22E Hybrid w/ VF39
Lower gears don't move the curve anywhere, they multiply the numbers that are already there.
If the torque converter isn't locked, then it will multiply torque up to its stall speed. That can cause big low end torque spikes in automatic cars on the dyno.
tachrev is offline   Reply With Quote
Old 01-05-2013, 08:02 PM   #12
rexworx
Member#: 103232
Not to start a pissing match but this car was locked into 2nd gear during the pull.
Old 01-05-2013, 09:37 PM   #13
tachrev
Member#: 115260
04 WRX
I thought you were implying that the 4.11 final drive would move the power curve to the left vs other final drive ratios.
Old 01-05-2013, 10:56 PM   #14
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Originally Posted by ProfessWRX View Post
Seems like you haven't done a lot of things.
Why don't manual guys slip the clutch on dynos?
How does a dyno calculate torque? Does it use rpm? What happens if the Rpms are not directly connected to the drivetrain rotation?
Lol and you know everything I understand what you are saying, and it applies 100% if you are using a road dyno software. If you're measuring RPM accel vs. time NOT roll speed accel vs. time, slipping the clutch would net big numbers. Usually, like Airboy says, without a rpm pickup, you use a function called "calculate from roll speed" to estimate RPMs. If you're simply measuring torque output without a direct RPM signal to the dyno, slipping the clutch would just drop power, and kill your clutch. I'm not really sure where you're going with this.
I can tell you though, the auto has much more torque in the stall speed range than a manual does, whether you want to beleive it or not.
Originally Posted by Airboy View Post
The Torque curve, as plotted against engine RPM, is not accurate in the sense that the engine is not actually at the RPM indicated on the chart but I wouldn't go as far as "artificially inflating..." That RPM scale is calculated from the roller speed. As soon as you step on the gas, the engine will speed up to the stall speed and the wheels has to "catch up". The calculated RPM will be less than the actual engine speed.
That being said, the torque curve, as shown, does give an indication of the acceleration that you would feel. Imagine if you were blindfolded and didn't know the car had an automatic, would it feel like a lot of "low end" torque?
I made some plots and stuff that covers this:
http://tinyurl.com/b28nyx6
More or less this is what I was trying to get at. You're just much better at articulating it. I would like to see torque output plotted vs. time, taking RPM out of the equation, and see if it would change the shape of the graph.
Old 01-05-2013, 11:29 PM   #15
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
"Locked" into a gear and torque converter clutch lockup are two separate things.
Old 01-05-2013, 10:08 AM   #16
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
Very nice! We have identical long blocks lol bet its a blast to drive
shadowmd is offline   Reply With Quote
Old 01-05-2013, 12:47 PM   #17
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Yeah. I don't buy it at all. Torque converters are KNOWN to artificially inflate dyno torque numbers.
Look how fast it dips. That's the converter. The torque doesn't magically go away like that.
Once the turbine, impeller and stator reach the same speed, multiplication stops and torque drops.
The only accurate dyno for an auto is with a locked converter. And I'm willing to bet a considerable amount the OP didn't have his locked.
Old 01-05-2013, 02:15 PM   #18
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Who cares how the torque is made? It is, and thats all that matters. Really any car isn't 'accurate' to the engine hp and torque due to drivetrain loss on a chassis dyno. But guess what its more realistic than measuring on an engine dyno, because you are seeing what the wheels are recieving, not what the engine puts out.
I'm curious, was this pull done in 2nd or 3rd? Numbers seem high-ish for a 93 pump auto car on a mustang dyno.
Anyways, very nice car to the OP. Enjoy it! I love the auto myself, its much better than any 5 speed
Old 01-05-2013, 02:23 PM   #19
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Wrong. Artificially inflated numbers are accurate?
Old 01-05-2013, 04:12 PM   #20
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
How's it artifically inflated? You're measuring what's at the wheels. It's not the engine making all that torque, but there is torque multiplication through the TC which is brought at the wheels. Hence 390wtq, not 390 ctq.
Noone said that this engine paired to a manual gearbox would make these numbers, it would probably make more peak hp, less peak tq. Now your way of thinking, does this mean these horsepower / top end torque numbers artifically low due to the higher parsitic loss of a hydraulic automatic?
Edit: I kind of see where you can come from. Using like a road dyno software this becomes evident. If you are measuring how quick it can accelerate RPMs, then yes, this 'slip' is shows up as torque rise/then dip. However, I am very sure it measures torque simply by how quick it can accelerate the rollers and then assigns RPM datapoints to it afterwards, hence this is real torque. You could always measure it torque vs. time and see what happens.
Old 01-05-2013, 05:38 PM   #21
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
So tell me what happens when you brake stall on the dyno.
What happens when you lock the converter?
What happens when you change your final drive ratio? Does gearing effect power output?
Why don't manual guys slip the clutch like they do a "launch" to raise measured torque on the dyno? Because it skews numbers? Nah, no way. It's cause they don't know how to get artificial numbers like a stall gives you.
Old 01-05-2013, 04:21 PM   #22
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
This is exactly what torque converters do. I have a friend who had a 1969 340 Dodge Dart with an auto and the factory TC. Just couldn't quite break below 15 seconds in the quarter.
Got himself a high-stall track-designed converter and he was into the 13's.
Old 01-05-2013, 08:09 PM   #23
Mike05wrx
Member#: 314747
2005 WRX
i'll vouch for this car. it's def quick and the torque is insane
Mike05wrx is offline   Reply With Quote
Old 01-05-2013, 08:46 PM   #24
halokilller
Member#: 278870
2005 Stage 2 WRX
Obsidian Black Pearl
this is sick, nice video in the rain
halokilller is offline   Reply With Quote
Old 01-06-2013, 09:40 AM   #25
silvercookie
Member#: 180033
2005 WRX
Wow, got alot more responses then I thought it would.
No need to argue over every thing, I know the auto in 2nd will skew the numbers ever so slightly, but regardless, the car is running perfect and on the highway this thing is a blast.
Going to be getting a FMIC this upcoming week and a bigger turbo later on down the road.
