Welcome to the North American Subaru Impreza Owners Club Saturday February 13, 2016
Old 01-04-2013, 11:47 AM   #1
dangsy
Member#: 318906
2012 SWP WRX Premium
Default Anyone have the Sony xav-701hd?
Looking for some thoughts on the xav-701hd. Anyone have any experience in our cars?
dangsy is offline   Reply With Quote
Old 01-04-2013, 11:51 PM   #2
ryager
Member#: 342391
2015 WRX
Default Not exact model
I did not have that exact model, but the Sony XAV-60 which is a downgrade to that one is an amazing stereo and you can do a lot with it. That one will only be that much better. Never gave me any problems and install was a breeze, touchscreen and buttons always worked and had to reset it only a handful of times.
ryager is offline   Reply With Quote
Old 01-05-2013, 11:29 AM   #3
blessthekellen
Member#: 273859
MY98
WRX
Reset a hand full of times and you say its great?
Stay away from Sony. Slow interface. Crap quality. I've never had to reset my alpine inaw910.
blessthekellen is offline   Reply With Quote
Old 01-09-2013, 12:05 AM   #4
emjp4
Member#: 290926
2005 WRX
Never ever buy Sony in the car audio department. . They make some of the worst quality items I've seen.
emjp4 is offline   Reply With Quote
Old 01-28-2013, 01:41 AM   #5
jtoast
Member#: 345126
Just surfing by and saw your thread. While I don't own an Impreza, I do have an XAV-701HD in my Wrangler. I hate the thing. Nothing on its own makes it terrible but the combination of all the little things add up to a huge amount of user frustration.
Good:
Sound quality is excellent.
Several different built in animated backgrounds
Several sources available (Pandora/Bluetooth/usb/XM/etc)
Bluetooth is excellent on my Galaxy SIII but has issue..see below.
Mirrorlink if all you want is calls/nav.
Bad:
Mirrorlink implementation is weak.
This is Samsungs fault but since Mirrorlink is an advertised feature, I thought I would mention it. The US drivelink application was release last week and the only things that actually mirror are music on your phone (no Pandora/mog/etc), calls/texts, and nav. If you try to create a shortcut to mirror other apps, it works offline but the apps disappear when connected. Sony support says "working as intended."
Head unit seems buggy as hell and no firmware update in sight Examples:
About half the time I start my car, I have no sound from the head unit. It comes back if I change sources (FM to XM or vice versa for example). Also volume buttons seem to quit working at random. They will come back on usually after driving a bit. Until they do I have to either use the remote or reset the head unit. Yes, I've checked the wiring. This seems to be a common problem with both the xav-701HD and the 601.
User interface is very poorly thought out. Examples:
No mute button
Sometimes there is no "return to previous screen button" which forces you to press "Home" and start over.
No ability to rearrange or hide source buttons...for example to hide XM if you are not a subscriber.
Screen is not removable
Bluetooth loses info after shutdown. This means every time I connect it re-downloads my contacts.
If two paired phones are in the vehicle at startup, its a crapshoot which it will choose to pair with. Sometimes it does neither and I have to force the connection manually.
Sometimes it will choose to read an incoming text message and other times it doesn't. Haven't figured out why yet.
Radio reception blows. Even with an upgraded aftermarket antenna I don't get half the stations I did with my stock unit.
All in all, I really regret buying this unit. If I had it to do over again I would probably go with something like the Kenwood DDX-719 and saved myself a couple hundred bucks and much frustration.
jtoast is offline   Reply With Quote
Old 04-11-2013, 08:58 PM   #6
sabrelli
Member#: 342470
2013 WRX
Thought ill add my 2c as I just installed same model in my 2013 WRX this week.
Was looking at a pioneer but picked up this unit for only $400.(from Australia)
Install was a cinch - bought David Carter SVXdc harness and AXXESS SWC along with JDM Bezel.
I have a Sony Xperia Z phone and mirrorlink works perfectly, no lag simply does what its meant to do.
My radio reception is on par with Stock.
Steering wheel controls work for the time being except phone buttons. But that’s a common issue and I just need to program manually. Push to talks gets assigned Mute/ATT which I don’t really mind.
I was also able to bypass the parking brake by simply connecting it to the ground wires within the harnesses
Sound quality is pretty good compared to stock but that’s expected with any head unit upgrade.
All in all, im pretty happy so far.
sabrelli is offline   Reply With Quote
