Old 01-06-2013, 12:44 AM   #1
SpicyPeaNut
Member#: 43310
1978 Brat
Default GR JDM STI Side Skirts Install
Hi guys, over the years I have read some very helpful posts on this site and I would like to contribute. I know the side skirt parts aren't very complicated of an install but I've seen some threads pop up asking how to install them and figured it might help someone.
Anyways, this is going to cover the install on a 2013 sti (not sure which other years would be the same).
First things first. You need to take the stock side skirts off the car. For that you need to get under the car and pop off the little plastic automotive clips (there should be a total of 7. 6 are the big black plastic circular clips and 1 in the front that you need a small phillips head screwdriver to twist and remove) that line the bottom of the side skirts.
(here is a shot of the fat black plastic clips you will need to remove)
Once those are popped off, use my tried and true method "one-two-yank-foo". And the side skirts will pop off. Your car should now look something like this:
(After doing the first side I realized that the front fender vent did NOT need to come off to get the side skirt off. So you can skip removing that panel.
Once you have the skirt off, now would be a good time to clean them...
Once the actual stock skirt is ready you need to ready the new skirt lips...
Yummy STI goodness from Japan :derp
I wonder why I had a hard time reading these instructions...
Take the now clean OEM skirt and put it someplace you can work on it. I used my workbench (novel idea I know). Place the skirt like-so and line up the s206 skirt lip. When you do this it is very important to start at the rear. So align the rear first. Before you get into drilling holes and such, secure the lip with some painters tape.
I didn't get a shot of my aligning it up. But here you can see I started at the rear and slowly worked my way up.
The hole that you will need to drill will be obvious when line up the s206 skirts. Just go down the line 1 by 1 and drill the hole, insert bolt etc. Here you can see how I had taped the lip on.
As you secure each new bolt it will start to take form and you will soon find yourself not needing the blue painters tape.
If you have read this far I bet you are asking yourself, "what type of nuts and bolts is this guy using?". Well consider that question answered. These seem to be high quality, non-rusting nuts and bolts. As you can see when you do the install, you want to insert the bolt into the drilled hole you created. Then on the other side of the skirt, you want to use a washer, and then finish it off with that extended-rubber-nut-thingy (yes, this is a technical term and will be on the test at the end).
SpicyPeaNut is offline   Reply With Quote
Old 01-06-2013, 01:14 AM   #2
SpicyPeaNut
Member#: 43310
1978 Brat
I can also hear another question being asked. "What size drill bit do I need?" Well, since I have no idea what the actual size was on the bit I used I used the ole eye-ball test. I grabbed a random bit that was the same diameter as the bolts...
Here you can see how the bolt/washer/extended-rubber-nut-thingy is set up. This is before I tightened it down.
Here you can see what the bolt/washer/extended-rubber-nut-thingy looks after its tightened and snug.
Once you have drilled all the holes, installed all the bolts and tightened it all down, it should look something like this:
When you get this far, you only have to put them back on the car (obviously). Now get to it and install the OEM skirts on the car just like you removed them (except do the steps backwards).
New Hotness
I hope you learned a little about how this install goes from my little thread. I know its nothing ground breaking but so far, its the only way I could give back to teh Nasioc.
Old 02-10-2013, 03:09 PM   #3
ProdriveWRC
Member#: 20779
2012 STi
WR Blue
[quote=SpicyPeaNut;38845442]I can also hear another question being asked. "What size drill bit do I need?" Well, since I have no idea what the actual size was on the bit I used I used the ole eye-ball test. I grabbed a random bit that was the same diameter as the bolts...
1/8", 1/4" and 3/8" - they cross over to the 3mm, 6mm and 9mm that the instructions call for. It's the same as the OEM front lip.
Totally worth the money, same quality and fitment as the front lip too.
ProdriveWRC is offline   Reply With Quote
Old 01-06-2013, 01:27 AM   #4
PhamilySedan
Member#: 132249
2003 Bugeye PSM
RIP RSTi
None of your pictures are working.
PhamilySedan is offline   Reply With Quote
Old 01-06-2013, 01:30 AM   #5
SpicyPeaNut
Member#: 43310
1978 Brat
Uh oh. It's working for me. Let me try another computer and fix asap.
I'm uploading the pictures to flickr right now. I'll have these fixed up shortly.
Old 01-06-2013, 01:30 AM   #6
WRXSteye20008
Member#: 175565
2014 Sport Premium
Past: 351awhp Sti
Yeah, broken links or something.
WRXSteye20008 is offline   Reply With Quote
Old 01-06-2013, 01:37 AM   #7
garudatwo
Member#: 322385
You're linking them from dropbox, so either set permission to public (not sure if you can do that) or re-upload to another site.
garudatwo is offline   Reply With Quote
Old 01-06-2013, 01:51 AM   #8
SpicyPeaNut
Member#: 43310
1978 Brat
Okay guys, I uploaded to flickr and redid all the links. Should be good to go now! Thanks for hanging in there while I fixed it (it was a mess btw).
Old 01-06-2013, 01:56 AM   #9
Gorge
Member#: 97449
2007 WRX
Looking good! Needs more pictures of the finished product though on the car though
Gorge is offline   Reply With Quote
Old 01-06-2013, 02:11 AM   #10
FLEX'N WRX
Member#: 163672
GV
Same color as veneers
Good install. On the drivers side skirt, I kept the 4, 5 and 6(from front to back) bolts off/ loose. Before getting used to the skirt that allowed for some give since my foot liked to hit it when exiting.
FLEX'N WRX is offline   Reply With Quote
Old 01-06-2013, 02:13 AM   #11
SpicyPeaNut
Member#: 43310
1978 Brat
Originally Posted by FLEX'N WRX View Post
Good install. On the drivers side skirt, I kept the 3, 4, and 5 (from front to back) bolts off/ loose. Before getting used to the skirt that allowed for some give since my foot liked to hit it when exiting.
Thanks for the kind words. I was actually worried about that exact issue. After I had it all installed I got in and out of the car but my big ole feet cleared with ease.
Old 01-06-2013, 01:34 PM   #12
WRXLTD
Member#: 136314
2014 Grand Cherokee
+1
I'd also like to know how much you paid for the side skirts.
WRXLTD is offline   Reply With Quote
Old 01-07-2013, 12:10 AM   #13
SpicyPeaNut
Member#: 43310
1978 Brat
Thanks Gorge! As promised, some better pictures.
Old 01-06-2013, 11:57 AM   #14
swoyekr
Member#: 340115
2013 WRX
Dark Gray Metallic
Looks good!!
swoyekr is offline   Reply With Quote
Old 01-06-2013, 11:59 AM   #15
Molas
Member#: 309163
2012 WRX Premium/Nav
Looks nice
Molas is offline   Reply With Quote
Old 01-06-2013, 12:20 PM   #16
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Looks fantastic!
Its such a cool item, and it actually is 100% functional. Prevent free flowing high velocity air from rolling under the car and mixing with the high velocity air under the car.
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
Old 01-06-2013, 01:56 PM   #17
Molas
Member#: 309163
Price with shipping?
Old 01-06-2013, 03:10 PM   #18
RallySport Direct
Member#: 33174
We are Open Late!
Here is a image of them installed on our 2011 STi shop car.
Kirill
Old 01-06-2013, 03:17 PM   #19
SpicyPeaNut
Member#: 43310
1978 Brat
RSP has them for sale on their website listed at $1200. Now, that is a steep price however I also needed to buy some gauges, rear fog kit, smy cluster hood, front lic plate relocation kit etc. So I ended up spending around $2000, but luckily for me they had a black friday sale so the more you spend the more you save
I believe they are offering free shipping (which would cost atleast $75 via ups since the box for these is about 6 feet long). Wait until you have a discount code and want to buy lots of parts. Then capitalize :P
Old 01-07-2013, 08:05 AM   #20
WRXLTD
Member#: 136314
2014 Grand Cherokee
They look fantastic on your car (even better after you get a front lip), I just could never see myself spending $1,200 for them.
I'd rather take that money and get a carbon fiber driveshaft!
Old 01-06-2013, 03:35 PM   #21
carnz-pj-410
Member#: 110994
Old japanese cars
are the best
final product looks good mang, a little expensive but pretty sweet
carnz-pj-410 is offline   Reply With Quote
Old 01-07-2013, 10:14 AM   #22
Legend STI
Member#: 41086
2015 Jeep Sahara
Those look great!
Legend STI is offline   Reply With Quote
Old 01-13-2013, 03:34 AM   #23
Bacillus9
Member#: 342519
2013 WRX Limited
Dark Gray Metallic
Thanks for the step by step! I'll be getting a set when I pick my WRX up from the dealer in a few weeks.
Bacillus9 is offline   Reply With Quote
Old 01-13-2013, 07:04 AM   #24
Lrn2Corner
Member#: 246224
2012 WRX Sedan
12 Rav4 V6
Now put a V-limited front lip on it to complete the look
Lrn2Corner is offline   Reply With Quote
Old 01-13-2013, 12:31 PM   #25
SpicyPeaNut
Member#: 43310
1978 Brat
I picked my V-limited up from the Dealer yesterday. I will be making a replica vs oem lip comparison thread later in the day, so stay tuned!
