Notices
Old 01-06-2013, 06:39 PM   #1
m0nkey
Member#: 142325
2002 WRX Wagon
MBP
Unhappy Quick question about the weather temperature
So since the weather has dropped in temperature I have been getting a cel for system too lean and maf signal is high. But during the spring and summer I never throw a cel. So my question is should I have had two maps, one for warmer climate and another for cold?
m0nkey is offline   Reply With Quote
Old 01-07-2013, 01:50 PM   #2
bmx045
Member#: 262684
2015 Impreza Sport
ISM
maf specific codes should never be ignored. it can be a recipe for disaster. i suggest you find someone with a working maf and try it. you can try cleaning yours but it sounds like the maf itself is on the way out, proceed with caution and do not WOT it. failing maf's often lean out the fueling.
bmx045 is offline   Reply With Quote
Old 01-07-2013, 03:40 PM   #3
m0nkey
Member#: 142325
2002 WRX Wagon
MBP
Yeah I just cleaned mines two days ago and no codes except for system to lean. I just reset it and it has not came back on but the weather has warmed up a little.
Old 01-08-2013, 08:09 AM   #4
bmx045
Member#: 262684
2015 Impreza Sport
ISM
maybe you have a vac leak, boost leak test the system first and see if the problem subsides. if one of your codes is an IAT code or volt, it's more than likely because the maf is bad.
Old 01-09-2013, 10:16 PM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
if you clean maf sensor always best to let the car re-learn idle.
that means as long as it takes for the coolant fan to switch on.
