Old 01-14-2013, 07:27 PM   #1
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Default Lightweight flywheel, 16bit looking to tune throttle return
On my EJ207, with a 5 speed and Sti chromoloy 5 speed lightweight flywheel, I get sometimes a sharp drop when releasing the throttle, to where it almost stalls.
I've replaced the IACV and I've read about rising the idle by 1-200 RPM.
I've also read on other cars something about torque demand (for 32bit) and increasing that in cells close to idle and a more general statement about bringing fuel back in earlier.
Is this done for the 16bit by the load compensation table?
Old 01-16-2013, 10:25 AM   #2
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Your issue can be easily fixed by raising the injector cut on rpm value. Iirc the stock value cuts injectors back on after throttle lift at 900 rpm. Raise that value to around 1500 rpm and. The ecu will be able to catch the idle as injectors cutting on earlier will slow rpm drop.
fastblueufo is offline   Reply With Quote
Old 01-16-2013, 11:59 AM   #3
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Can you tell me which table this is?
Old 01-16-2013, 01:08 PM   #4
fastblueufo
Member#: 212154
02 billet crank
Its decel fuel cut. It may not be defined in your rom. Pm me the rom on romraider or email it to me and I will either modify the value for you or get a def file made so you can modify the value yourself.
Old 01-16-2013, 03:00 PM   #5
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Thank you, I appreciate this.
Old 01-29-2013, 04:54 AM   #6
nfm
Member#: 171697
05 WRX
wait, does this mean you can run lightweight flywheel fine after this ROM patch?
nfm is offline   Reply With Quote
Old 02-07-2013, 06:27 PM   #7
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Do any 16 bit ROMs have this RPM above X and TPS = 0 fuel cut table defined?
I've checked Carberry, my stock 2002 MT WRX ROM, my friend's 2004 MT WRX ROM and my stock JDM ver8 ROM and none of them have this defined that I can find.
Old 02-10-2013, 04:41 PM   #8
ammo0000
Member#: 175401
2007 VF39'd OBP WRX
2008 Blue Kawi ZX-10R
I have the streetlite flywheel on my 2007 as well. I'm not seeing these tables anywhere. Can anyone help with my tune as well?
ammo0000 is offline   Reply With Quote
Old 02-12-2013, 01:09 PM   #9
bmalo
Member#: 118930
1998 WRX'd Forester
I have a Ej205 so this may not apply to you. When I cleaned my IACV I fiddled with the orientation of the stepper motor on the valve. Basically adjusting how much that valve is open at it's resting position. At first adjustment I had the same problem as you described. Rpm's would fall fast and would shut the car off.
Then I turned the motor ever so slightly so the valve is a bit more open in it's resting position and it cured my stalling issue. Rpms fall fast but the ECU or the Iacv "catches" it before it stalls.
Just offering this as something you can try. My Ecu tuning knowledge is nonexistent.
Edit: FYI I have a ACT 12lb fly and a light crank pulley
bmalo is offline   Reply With Quote
