Old 01-17-2013, 02:43 AM   #1
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Default pet3r's 08 STI - GTX3076 - 553whp 527wtq - Phatron
This car has been a work in progress for quite a while now, and it feels good to be just about finished with the tune. There might be minor tweaks, but its about as fast as she's gonna get for now.
Details can be found on my online journal - www.pet3r.com
Dyno: Virtual Dyno
Temp: ~45 degrees
Elevation: ~2900
Tuner: Phatron (Phatbotti)
Car: 2008 STi, GTX3076R .82a/r
Target boost: 28psi
Target AFR: 11.6
Hp: 553whp
Tq: 527wtq
Fuel: E85
Vehicle Weight: 3350 + 220 (passenger)
Engine:
• Rallispec Street Block EJ25 (Crawford pistons, Subaru nitrided crank, Manley H-beam rods, upgraded main and rod bearings)
• Stock heads/cams
• Stock location intake manifold
• ARP Head Studs
• KillerBee Oil Pickup
• TiC Motive Autowerks Composite TGV Deletes
• Crawford Air/Oil Seperator
• Torque Solution Air Pump Delete
• Omni 4bar MAP sensor
• Gates Racing Timing Belt
Intake:
• Spearco TMIC
• P&L Rotated Cold-air intake, with TMIC connection
• Turbosmart Kompact BPV
• Garret GTX3076R w/ .82A/R
• Grimmspeed 3-port EBCS
• K&N Filter
Exhaust:
• Perrin EL Header
• P&L Rotated Turbo Kit
–up-pipe with Tial 44mm EWG, ported back to downpipe
–custom downpipe
–coated with LO-KO heat coatings
• Stock Catback + Muffler
Fuel:
• Five-O custom 1400cc Top-feed injectors
• Perrin Top-feed Fuel Rails
• Walbro E85 450lph pump (in OEM fuel basket, direct wire to battery)
• AEM Fuel Pressure Regulator @ 55psi
I can't recommend Phatron highly enough. I'm just blown away by his tune, his quick service and expertise. Phatbotti FTW!!!
Virtual Dyno
Just for fun...50-100 for xluben
50-100 = 4.33s (with no flat foot shift)
Also, for comparison against my last turbo, Dom1.5xtr 10cm. The Dom1.5 setup dynod at 400whp on a lowish Mustang dyno.
And just for kicks, here is what the Dyno feature on the Accessport shows (weight-3590, gear-4)
552hp @ 5845rpm / 558tq @ 4361rpm
pet3r is offline   Reply With Quote
Old 01-17-2013, 07:46 AM   #2
TonyNate
Member#: 323087
2004 Impreza WRX
Very nice... i can't wait to be at about 400hp myself...
TonyNate is offline   Reply With Quote
Old 01-17-2013, 08:20 AM   #3
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Wow impressive, thats a ton of torque. How much timing are you running at redline?
Nice car.
Old 01-17-2013, 08:44 AM   #4
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Wow, great results! It's amazing how much more power this setup is doing vs. the 1.5XTR with only 2psi more boost. And it spools just as well! I guess I can see why Phatron doesn't like the 1.5XTR much!
Any idea if you're being restricted by the TMIC? I think it is probably helping a lot with that incredible spool (400WTQ @ 3.5kRPM's), but I'm amazed it can keep up with that top end. The Spearco must flow pretty well. I wonder how it will handle heat soak...
Overall it looks like a great, (relatively) simple setup! Spool looks amazing and the top end is really strong. Any idea why the plots are trimmed? I assume this is VD - Dynojet setting? The 50-100mph time looks good too. I was just going to ask for that, and then I saw it!
Now a speedo video?
PS. Your site gave me some weird error in a pop up box, and then showed me a bunch of HTML code. Only happened once. I was just mousing over things when it came up.
Old 01-17-2013, 08:49 AM   #5
KurtP
Member#: 44836
1999 Fozzy
that is robust.....550whp and 300lbt ft at 3200. that must feel like a rocket ship.
KurtP is offline   Reply With Quote
Old 01-17-2013, 09:01 AM   #6
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
I guess Ron didn't like getting called out for posting weak cars and stepped on his stronger customers to post up his voodoo.
Please tell me you rev over 7. Please.
Old 01-17-2013, 09:23 AM   #7
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Wow thats alot of power and early. I cant believe your still running a TMIC with all that power. Must be happy with it though as im sure ron woulda told u otherwise.
Your dom 1.5 on e85 looks almost identical to my Dom 3 graph. Gotta love e85.I couldnt imagine having over 150 more whp, 415 feels nasty. It must just be scary at this point.
Old 01-17-2013, 09:13 AM   #8
02rex62
Member#: 215004
02 Rex
I wanna go fast!!!!!
Dam that think is sexy!
02rex62 is offline   Reply With Quote
Old 01-17-2013, 09:21 AM   #9
CatfaceType-R
Member#: 81102
Phatron's a ricer.
Old 01-17-2013, 09:27 AM   #10
bilt2run
Member#: 134211
my 1.5xtr is up for sale if any ones interested! haha..
bilt2run is offline   Reply With Quote
Old 01-17-2013, 09:36 AM   #11
KingPest
Member#: 194894
2013 BRZ
2005 STi
You really can't compare a 49lb/min turbo to a 64lb/min turbo. The GTX is much more appropriate for a high boost E85 application.
KingPest is offline   Reply With Quote
Old 01-17-2013, 09:39 AM   #12
bilt2run
Member#: 134211
^^^64lb/min? I thought they were rated at 55lb?
Old 01-17-2013, 09:50 AM   #13
juanmedina
Member#: 133146
nope is like 65lb/min.
Old 01-17-2013, 09:52 AM   #14
juanmedina
Member#: 133146
OP is your TMIC getting head soaked? At 500whp my hyperflow is having issues after repeated pulls
Old 01-17-2013, 10:10 AM   #15
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Thanks!
Nice car.
Honestly not very much. Ron likes to keep his tunes pretty conservative, but I asked him to step on it a bit. This log saw maybe 21.5-22 degrees by 7k.
Now a speedo video?
Ya, I'm blown away by this turbo. Transient response isn't quite the same, but its still making WAY more power than the Dom1.5 was
The Spearco is an amazing TMIC. The guys at P&L designed their rotated kit for this intercooler, and it's showing. I'm sure if I went up to 7500 the HP would keep climbing. I'm sure I could get a slightly faster 50-100 if I did a better job at break boosting and used FFS
Very much so!
Rev limit is at 7. Still a fairly young motor, and I don't want to go past 7 honestly. At 7k its a ZOMG feeling.
It's hard to tell. I never had a problem with it in the summer. Right now the average temp has been 45 out, so, its cooling really well. I also have the PTP turbo blanket, and even after a 30 min drive, I can put my hand on the turbo. P&L designed their kit for TMIC and thats the way I wanted it. We'll see come summer time again...
Old 01-17-2013, 10:12 AM   #16
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Like juanmedina said, this is a 65lb/min turbo. It's basically a GT35R, just more efficient and spools like a GT30R (at least according to Perrin's big post testing all these turbos). One of the reasons I went with it is it still had good spool but made monster power.
These can be pushed to 32 and still be efficient. That would be scary. And stupid for me
Old 01-17-2013, 11:10 AM   #17
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
You can when they spool the same!
Boost was already built by 50mph so brake boosting differently won't help anything. But it looks like it takes you close to 1/2 second to shift and then another 1/2 for the boost to fully built. I bet a hard FFS could save you 1/3 to 1/2 second.
Can you post (or e-mail me) more info on how you got the Walbro 465 to fit into the stock housing? How much power could your fuel system support (with stock lines and stock plastic housing restrictions)?
I think you should rev it to 8k and turn up the boost to 30psi
Old 01-17-2013, 10:35 AM   #18
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
That GTX30 amazes me. Awesome power vs spool!
wgr73 is offline   Reply With Quote
Old 01-17-2013, 11:18 AM   #19
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
As for the Walbro 465, I took out my 255, put 2 o-rings on and thats it. It fit just fine. I think my mechanic had to shorten the tabs on the outside casing brackets as the pump is longer, and then the filter added to it, it made it too tall. But, the nipple on the 465 is much wider and it took a few tries to get it to slide in without pushing out the o-rings.
My IDC for this log was 85%. I'm at 55psi with the FPR and I'm not a fuel expert. But i'd guess I could go a tad higher than what its at now.
Old 01-17-2013, 12:10 PM   #20
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Very interesting... I already trimmed my tabs a little with the 255, so I'm aware of how that goes. I think I might have to try that 465!
Old 01-17-2013, 11:24 AM   #21
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
That's one of my favorite turbos. Great results!
The problem with the comparison to the 1.5XTR is that it's running a 10cm housing. That's doing it absolutely nothing in terms of power but hurting spool like crazy.
-- Ed
Old 01-17-2013, 12:11 PM   #22
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
-- Ed
Uh oh. Don't let Phatron in here. He wants the biggest exhaust side on everything...
Old 01-17-2013, 12:24 PM   #23
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
-- Ed
Transient response on the Dom1.5 was very very good, like stock good. The 10cm is the way to go based on the results TopSpeed posted...very little difference in spool with the 8cm vs 10cm. I was very happy with the 10cm.
Originally Posted by Dave D. View Post
That's some incredible spool. How do you think the stock location setup would do on pump 92? Any graphs? Naturally boost and timing would have to be more conservative.
I'll be getting a tune on 91pump. I don't know what Ron would run the boost at, but I daily drive with E85. Just want a 91 map for when I travel, and when my business gets busy I drive about 200 miles every 2 days...so will need a tad more economical and longer-range fuel setup for those weeks.
Old 01-17-2013, 02:35 PM   #24
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Transient response might be good once you're above the boost threshold, but the boost threshold itself is moved up drastically with the larger housing. I have also yet to see any significant increases in power with the 10cm on that particular turbo. The compressor just doesn't flow enough to take advantage of the increased hot side flow potential.
-- Ed
Old 01-17-2013, 11:27 AM   #25
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Also just noticed that this is rotated. The stock location one we did had nearly identical results. Nice to see the comparison.
-- Ed
