Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 01-26-2013, 06:55 PM   #1
johnblahuta88
Member#: 221614
Default heat shield or turbo blanket.
so my debat is what would be better. a heat shield/chimney or an turbo blanket with stock shield over it
johnblahuta88 is offline   Reply With Quote
Old 01-26-2013, 07:39 PM   #2
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
The Perrin blanket is thinner from my recollection that the PTP, and on my OXT I was able get both the Perrin blanket and the OEM heat shield over a VF-52 without interfering with the WG. I have just the PTP blanket on my 1.5xtr and I would likely need a larger heat shield to get over that. If you are running a more stock size turbo why not try to get both on?
tazswing is offline   Reply With Quote
Old 01-26-2013, 07:40 PM   #3
RoadKillDMD
Member#: 284792
2011 STI
Blurple
All of the above. Wrap turbo, put stock HS around it, then an aftermarket HS over that.
BTW, fill out your profile...
RoadKillDMD is offline   Reply With Quote
Old 01-26-2013, 07:44 PM   #4
byun
Member#: 258046
2011 Impreza WRX
I'm running just the Perrin blanket on my 1.5xtr but just ordered a grimmspeed heat shield to fit.
byun is offline   Reply With Quote
Old 01-26-2013, 09:07 PM   #5
Type2
Member#: 200436
2004 Forester XT
Turbo blanket and heat shield. If choosing only one go with blanket
Type2 is offline   Reply With Quote
Old 01-26-2013, 09:10 PM   #6
93rx7fd
Member#: 342790
1993 rx7
shield generally keeps the heat from transferring all around the engine bay, keeping temps down and not cooking lines/hoses and such.
I believe the blanket is more for optimal turbo performance but it traps more heat in the turbo as well
93rx7fd is offline   Reply With Quote
Old 01-26-2013, 09:12 PM   #7
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
blanket
Old 01-26-2013, 09:36 PM   #8
kingsalami
Member#: 206257
2009 WRX 5-door
I'm running a PTP blanket, the OEM heat shield (modified to fit my Cobb DP) and an SPT heat shield I got for cheap.
Heat soak is practically a thing of the past for me!
kingsalami is offline   Reply With Quote
Old 01-26-2013, 09:34 PM   #9
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Both.
Old 01-26-2013, 10:40 PM   #10
white rocket
Member#: 329829
2007 STI Limited
I'd say both. Why not. I did the PTP black blanket, Cusco heatshield and lined the underside of the heatshield with gold foil. Heat is the enemy so the more the merrier IMO. I hear that keeping the heat within the turbo will help with air flow thus pushing the air out of the exhaust faster.
white rocket is offline   Reply With Quote
Old 01-27-2013, 12:28 AM   #11
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
read all of my infrared threads, take the information and make the best decision for you and your wallet. After all of my camera and product experience, if I had to choose to only have one product under my hood it would be the PTP Lava Blanket.
The Lava Blanket has many more benefits than a heat shield alone does.
www.ptpturboblankets.com <---------------go here for all the info
then go here to buy one ----------------------------> http://forums.nasioc.com/forums/show....php?t=2445720
Old 01-27-2013, 02:40 AM   #12
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
Blanket if just one, and to correct a couple of post above, "trapping" heat in the exhaust aside of the turbo isn't bad. Hotter air flows faster. That's why you wrap headers and up pipes to get the air to spin the turbine as fast as possible.
m1r4g3 is offline   Reply With Quote
