Notices
Old 02-04-2013, 09:33 AM   #1
RickDC
Member#: 199171
2004 WRX Wagon
Default 2004 WRX Wagon radiator problem
Looks like I have a leak right under the radiator cap after noticing white smoke and burning smell. I could see bubbling where the neck meets the plate. At first I thought it was just because I had more coolant than necessary but draining some coolant didn't resolve it. I'm also noticing a strong fuel smell coming through the vents while driving although maybe I'm mistaking it for burnt coolant. Anyone have ideas on how to fix or whether something else is wrong?
RickDC is offline   Reply With Quote
Old 02-04-2013, 09:34 AM   #2
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
Maybe the cap is not sealing properly.... I bet new caps are cheap!
Smurftastic is offline   Reply With Quote
Old 02-04-2013, 09:45 AM   #3
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Yikes, clean that up quickly and get a new cap ASAP and see if that resolves your issue.
That burning hot coolant is not going to be good for your electrical if it is spilling all over your wiring, and from the looks of if there is dried up coolant on your loom there.
It is hard to mistake coolant for fuel. Maple syrup vs. fuel should be pretty clear. And as danthrax said, that recall is only for I believe 2002 WRXs, has something to do with modifying the fuel rails with a longer hard pipe and a shorter hose. Look that up in the Warrantee Issues forum, you can find it there.
Jessekrs123 is offline   Reply With Quote
Old 02-04-2013, 09:45 AM   #4
Danthrax
Member#: 299368
2014 Impreza 2.0i
1. You should buy a new radiator cap and that should resolve the leaking coolant.
2. That smell is one of your fuel lines seeping fuel on top of your engine. It happens to all 2.0L wrxs and is a good idea to have it fixed.
I had number 2 done for free because I was covered under the wvk-21 SOA recall. You may have to front the bill though being a 04.
Danthrax is offline   Reply With Quote
Old 02-04-2013, 09:57 AM   #5
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
those metal coolant tanks often have pinhole breaks at the welds by the filler neck. Pull the whole tank off, clean it up and bring the top lid to your local muffler shop to reweld for a beer.
