Welcome to the North American Subaru Impreza Owners Club Monday July 28, 2014
Old 02-07-2013, 06:49 PM   #1
Raider2005
Member#: 313175
2005 Wrx Sti
Default Cams Or Not?
I have a 2005 sti i spun a rod bearing and ordered a short block for it and stage 2 brian crower cams and injectors and ARP headstuds. once i get done with it will it be still a reiable car or shold i always worry about something going wrong
Raider2005 is offline   Reply With Quote
Old 02-07-2013, 06:54 PM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Your thread subject and post are asking two different questions....are you asking if you should run cams or not or are you asking if your engine is going to grenade again?
Old 02-07-2013, 07:06 PM   #3
Raider2005
Member#: 313175
2005 Wrx Sti
like if i use them will my car not be reiable to drive 4hrs on the weekends and not have to worry about it and jst do regular oil changes and stuff
Old 02-07-2013, 07:28 PM   #4
04ScoobyWtf
Member#: 287974
Depends on the builder the tuner and the drivers ability to not grenade it
04ScoobyWtf is offline   Reply With Quote
Old 02-07-2013, 07:35 PM   #5
Member#: 51961
2005 STi
2012 WRX
The cams themselves will not affect the engine's reliability, no. The biggest factor in reliability is maintenance and the quality of the tune.
Old 02-08-2013, 11:44 AM   #6
Raider2005
Member#: 313175
2005 Wrx Sti
Ya I was gonna have it pro tuned. I have always kept up on the maintenance
Old 02-08-2013, 11:50 AM   #7
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
If your not running a larger turbo the cams were worthless
dangerousatom is offline   Reply With Quote
Old 02-09-2013, 12:26 PM   #8
Raider2005
Member#: 313175
2005 Wrx Sti
I'm going to up grade my turbo but not right away
Old 02-09-2013, 12:45 PM   #9
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
A quick google of how a camshaft works would have answered your question.
If you already purchased the parts and then are second guessing them does that make sense?
Why must a new thread be posted, every time someone has a mundane question.
here man
Flat 4 Motorsport is offline   Reply With Quote
Old 05-10-2013, 04:02 AM   #10
Cr4ckfi3nd
Member#: 269647
2009 LGT Limited
that link is awesome!!!!!!!!!!!
Cr4ckfi3nd is offline   Reply With Quote
Old 05-10-2013, 12:45 PM   #11
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Cams are worthless unless you above 500whp i would say. Why do you need cams to draw in more air when the turbos job is to deliver more air?
cosseywrx is offline   Reply With Quote
Old 05-10-2013, 01:38 PM   #12
meat_WRX
Member#: 96919
2004 sti
black
really?
because a 35r car locally can make 400whp on lets say 22psi. (dont remember exact)
the same car/turbo with cams made 400whp on 18psi. (i do remember it bening a 4psi drop to obtain the same whp)
This is coming off my memory from a discussion and dyno session that was going on back in 2009 when I just happened to pop in.
cams might be worthless on a stock frame turbo, but thats it.
edit- OP - your thread is, well, not needed to put it in a nice manor.
meat_WRX is offline   Reply With Quote
Old 05-10-2013, 01:40 PM   #13
Strider327
Member#: 131280
2004 Impreza WRX
Originally Posted by meat_WRX View Post
really?
^This, but even with a stock turbo. Nicely built heads with cams can have a huge impact on power and response. For example, Cosworth big ported heads with cams. Complete fully powerband all the way to redline.
Strider327 is online now   Reply With Quote
Old 05-10-2013, 01:53 PM   #14
meat_WRX
Member#: 96919
2004 sti
black
you gonna spend 5 grand on some heads just so you can run the stock turbo?
Old 05-10-2013, 06:21 PM   #15
northman
Member#: 163631
07 Forester XT
Dom 1.5XT-R
Cams can affect reliability. Going with a bigger cam usually necessitates using springs with higher spring rates. A firmer spring will put more stress on the valvetrain, and be an incremental hit to longevity. How much, I don't know, but the effect is real.
northman is offline   Reply With Quote
Old 05-10-2013, 01:33 PM   #16
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
I think you need to do some homework.
Old 05-10-2013, 07:54 PM   #17
Cr4ckfi3nd
Member#: 269647
2009 LGT Limited
Wow did I reopen a can of worms. The only intelligent comment since I posted was by meat_WRX. Yes heads w/ cams can improve the overall powerband but the fact remains that the stock turbo will fall on its face at higher rpm. So, unless a turbo upgrade is in the near future all these gains will be minimal and not cost effective. You will spend 5k+ for maybe 50whp and trq (being optimistic). That doesn't include the cost of the parts and labor involved in upgrading heads.
As you can see it adds up fast. Just an upgraded stock location, fuel system, and tune will cost ~3k and can get gains get better gains.
My .02
Old 05-11-2013, 06:39 PM   #18
cowboy_Rob
Member#: 194062
2003 Impreza WRX
If you guys are spending 5k for cams your getting ripped off. I bought crower 272s for ~500 and the machine shop charged me 750 to clean, resurface, valve job and install new cams and set the valve lash.
On a stock car as a first mod don't bother but if you have the motor apart anyway and have plans for a bigger turbo its definitely cost effective to do it while the engine is apart
cowboy_Rob is offline   Reply With Quote
Old 05-11-2013, 06:58 PM   #19
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
And we have a winner . . . If your already there might as well get it done when the thing is apart. I also got the Brian Crower 272's and they made amazing differents, I also did the rest of the valve train so I could rev to 8k and not worry.
Also do NOT over pay, I got a fully built long block for $7500 maybe $8000 (cant remember its a big blur of parts and such lol) it maxed out my fuel system and made 420 whp peaking up at 7900 rpm. It all comes to balancing your build. The cams, compression, fuel, and turbo are the most basic pieces of the system to focus on. If you need/want some specifics on what you might want to do PM me and I will be happy to point you in a good genneral direction.
Scuby04STi is offline   Reply With Quote
Old 05-11-2013, 07:30 PM   #20
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Not that its a big deal but I meant actual crower cams not Brian crowers. Deals can always be found if you look hard enough
Old 05-11-2013, 07:02 PM   #21
Cr4ckfi3nd
Member#: 269647
2009 LGT Limited
Fail..... read a lil closer next time, no one is spending 5k on just cams.
Yes if its apart and you have future plans then by all means yes, put the cams in. But based on this post there are no "real plans" so this not the best use of the money at this time. If the op actually puts together a plan for his future build then this might be a good time for cams.
I learned these lessons the hard way and now i have a spreadsheet with every single part i plan to put on my car in order of which ones should be installed first and grouped by parts that should be installed together. I have a defined power and performance goal and have researched how to reach that and have chosen parts to accomplish my goal. That is a plan. The end.
Edit: in reference to 2 posts ago.... and then some....
Old 05-11-2013, 07:15 PM   #22
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
True, it is not the best use of the money at the moment. If you KNOW you will put a big old beautiful turbo on then cam it, if you are keeping a turbo that doesnt like going over the 6800 mark stick to stock.
Here is a perfect idea, list ALL the mods you have done or plan to do. There are plenty of people here who can help ease your mind when they have all the information.
Old 05-11-2013, 07:26 PM   #23
Cr4ckfi3nd
Member#: 269647
2009 LGT Limited
Totally agree
Old 05-11-2013, 07:43 PM   #24
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
No thats a massive deal cowboy_rob, LOL
Out of curiosity where does your power die off?
I want to get people to make a break down of cam/turbo/fuel combo's and show people what combo likes to go together the most. Seeing everyone told me these cams where nearly stock, I just look back and laugh.
Old 05-11-2013, 08:57 PM   #25
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Tough to tell at this point where the power falls off at lol
Outfront block, crower cams, bc springs and retainers, Fp red, aps fmic, dw1000's, clutch masters 6puck, and a walbro 255 that just may need upgraded
