Old 02-24-2013, 12:16 PM   #1
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
Default first time tuning. need major help
hey guys. I am looking to start tuning my own car, but I am having a hard time knowing where to start. I have read the "tuning for newbies guide" and also a bunch of other threads on here/ as well as the romraider forums.
I am not looking to be spoonfed, but I just need a little bit of direction on where to start, and I think I will be able to figure it out much more quickly with a bit of guidance from you guys that have been doing this for awhile now.
so anyways here is what I have for tuning equipment
innovate mtxl wideband
blue vagcom cable
romraider
ecuflash v1.29.906
learningview
windows 8
here is a link to my build thread on the car
http://forums.nasioc.com/forums/show....php?t=1753564
cn:
07 2.5i m/t
built motor
large turbo
modded wrx injectors
blow through maf
mbc
right now I have just a base tune that I had done by someone else. it's running wastegate pressure (7pounds)... I would like to smooth everything out, and start turning up the boost.
basically I am wondering where to start? what should I be logging?
olsen726 is offline   Reply With Quote
Old 02-24-2013, 04:05 PM   #2
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
What rom are you running on your NA ecu that allows you to tune for boost? Are you using a WRX rom on your NA ECU?
endrswrd is offline   Reply With Quote
Old 03-01-2013, 11:49 AM   #3
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
using the factory 2.5i ecu/ rom.
im pretty sure the ecu doesnt know that the car is boosting..that you just tune it how people would tune there older na/t subarus with a piggyback
i could be way off though. i am still trying to learn this as i go
Old 03-02-2013, 04:24 PM   #4
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Does the stock MAP sensor read high enough? Can you scale the necessary tables? I've tuned a turbo car on an na ecm. Not a Subaru but It can be done. Not ideal but it works.
Old 03-03-2013, 02:00 AM   #5
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
im not sure about the factory map sensor. i believe it will read high enough, but i dont know for sure.
and yes i am pretty sure you can scale everything that you would be able to scale on a wrx ecu
Old 03-03-2013, 02:01 AM   #6
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
tomorrow i will post a log. hopefully one of you guys can help me out with deciphering the info on it
is this everything i should be logging
• Engine Speed (RPM)
• Engine Load
• IAM
• A/F Correction
• A/F Learning
• A/F Sensor
• CL/OL Fueling
• Feedback Knock Correction (FBCK)
• Fine Learning Knock Correction (FLKC)
• Ignition Base Timing
• Ignition Total Timing
• Knock Correction Advance
• Mass Air Flow Sensor Voltage
• Throttle Opening Angle
• Manifold Relative Pressure
• Injector Duty Cycle
• Intake Air Temp
Old 03-03-2013, 02:54 AM   #7
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
• Engine Load
• IAM
• A/F Correction
• A/F Learning
• A/F Sensor
• CL/OL Fueling
• Intake Air Temp
I would skip maf volts and scan maf afgs instead.
If also skip base timing and advance timing.total is all that's really important. Scan absolute manifold pressure and atmospheric pressure instead of relative pressure.
...But that's just me.
Also idc is only needed if you question their ability to keep up with fueling requirements. Otherwise fewer parameters is better.
Old 03-03-2013, 12:15 PM   #8
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
sounds good. i will head out here in a few to get some logging done... thanks for all of the help
Old 03-03-2013, 02:45 PM   #9
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
of course the frigging serial to usb adapter that i bought wont work with windows 8... i will just have to log without the wideband, until i can get another converter cable
Old 03-08-2013, 05:36 PM   #10
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
finally got everything hooked up and working properly.
here are some of my logs
i logged them today
60 degrees out/ blue sky
3rd gear 3k-6200 wot
gonna figure out how to post the logs, and have them on here very shortly
Old 03-08-2013, 05:49 PM   #11
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
http://www.fileswap.com/dl/RNPxwD4z/
http://www.fileswap.com/dl/K1vkKd7rrf/
http://www.fileswap.com/dl/B9yCWaynKk/
that is a link to the files... i am still trying to figure out how to post them on here
Old 03-08-2013, 06:26 PM   #12
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
i think i figured it out... here is the 3rd log i did
https://docs.google.com/spreadsheet/...=0&output=html
Old 03-08-2013, 06:32 PM   #13
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
Old 03-10-2013, 02:54 PM   #14
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Don't go wot again. You are very lean.
It also looks like your map sensor is maxed out at 19.88. Don't know enough about your computer but it could be a sensor limitation or the ECM reading limit. I assume the sensor.
That means the computer is seeing 5 psi max.
Old 03-10-2013, 03:36 PM   #15
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
should i see if i can track down a wrx map sensor, and swap that it?
also i thought around 11.1 afr was what it was supposed to be under boost, or are you referring to the 3246-4216 rpm range?
Old 03-10-2013, 06:53 PM   #16
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
It may not be as easy as a simple swap. Might want to see is somebody else has done that and see what all it takes. It is a very important sensor.
And yes, 3200-4200 is way too lean.
Old 03-10-2013, 09:39 PM   #17
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
Ok, thanks for the help. I will do some digging, and see what I can find on the map sensor issue... I have a feeling I wont be able to find much info on it though... there arent a whole lot of people tuning/boosting these cars
Old 03-10-2013, 09:59 PM   #18
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
Just found a thread on rs25 where a guy said that his map maxed out at 5psi too. He had to run a voltage clamp thing... im still reading up on my options though
Old 03-15-2013, 08:25 PM   #19
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
i grabbed a map sensor off of a wrx motor that i had laying around, and it bolted right up now i just need to figure out how to calibrate this thing!
Old 03-15-2013, 09:24 PM   #20
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
if the calibration values are in the same units as the wrx rom, you may be able to pull it directly from there. Hopefully somebody who has more knowledge on this type of situation can help...
Old 03-20-2013, 03:49 AM   #21
Gamble_WRX
Member#: 234783
2004 STi
im just getting back into tuning, but can i get a copy of your rom? i wanna see how the map lines up with the log. thanks!
Gamble_WRX is offline   Reply With Quote
Old 03-20-2013, 10:18 PM   #22
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
i will get you one as soon as i can figure out how to get ecuflash to read my rom
Old 03-25-2013, 11:29 AM   #23
abstrakraft
Member#: 292008
2007 OBS SE
Blue/Grey
Your 2.5i uses a MAF (Mass Air Flow) sensor, not a MAP (Manifold Air Pressure) sensor. Where exactly are you plugging in the MAP sensor? If it's replacing the MAF, I wouldn't think the ECU (which is still expecting MAF) will be too happy.
abstrakraft is offline   Reply With Quote
Old 03-25-2013, 05:18 PM   #24
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
errrrr....they are not mutually exclusive...
mechatricity is offline   Reply With Quote
Old 03-28-2013, 12:26 PM   #25
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
It uses both map and maf.
