Welcome to the North American Subaru Impreza Owners Club Saturday February 13, 2016
Old 03-16-2013, 05:50 PM   #1
06wrxlbart
Member#: 154013
2012 S4
Monsoon Grey
Default What is this inside R180?
Im not sure what this metal band ir gasket is can someone tell me? Both sides of the R180 has it that i bought. Thanks in advance.
06wrxlbart is offline   Reply With Quote
Old 03-16-2013, 06:20 PM   #2
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Looks like the coil spring for the axle oil seal to me.
minifreak is offline   Reply With Quote
Old 03-16-2013, 08:40 PM   #3
Snowy
Member#: 50945
+1 its the spring that applies tension to the oil seal, they get knocked out pretty easy if the drive shafts are pulled out at an angle, or put in at an angle for that matter. If the seals are in good shape you can just reseat the spring into its groove, when it comes to oil seals, rule of thumb in most every case is spring side is towards the oil FWIW.
Snowy is offline   Reply With Quote
Old 03-16-2013, 11:44 PM   #4
06wrxlbart
Member#: 154013
2012 S4
Monsoon Grey
So this goes behind the seal, around the rubber ring ? If I'm thinking right.
Are they really necessary to have or just for some type of safety?
Old 03-17-2013, 07:14 AM   #5
mhoerath
Member#: 131379
2003 354 ftlb@3k rpm
justablue hatch
spring goes inside the seal
mhoerath is offline   Reply With Quote
Old 03-17-2013, 11:34 AM   #6
06wrxlbart
Member#: 154013
2012 S4
Monsoon Grey
Thank you v. Much.
