Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 03-23-2013, 08:57 PM   #1
StayClassy94
Member#: 345354
Default EJ20 help!! Bought swapped car, don't know what motor it is!
I hope that I am posting this in the right area.
About 2 months ago I bought a 95 impreza l that someone had swapped to an "STi".
A few days ago I became curious to exactly what motor was in my car(I know its some kind of EJ20 since it's stamped on top with it.).
I looked up a few threads and I still can not find my VIN number on the motor anywhere.
It has coil-on-plugs and the ECU is OBD 1. So i'm assuming the motor would have to be <1998?
The whole subaru game is new to me, so excuse me if i'm handing out the wrong information.
The only numbers I have found are:
EJ20--on block under alternator.
02 AB 11112--on small flat area about an inch away from the EJ20 stamp.
BB 02--also on same flat area as above^^.
7345-on top of black about 2-3in left of the EJ20 stamp.
596224595387--on top of block on a tab, in the middle-back of the engine, where it connects to tranny.
199413--about 3-5in to the right on the number above^^.
4 cam 16 valve--on cam covers.
I know that's about every damn number on the motor but when I run them I still dont get anything for the motor.
Also there was a sticker on the front of the cam cover but it was in chinese writing. Nothing that gives me any vin to the motor.
I saw on a few threads that the vin in on the left back side of the motor. But i looked and looked and looked and couldnt find anything. Am I just blind??!!?!
Someone please help. I need to order some parts for the motor and I want to make sure that I order the correct things for the correct motor. Also, it'd just be nice to know exactly what motor is under the hood since the previous owner couldnt really help me out in any way.
Here's a few pics of the motor if that helps anything out at all.
Thank you all very much.
Here's the cam cover sticker:
Motor:
StayClassy94 is offline   Reply With Quote
Old 03-23-2013, 10:25 PM   #2
Dan7140
Member#: 228950
Ej20g
Dan7140 is offline   Reply With Quote
Old 03-24-2013, 05:04 AM   #3
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
1992-1996 EJ20G.
Just because it has a red (painted) intake manifold doesn't mean it's an STI. What are the last four digits of the ECU code (after 22611A)?
Japanese writing. And that sticker is there to write down at what mileage the cam belt was replaced.
Marnix is offline   Reply With Quote
Old 03-24-2013, 01:42 PM   #4
StayClassy94
Member#: 345354
Originally Posted by Marnix View Post
1992-1996 EJ20G.
I never said it was an STi. In my original post I clearly stated that he had converted it to an "STi"<----putting it in quotations to show my doubt of it being an STi. If it were an older STi it'd be a lot easier identifying the motor. EJ20K. I'll check ECU and get back today. Thank you very much.
Old 03-24-2013, 01:55 PM   #5
Dan7140
Member#: 228950
What about an EJ20K? Those were in WRX and STi models.
So were EJ20G engines. This is a 20G.
Old 03-24-2013, 03:01 PM   #6
StayClassy94
Member#: 345354
What I meant when stating the "EJ20K" was that and the "EJ20G" were my only options in regards of the older STi and WRX, making it a littler more easier to identify, if that makes sense?. Opposed to the other motors that this could be(EJ205, etc.).
And how could I identify that it's an EJ20G? I believe you, i just wanted to know how I could verify that. Thank you.
Old 03-24-2013, 05:42 PM   #7
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
The intake manifold and coil on plug are the key identifiers.
i_c_the_light is offline   Reply With Quote
Old 03-24-2013, 08:26 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
What is written on the plate on the turbo? There will be a 10 digit part number as well as either a VF or TD designation on the next line down.
Old 03-25-2013, 01:17 AM   #9
blessthekellen
Member#: 273859
MY98
WRX
Definitely EJ20g.
Take a look at your turbo to find out if its a TD04 (wrx) or TD05 (sti).
Also check your ECU to see if its stamped Z4 (wrx) or SB or SA (sti)
blessthekellen is offline   Reply With Quote
Old 03-25-2013, 08:10 PM   #10
eg33GC
Member#: 206851
56 Belair
Pro Street
Originally Posted by blessthekellen View Post
Definitely EJ20g.
Wrx were tdo5. Sti were z4 too. Check your facts
Old 03-25-2013, 11:00 AM   #11
Pebbles!
Member#: 243172
I rebuilt one of these recently. Looks like an EJ20G for sure.
Pebbles! is offline   Reply With Quote
Old 03-25-2013, 10:37 PM   #12
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Definitely EJ20g.
Try again.
Old 03-26-2013, 12:43 AM   #13
blessthekellen
Member#: 273859
MY98
WRX
Originally Posted by i_c_the_light View Post
Try again.
WRX (wagon) Td04.
Wrx/Sti Td05.
My apologies.
Z4 definitely is WRX stamped though. STi were SB or SA.
My previous Version II STi was stamped SB.
Every JDM WRX that I have taken an ECU out of is Z4 stamped.
Old 03-26-2013, 12:51 AM   #14
blessthekellen
Member#: 273859
MY98
WRX
Impreza 1993-1996
Impreza 1993-1996 UK/GT/Aus WRX
ECU Code 7D or V7 : 11.47psi (UK Spec/Aus WRX)
ECU Code 6D : 11.47psi (GT/Euro model)
Impreza 1993-1996 UK Prodrive upgrade
ECU Code 7D or V7 : 13.64psi (actually the STi 2 6K map)
Impreza WRX 1993-1994
ECU Code W6, U8 or 2C : 11.47psi
Impreza WRX RA 1993-1994
ECU Code W9 : 11.47psi
Impreza STi 1 1993-1994
ECU Code SA : 14.87psi
Impreza STi RA 1993-1994
ECU Code SB : 14.87psi dropping to 13.64psi (very lean fuelling )
Impreza WRX 1994-1996
ECU Code Z4 : 12.7psi
Impreza WRX RA 1994-1996
ECU Code Z5 : 12.7psi
Impreza STi 2 1994-1996 (inc 555 Sp.Ed)
ECU Code 6K : 13.64psi
Impreza STi 2 RA 1994-1996
ECU Code 7K : 13.64psi
Impreza WRX Wagon 1993-1996
ECU Code 1C, 3B, V9 : 10.5spi (peak) dropping to 6.8psi
Impreza WRX Wagon/Saloon Auto 1993-1996
ECU Code B4, V5 : 10.5spi (peak) dropping to 6.8psi
Impreza STi Wagon 1994-1996
ECU Code SC : 12.7psi (actually the Z4 Map from saloon, as has TD05)
Old 03-26-2013, 05:32 AM   #15
Merko
Member#: 317488
1995 GC8C WRX import
Definitely ej20g. But I don't see a 5th fuel injector on the intake manifold. Don't all V1&V2 STi's have that?
Merko is offline   Reply With Quote
Old 03-26-2013, 10:05 AM   #16
pmugabi
Member#: 280926
Only the WRX RA and STi RA have the famous (but useless) 5th injector.
pmugabi is offline   Reply With Quote
Old 03-26-2013, 12:21 PM   #17
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
EJ20G. Valve covers also tell you.
Check the turbo and ECU to tell if it's an STi or WRX. These guys are right.
GGSimpreza is offline   Reply With Quote
