Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 03-24-2013, 02:21 AM   #1
bshep211
Member#: 332839
Default Need help with 05 STI cam timing
I have 5K miles on my new build. I have a new 2012 bottom end. I had the heads rebuilt by pro machine. I got a new gates timing belt kit with water pump & oil pump for the build. I had my local Subaru dealership build the motor & do the timing.
I started to get some knocking noise from the new motor. I drove 5 miles home. I got a p0011 check engine light once I got home. I checked the turbo & heads oil supply line to make sure there was no oil starvation. Oil system is working correctly. I checked the timing and found the exhaust cams are way off.
Shouldn't the exhaust cams look like this?
The only thing I was worried about doing myself was the motor build and timing. I payed $600 for Subaru to build the motor and to do the timing.
bshep211 is offline   Reply With Quote
Old 03-24-2013, 10:35 AM   #2
bshep211
Member#: 332839
Bump! Need help please
Old 03-24-2013, 12:03 PM   #3
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Why wouldnt you have turned your car around and gone back..??
You just paid to have all this done, does responsibility not lie somewhere??
I would have stopped on the side of the frikkin road and had them come get the effin car...
Old 03-24-2013, 12:28 PM   #4
bshep211
Member#: 332839
Trust me, I will be at the dealership Monday morning.
I did not pay for the install of the motor. I didn't want to pull the motor until I knew what was wrong. Timing belt is easy to check.
Is there any possible way for the timing to be done correctly then both exhaust cams flip in rotation? I just trying to get all the facts before talking to the dealer.
Old 03-24-2013, 12:37 PM   #5
bshep211
Member#: 332839
I talked to Gates support and they said the belt would have to of broken for this to have happened. I don't see any damage to the belt. But I don't think the motor would run with the exhaust cams like this but i am unsure on that. I changed the oil after I got home and the oil had no metal shavings in it.
