Old 03-24-2013, 01:04 PM   #1
855T
Member#: 246628
2010 Impreza WRX
Default TPS light is on, pressure is fine
My TPS light came on a few weeks ago when I last drove the car. I'm back in LA and the light is still on. I checked the tire pressures a few weeks ago and again today and the pressures are all good, between 32 and 33 in each tire. It seems like one of the sensors is broken...is there anything else it could be?
Also, the car was purchased in May of 2010. Is this something covered under the 3/36 warranty?
855T is offline   Reply With Quote
Old 03-24-2013, 01:09 PM   #2
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Ask the service writer at your dealer. Likely a bad sensor. They don't last forever but that's pretty quick. My LGT...they died in a little over 2 years. I didn't care as the light isn't all that annoying.
Old 03-24-2013, 01:09 PM   #3
Heedlessone
Member#: 254130
1993 LS1 RX7
Subaru charges $45 to reset the TPMS light. Is it worth $45?
Heedlessone is offline   Reply With Quote
Old 03-24-2013, 02:07 PM   #4
2011WRXMT
Member#: 270426
2011 WRX Premium
Satin Pearl White
This seems like something that would be and or should be covered under warranty if you still have a warranty.
2011WRXMT is offline   Reply With Quote
Old 03-24-2013, 08:40 PM   #5
backseatwindowsup
Member#: 321212
2012 WRX
might be a dumb question but did you change your wheels recently?
backseatwindowsup is offline   Reply With Quote
Old 03-24-2013, 09:31 PM   #6
855T
Member#: 246628
2010 Impreza WRX
I did change my wheels, but it was almost two years ago.
Old 03-24-2013, 11:30 PM   #7
emazz104
Member#: 281811
04 WRX
World Rally Blue
Did you check the spare tire?
emazz104 is offline   Reply With Quote
Old 03-25-2013, 12:30 AM   #8
855T
Member#: 246628
2010 Impreza WRX
Does the spare even have a TPMS sensor? I feel like the last time I used the spare the light stayed on the whole time anyway.
Old 03-25-2013, 05:58 PM   #9
emazz104
Member#: 281811
04 WRX
World Rally Blue
I don't know honestly. I just figured it was something to check, I thought most cars had them.
Old 03-24-2013, 11:30 PM   #10
doellski
Member#: 282837
Same thing happened to me, dealer found one of the tpms went bad. Covered under warranty.
doellski is offline   Reply With Quote
Old 03-26-2013, 04:24 PM   #11
855T
Member#: 246628
2010 Impreza WRX
Weirdly enough, washing the car fixed it. A clean car never breaks, I guess.
Old 03-26-2013, 05:32 PM   #12
roadboy
Member#: 329556
Tpms sensor light can come on if tires are a a couple psi difference within each other, also can come on if its defective.
roadboy is offline   Reply With Quote
Old 03-26-2013, 06:54 PM   #13
BeefCurtains64
Member#: 251257
12 WRX
Spare does not come with tpms.
BeefCurtains64 is offline   Reply With Quote
Old 03-26-2013, 07:05 PM   #14
shaggie
Member#: 36022
2000 08 OBS
Silverthorn Metallic
How long was it between drives? The light won't go off unless you drive the car for a bit. The sensor needs to pass the pickup a few times. If the light was on and the car never moved but you adjusted the pressure, the light would stay on. From your post it doesn't sound like you've driven very much.
shaggie is offline   Reply With Quote
Old 03-26-2013, 10:50 PM   #15
Ian G.
Member#: 303086
2008 Subaru WRX
Dark Grey
If the TPMS telltale light is flashing when you first start the car, you have a dead sensor. When its cold, pressures drop a little more easily so just check the pressure more often. If the pressure is approx 15% lower than spec the light will illuminate. Adjust to 33 psi and after driving for about three mins or less the light will clear out if it was just a pressure issue. I would never pay a shop 45 for a sensor scan. It's literally a two min job at most and free at a lot of tire shops (don't go to the dealer for tire issues). The sensor itself runs about 35-40 dollars at the last shop I worked at with a 14 dollar install. The sensors have to be relearned with the linked ID numbers (TPMS relearn scanner does it in no time)
Ian G. is offline   Reply With Quote
