Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 03-31-2013, 12:28 PM   #1
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Rotated BW S200sx-56
Default Power limits of Spearco TMIC?
Anyone have experience pushing the Spearco TMIC upwards of 400whp? Trying to figure out if this is what is holding me back from making the 400 club, lol. The chart below is on a mustang dyno, SeaTac area in Wa ~65deg F. Fuel is E85.
2007 2.5i swapped 07 STi EJ257, drivetrane, suspension.
New 09+ EJ257 bored 99.75 CP pistons / rings. ACL race bearings
New heads / new oem cams ARP head studs, Gates timing set
Spearco TMIC
Omni 4 Bar Map sensor
Cobb XLE BPV
Grimmspeed ECBS
FP Green 8CM hotside / 3" inlet
AMR inlet
Cobb Aftamaf tube
APS 70mm intake
TGV's deleted
3mm phenolic spacers
Kartboy main pulley
secondary injection air pump delted
bellmouth DP
Grimmspeed 38mm EWG Up Pipe with Tial wastegate @ 1 bar springs
Maddad UEL header
Maddad whisper exhaust
DW1300cc injectors (new)
Walbro 400 stock location fuel pump
Competition clutch stage 3
DerekB707 is offline   Reply With Quote
Old 04-04-2013, 04:19 AM   #2
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
could just be the dyno. or the timing or AFR. its pretty hard to tell what the AFR is from that plot.
also, im running a gtx35 on a spearcon tmic
Old 04-04-2013, 07:11 AM   #3
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
It's not the Spearco. There are at least 2 tuner builds on this site with a GT35 and a Spearco TMIC running 500-550whp. My own car with a rotated GT3076 and the Spearco made 424whp on 100oct (391whp on 93).
Old 04-04-2013, 08:39 AM   #4
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
I want to say that you are running quite rich(under spool up). But that point is pretty moot as you wouldnt get much more power out of leaning it out a bit. It may bring up spool up however which translates to more tq.
Like Phatron said the plot leaves some questions. Boost control looks good but without a better fuel curve and knowing the timing curve all we can do is speculate. Was this done on a mustang heartbreaker? Because that could be it right there if you are on a very low reading dyno.
endrswrd is offline   Reply With Quote
Old 04-04-2013, 09:02 PM   #5
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
At this point, I am starting to question the maddad whisper exhaust. I believe it tapers to 2.5" at the tail pipe even though it is 3" everywhere else. Would this rob that much power? The tuner told me that it really didn't pick up that much power going from 22psi to 24psi boost. He said he felt that the car had a restriction somewhere.
From what I hear, PIA has a stingy Mustang dyno, but I really thought I would have had enough here to put down 400whp.
The local track opens for test and tune April 13th, I'm planning on going and running a couple passes to get my trap speeds.
Thanks for your replies, I appreciate the input.
Old 04-07-2013, 01:18 PM   #6
1QUIKV6
Member#: 9427
2006 WRX STi
Did they work the timing yet? Could be just an ultra safe tune with the timing pulled way back.
1QUIKV6 is offline   Reply With Quote
Old 04-09-2013, 09:52 AM   #7
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Its not a timing issue.
Old 04-09-2013, 10:57 AM   #8
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
I dont see the exhaust being the choking point, particularly if its way back at the muffler can. On e85 you should be far more HP then me if we were on the same dyno?!? I was on a Dynapack near sea level at 85+ degrees
I have a similar setup with the older non HTA Green 850cc FMIC and at 20psi im at 391hp on 93oct.
Only thing I can think of is to check the gaskets on the TGV to spacers. I have seen them stick near an 1/8" into the air flow path, just because they are too wide. Also check the transitions from Manifold to TGV to Spacer to Heads....the smoother the transition the better.
Next time your on the Dyno take a laser temp sensor and shoot the TMIC and see what the core is at during the pulls. If its ridiculously hot that will not help either.
dangerousatom is offline   Reply With Quote
Old 04-09-2013, 11:32 PM   #9
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Thanks for the input, I'll look at the gaskets next time I tear it apart. The intercooler was cool to the touch, I checked it after every pull, had 3 large automotive fans blowing on the engine compartment. The tuner expected to see 375whp on 92, and 435whp on E85. I made 345whp @ 19 psi on 92, and 382whp on E85. It is a mustang dyno, so expected slighty lower numbers. When I only got 382 on E85, I was really wondering whats wrong. He said he felt like we hit some sort of threashold, it really didn't make any more power from 22psi to 24psi on E85. He questioned my spearco, but I know that intercooler can handle it. I can see the pressure increase on the map sensor to 24psi, just seemed like the car couldn't move the air out or something. I had a buddy put down 410whp on EQ Tunings dynapack using a maddad whisper, not sure how accurate those dynos are. He says its calibrated to read like a mustang though.
