Old 04-01-2013, 12:57 PM   #1
six3jag
Member#: 81540
02 WRX
Default Engine bouce or drivetrain slack
Its been a while since i've posted but i am in need of some opinions on a problem with my aging 2002 wrx. I noticed on a high way trip that while in first gear in traffic i could no longer control the engine bounce that comes from lightly increasing the throttle at low rpms. I also notice that after engine breaking in 5th gear for a while when i come back on to the throttle a bit harder i get the same engine jerk or bounce. I have been driving this car for a long time and have never experienced this in 5th gear. I also have a bit harder of a time coming off the clutch in first now. I mean even though i have been driving this car for 9 years i have started stalling it occasionally.
My thoughts were that this is a problem with the motor mounts or transmission mount, and that my engine was winding up like a spring and then when it hits its limits of travel it suddenly unloads the stored energy into the drive train. I have never really seen this problem with anyone else on the forum though.
Is there a good test for the engine mounts?
Does anyone have any other ideas as to the cause of something like this?
Thanks.
six3jag is offline   Reply With Quote
Old 04-01-2013, 09:22 PM   #2
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
Pop the hood and rev the engine. If it moves a lot more then normal its probably time for new mounts
04wrxhart is offline   Reply With Quote
Old 04-02-2013, 10:04 AM   #3
Member#: 301037
2004 Forester XT
How many miles are on the car?
art@grimmspeed is offline   Reply With Quote
Old 04-02-2013, 10:34 AM   #4
six3jag
Member#: 81540
02 WRX
there's about to be 100k on the car. I revved the engine while looking at it for excessive play. There doesnt seem to be too much movement. I would guess it rises or falls 1 inch on each side as it revs. Could be worse with a load on it.
I did notice though that it had some really bad throttle response. I don't recall specificly how quick it responded to the throttle before but if you pull the throttle quick to about a quarter or more it waits maybe half a second or so before responding. Seems like this is too slow.
I also noticed today while driving that the bounce can be brought on without a change in the power transmission direction. That is, even while continuing to accelerate if i suddenly push the throttle harder i get a hard snap to the car, and it kinda bounces like you would get in 1st gear. It does this in all gears. I am not sure where the engine gets enough torque to do this while in high gears. Seems like something is making it feel like it has a lot more torque than it should.
Old 04-02-2013, 10:59 AM   #5
Whoa!ShutItDown
Member#: 191700
04 WRX
I used to get a nasty bucking, I couldn't tell which mounts were causing it. It was most prominent getting into 2nd, but still there in 1st and 3rd. I did group n motor mounts and that helped quite a bit. Next was a group n trans mount which was another noticable improvement, also made shifting a little nicer. I just did rear diff mount bushings last week and that seemed to help a little too. Idk which one I'd recommend doing first
Whoa!ShutItDown is offline   Reply With Quote
Old 04-02-2013, 09:25 PM   #6
Andrewxxcarlson
Member#: 316415
2006 WRX
Check your pitch mount, gettin to the mileage to start replacing mounts.
Andrewxxcarlson is offline   Reply With Quote
Old 10-05-2013, 12:40 PM   #7
02-wrxbugeye
Member#: 316420
2007 WRX Wagon
I am having the same problem with my 02 that's also nearing 100k miles. Hopefully it's just worn mounts.
02-wrxbugeye is offline   Reply With Quote
