Notices
Old 04-01-2013, 04:03 PM   #1
dlysiak2
Member#: 310866
2015 Legacy;)
Silvaaah
Default Car ran out of gas now wont start?!?!? HELP
gggggg
dlysiak2 is offline   Reply With Quote
Old 04-02-2013, 09:59 PM   #2
Franko
Member#: 193628
2010 STI
SSM
WHY ARE WE YELLING?!
j/k... Hook the laptop up to it and monitor what is going on during cranking. See if you are reading rpm and injector duty cycle.
Can you smell fuel while trying to start?
Franko is offline   Reply With Quote
Old 04-03-2013, 08:22 AM   #3
quazimoto
Member#: 70395
You will have to let it prime at least 5-6 times.
Old 04-03-2013, 12:53 PM   #4
mikeydrives1
Member#: 262117
Dont try so many times (in a panic) in one sitting, you may be flooding the motor. Give it 15-20 mins between cranking attempts if you suspect that, letting the gas evaporate.
If you wanted to, (not reccomending, but it would prove flow) , disconnect the line coming off the fuel filter, having a friend hold a towel over it, and prime the car, seeing if it getting fuel at that point and nothing is clogged
Typically, mechanics/techs will tell you to never run the cars tank too low, being that solids can settle at the bottom of the gas tank over time. Now, one would be quick to say that there is a fuel filter that would stop such things from reaching the motor (both on pump, and in engine bay) , there is, however, these can still get clogged.
mikeydrives1 is offline   Reply With Quote
