Old 04-08-2013, 08:25 AM   #1
wrx_yfz
Member#: 345962
2012 WRX Sedan
Default Stage 2 WRX transmission problems?!
Hey guys i had a question about whats going on with my 2012 stage 2 WRX. it happens when cornering under hard acceleration and also when i punch the gas in first or second lastly It seems when i floor it in either 2nd or 3rd and let off at about 5.5k RPMS, it feels like my transmssion shakes and clunks?! i can feel the tranny or motor like clunk back and forth. its only 1 or 2 big clunks and it makes you cringe because it sounds awful haha. does this mean my transmission or motor cant hold the power of my stage 2? thoughts and suggestions would be awesome guys thank you!
wrx_yfz is offline   Reply With Quote
Old 04-08-2013, 09:03 AM   #2
Tripintaz
Member#: 245218
2013 STI Limited
Are you pushing the clutch in when you let off that gas at that RPM? If not then DERP.
Old 04-08-2013, 10:47 AM   #3
wrx_yfz
Member#: 345962
2012 WRX Sedan
I don't touch the clutch unless I'm shifting and if I'm shifting then i don't have this problem. It's only when I reach high RPM's and then let off the throttle.
Old 04-08-2013, 11:19 AM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You should inspect the tranny mounts, engine mount nuts.
Old 04-08-2013, 11:52 AM   #5
wrx_yfz
Member#: 345962
2012 WRX Sedan
Sense I do not know what I'm inspecting should I just get this looked at, at a auto shop?
Old 04-08-2013, 01:00 PM   #6
some dude
Member#: 100300
06 WRX
CGM
I asked a similar question. My engine bucks hard if I let off the gas near redline, especially if its a partial let off. One big buck. I was told pitch stop. Upgrade that and maybe the stuff happen g to you will reduce or disappear.
some dude is offline   Reply With Quote
Old 04-08-2013, 01:20 PM   #7
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Stock engine mounts. Upgrade them and you will have little if any bucking. It makes a huge difference, believe me.
Old 04-08-2013, 01:35 PM   #8
wrx_yfz
Member#: 345962
2012 WRX Sedan
Whats pitch stop? And Dave d did you have this similar problem or something?
Old 04-08-2013, 01:46 PM   #9
RoadKillDMD
Member#: 284792
2011 STI
Blurple
http://bit.ly/Z3UaOl
RoadKillDMD is offline   Reply With Quote
Old 04-08-2013, 03:22 PM   #10
wrx_yfz
Member#: 345962
2012 WRX Sedan
is this a serious issue? are my motor mounts likely to break or can i ignore this?
Old 04-08-2013, 04:21 PM   #11
some dude
Member#: 100300
06 WRX
CGM
Its probably only serious if they break and you don't replace them. Probably not very serious to break one, just don't make a habit of it or anything. Look under your intercooler. There should be a brace there connected to the firewall. That is the pitch stop.
Old 04-08-2013, 08:33 PM   #12
wrx_yfz
Member#: 345962
2012 WRX Sedan
alright cool i appreciate the help ill look into getting a new pitch stop/tranny/motor mounts!
Old 08-09-2013, 05:03 PM   #13
wrx_yfz
Member#: 345962
2012 WRX Sedan
hey guys im still worried about this clunking noise. I brought it to my local subaru dealership where i bought my car and i had the head mechanic look at my motor and transmission mounts, while i waited there for over 2 hours he came back and said that they were not stressed or in bad condition at all and that they looked fine. Does this mean that those are now out of the question now for being my problem? i want to get this fixed because i cant really do any spirited driving without worrying about the clunking noise.
Old 08-09-2013, 05:06 PM   #14
wrx_yfz
Member#: 345962
2012 WRX Sedan
i will try and explain the problem again in better detail. Its a hard clunk underneath my car i cant tell if its the motor and tranny but its a heavy clunk. the noise can happen almost at any range in the rpms for Ex.) if im in first gear i can punch the throttle for a second to bring the rpms to like 3-4 and let of quickly and it will clunk. going around corners in high RPMs it will clunk, letting off the gas at high rpms to slow down without the break it will clunk as well. just trying to put as much detail as possible. Looking for some help here, i dont want to buy the mounts and have that not fix the problem. thanks guys
Old 08-12-2013, 12:26 AM   #15
EnlightenedOne
Member#: 278744
06 WRX
Like the previous people have said, replace the motor mounts and possibly the pitch stop. I have the same issue except this is on an 06 wrx. Saving up to get those parts. Let us know how everything turned out once you have replaced those parts
EnlightenedOne is offline   Reply With Quote
Old 08-12-2013, 07:32 AM   #16
JonnyV2889
Member#: 197384
2006 WRX Ltd
Mounts won't hurt. I heard a lot of people have issues with rear diff clunk. Is it right under you or behind you?
JonnyV2889 is offline   Reply With Quote
Old 08-28-2013, 03:21 PM   #17
wrx_yfz
Member#: 345962
2012 WRX Sedan
It sounds like its right under me. are people having problems in their newer subies? mines an 12'
Old 08-28-2013, 04:55 PM   #18
dan2510
Member#: 305615
2013 WRX Limited Sdn
Let me know how this works out...I'm thinking about doing the same to my '13 WRX.
dan2510 is offline   Reply With Quote
Old 08-12-2013, 08:54 AM   #19
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Hey guys, I had a question about whats going on with my 2012 stage 2 WRX. It happens when cornering under hard acceleration and also when I punch the gas in first or second.
Lastly, it seems when I floor it in either 2nd or 3rd, and let off at about 5.5k RPMS, it feels like my transmssion shakes and clunks?! I can feel the tranny or motor like clunk back and forth. Its only 1 or 2 big clunks and it makes you cringe because it sounds awful haha.
Does this mean my transmission or motor cant hold the power of my stage 2?
Thoughts and suggestions would be awesome guys thank you!
Problem:
OEM Liquid-filled engine mounts, and a soft-durometer rubber for both the engine mounts and the transmission mount.
Solution:
Replace with Subaru Group-N engine mounts and transmission mount.
Buy parts package from TiC: http://turninconcepts.com/product_in...oducts_id=1083
PS: I'm not 'guessing' on this one, or 'think I know'; I do know.
Old 08-28-2013, 03:20 PM   #20
wrx_yfz
Member#: 345962
2012 WRX Sedan
Update: Bought a STI Group N Transmission mount and a Kartboy pitchstop ill update you guys to see if those have stopped the problem after i install them.
Old 09-06-2013, 09:37 PM   #21
wrx_yfz
Member#: 345962
2012 WRX Sedan
Update:
i installed a new Transmission mount/ pitchstop/ shifter bushings and all the clunking has gone away and the car is so much more responsive and quicker and is a lot faster, the only think is that the NVH is very bad. i can hear so many random noises here and there and i dont know if its normal or not.
Old 09-09-2013, 11:02 AM   #22
subezero
Member#: 207614
2008 WRX Hatch VF52d
SSM
Perfectly normal. I doubt the car is any faster, but absolutely more responsive. Enjoy that feeling, you won't be able to stop replacing soft bushings and mounts now!
subezero is offline   Reply With Quote
Old 09-17-2013, 01:00 AM   #23
wadowrx
Member#: 343621
2012 Impreza WRX
Dark Metallic Gray
I have some Group N engine mounts for sale!
But seriously, I upgraded to the Group N transm ount and the Torque Solutions pitch stop mount and 90% of my "bucking" issues are gone.
wadowrx is offline   Reply With Quote
Old 09-17-2013, 08:06 PM   #24
wrx_yfz
Member#: 345962
2012 WRX Sedan
i fixed the NVH problems it was a couple things rubbing like the heatshield.
Old 10-02-2013, 04:27 AM   #25
Nunogolos
Member#: 369855
check clutch
Nunogolos is offline   Reply With Quote
