Old 04-09-2013, 02:55 PM   #1
wlcmetomcyds
Member#: 335555
1993 impreza
Default non wrx suspension question
I am looking into replacing my suspension on my 1993 Subaru impreza L. I found a set of coilover suspension on eBay, it says it is compatible with a 93 impreza wrx. My question is if it will work on my not wrx impreza?
For More info may car has:
rear drum brakes
13 in. Wheels
Non-abs
Front wheel drive
Any feedback would be greatly appreciated!
wlcmetomcyds is offline   Reply With Quote
Old 04-29-2013, 12:16 PM   #2
razerv3c1
Member#: 354933
98 wrx sti
white
just reply to the seller and ask, but if it was me id be iffy about buying off ebay. ive heard its sketch i guess just depends what you buy rly.
razerv3c1 is offline   Reply With Quote
Old 05-14-2013, 06:04 PM   #3
RSTM
Member#: 204463
2007 Impreza 2.5i
Garnet Red Pearl
If you're looking to replace your suspension the best bang for your buck (depending on your intentions) are to purchase 4 new KYB GR2 struts. KYB sells products for ABS/NON-ABS vehicles.
If you're looking to lower your car substantially, coilovers are the way to go; BC, Tein, or Bilstein are all excellent companies.
If you just want the car to sit lower I suggest the Eibach kit or H&R's sport spring package. Eibach will take you down about 1" and the H&R's will take you down to approx. 2". Both are great springs that will certainly upgrade your stock suspension.
Other ways to upgrade your suspension are: new polyurethane bushings, sway bars, and bracing. I'd stay away from eBay for upgrade parts for your suspension. You really shouldn't mess around with these components. Your safety depends on it.
Good luck, PM me if you need any help, also check out RS25. That site has a lot of Impreza's like yours there, with a lot of information as well.
RSTM is offline   Reply With Quote
Old 05-19-2013, 10:51 PM   #4
Paul_impreza95
Member#: 356472
If I buy lowering springs then later plan on getting bigger wheels will I need a camber kit to ?
Paul_impreza95 is offline   Reply With Quote
