Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Old 04-10-2013, 04:45 PM   #1
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
Default The Birth of the Most Powerfull VF Downpipe?
Name that development...
__________________
- Highly Advanced and Full of Awesomeness - Patent Pending
vs.
V2 High Performance Aluminum
Brushed & Polished Delrin Shift knobs!
Old 04-10-2013, 04:49 PM   #2
V3rtigo
Member Sales Rating: (2)
Member#: 262020
2013 STi-Limited
PBP
in for answer
V3rtigo is offline   Reply With Quote
Old 04-10-2013, 04:55 PM   #3
I'mFineW/Slow
Member Sales Rating: (5)
Member#: 260395
2004 Impreza 2.5 RS
Excited even though I don't know what it is.
I'mFineW/Slow is offline   Reply With Quote
Old 04-10-2013, 05:04 PM   #4
Mountain
Member#: 331271
03 WRX
Coolant filler tank thingy prototype?
Mountain is offline   Reply With Quote
Old 04-10-2013, 05:17 PM   #5
T-37
Member Sales Rating: (3)
Member#: 175624
1234 RIGHT IN THE
SYRUP
unfinished divorced wastegate downpipe?
Old 04-10-2013, 06:01 PM   #6
Boston Motorsports
Vendor Sales Rating: (626)
Member#: 214025
+1
__________________
OPEN EARLY | OPEN LATE | OPEN 7 DAYS A WEEK!
Phone: 1.877.6000.BMS | E-Mail:
| Paypal:
WE WANT TO EARN YOUR BUSINESS!!
| WE WILL BEAT ANY ADVERTISED PRICE GUARANTEED!!
Boston Motorsports is offline   Reply With Quote
Old 04-10-2013, 06:32 PM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ Stay tuned on this one
Originally Posted by gmhl10 View Post
external wastegate??
Not quite, but related to EWG
Originally Posted by Boston Motorsports View Post
+1
OK you two are the closest. Honestly, I don't know if it would be considered divorced, separated, or just plain old absent. It's a bit niche, but I think there may be demand?
Essentially, it's a non-gated downpipe. There is no accommodation for any kind of waste gate. It's for those running a VF with an EWG venting to atmosphere. That's neat, but not really the 'special' part. The special part is that it's closely port matched to the VFs turbine outlet. Our 'divider' is unlike any other seen before. It nearly meet the turbine casting and expands as you go further from the turbine. The flange also has this same expanding geometry that matches the divider (as well as other funky geometry to match the housing) and on the other side of the flange, an expansion tube that continues (again all at the same expansion angle) up to 3". So basically you have much smoother less turbulent flow exiting the turbine and gradually expanding up to 3". This emulates the exit of most higher performance turbos. Here is a really crappy shot in the dark with a mirror looking into the DownPipe through the turbine housing. You can see the taper outwards and how closely it matches the turbine wheel's exit.
So cool beans, but how else can we keep it from falling into the 'downpipes are all the same' category. Without a 'bell' there's decent room to plumb straight out of the turbine instead of going downward immediately further reducing turbulence. We're also going to be using massive 8" centerline bends to further reduce turbulence and maximize flow capacity. This is very non-standard (not as cheap) as most popular downpipes use a more turbulent 3" or 4" bend radii.
Will all this trickery amount to anything? We shall see.
As usual, you thoughts, opinions, and comments are welcome.
__________________
vs.
Old 04-10-2013, 05:17 PM   #8
Cre8ive
Member#: 15617
2007 WRX STi OBP
'02 WRX OBP
Tube with a flange. Photo with car wheel centered in pic.
My guess. Brake duct!
Cre8ive is offline   Reply With Quote
Old 04-10-2013, 05:50 PM   #9
gmhl10
Member#: 158695
2013 GVB STi
World Rally Blue
gmhl10 is offline   Reply With Quote
Old 04-10-2013, 07:43 PM   #10
teiva-boy
Member Sales Rating: (16)
Member#: 22825
Off hand, Prodrive used to offer a catted downpipe as part of their power packs. They claimed that with a cat, there was no effect on power output. But still kept it clean...
Their cat was not your normal run of the mill 200cell 3" cat. But more so it was huge like 5"+ in dia. Their downpipe had a really funny shape because of it... I guess logically it sounds valid. Provide enough surface area, and the cell's could do their work without impeding flow?
Do you think you would ever offer something like that? Even as an option? I know in my searching I could never find a cat like that to even have it grafted onto my existing downpipe.
teiva-boy is offline   Reply With Quote
Old 04-10-2013, 09:05 PM   #11
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
If you like the Prodrive unit, you should get one.
We'll offer a catted and catless version. I plan on using the same 4" 100 cell cat I'm using on our low mount kit. It's a decent cat, I would say above the middle of the scale in quality/performance. Of course there are $800+ cats out there too if you're chasing down tenths while keeping Kermit happy.
I won't be offering different cats, but if you wanted to put a different version on there I'm sure it could be done.
__________________
vs.
Old 04-11-2013, 12:50 AM   #12
reid-o
Member#: 103631
2004 STI
I'm guessing that this will be released in tandem with an up pipe variation.
Old 04-11-2013, 06:39 AM   #13
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I don't see why it can't be used with any up-pipe.
__________________
vs.
Old 04-11-2013, 07:58 AM   #14
reid-o
Member#: 103631
2004 STI
I don't see why not either.
Old 04-11-2013, 11:42 AM   #15
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Couple more shots...
The bend that transitions from vertical to horizontal has a 10+" bend radius
__________________
vs.
Old 04-11-2013, 02:37 PM   #16
wantsti
Member Sales Rating: (90)
Member#: 134764
04 sti
java black pearl
Just get some products released. I know it takes time but it seems like you have sooo many prototypes and ideas but nothing ever gets produced.
btw love your products.
wantsti is offline   Reply With Quote
Old 04-11-2013, 03:48 PM   #17
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It all depends on the complexity and level of testing required. Products are researched, marketability is determined. Design, engineering, testing, possibly followed by a second round of the same. Then manufacturing engineering needs to be done; materials costing, fixtures and tooling needs to be designed, packaging requirements, etc. Then on to website and sales stuff, which I avoid like the plague. So something as simple as a shift knob can take a month. A full blown turbo kit, MUCH longer. I will always err on the side of over testing vs bringing something to market that may have compromised reliability/durability
I really wanted a flat plate downpipe with I had a stock location EWG setup. This looks like a really nice version of that. If you're port matching to the VF turbo, would you expect it to be restrictive/turbulent with a larger stock location turbo?
Thanks! I would expect that with a larger than stock turbo, but the nice thing is, it could always be DIY ported bigger. The 'divider' is substantially thick (machined solid Stainless, not a piece of cut tube) so quite a bit could be removed. For most people removing material is a much easier task than adding it
__________________
vs.
Old 04-11-2013, 02:39 PM   #18
xluben
Member Sales Rating: (17)
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Old 04-12-2013, 07:20 AM   #19
5.56x45
Member#: 305538
Will this be 304 or 321 SS? I'm about to swap out my Invidia for a Tomei unit but I'm willing to wait for this if it will be made with 321SS.
5.56x45 is offline   Reply With Quote
Old 04-12-2013, 08:06 AM   #20
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Max temps and the temp differential from end to end is not nearly as high as a set of headers. I see no reason to make a set from 321 unless you wanted to go with a thinner wall to save some weight.
Like all our products it will have a lifetime warranty.
__________________
vs.
Old 04-12-2013, 12:08 PM   #21
5.56x45
Member#: 305538
Nice! What's the estimated release date for this down pipe? And will you have an extra bug on it for those of us that have wideband?
Old 05-06-2013, 06:38 AM   #22
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Too soon to put any dates out there. Yes we will have an extra bung option.
Here's a pic next to the Invidia we will be testing against. Among other things, you can now really see the differences in bend radii.
Just as a refresher, this testing series is targeting those running an EWG VF shooting for maximum power.
__________________
vs.
Old 05-07-2013, 04:06 PM   #23
Concillian
Member Sales Rating: (4)
Member#: 4414
2002 WRX Sedan
Midnight Black
Or the crazy guys (a.k.a restrictor rally guys) who weld the IWG shut and use no boost control at all?
Old 05-28-2013, 03:47 PM   #24
vision.dynamix
Member Sales Rating: (53)
Member#: 139955
2015 Subaru STI
Stage e
Dont really need any boost control when you only flow enough air to build 12-14psi with the wastegate clamped shut.
Old 05-08-2013, 06:04 AM   #25
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Of course. You said it well... crazy
__________________
vs.
