Welcome to the North American Subaru Impreza Owners Club Saturday March 7, 2015
Old 04-22-2013, 11:31 AM   #1
MgMidget72
Member#: 57926
2003 WRX Wagon
Sonic Yellow
Default A/C Leak Found - How to Fix?
I found out yesterday that I have a leak in the a/c system where the discharge pipe attaches to the compressor (part 10 http://www.subarupartsforyou.com/cp_...hp?partid=7314). Whatís involved in fixing this? Is it just a matter of getting the correct o-ring and replacing it, or is there more? Anything else I should do while the systems open? Whereís the best place locally to buy the o-ring. I have a long trip on Thursday and itís supposed to be warm here, so Iím hoping to do this quickly.
Background:
2003 WRX, 145,000 miles
For the past few years, this has just been a slow leak that Iíve been topping up or occasionally pumping the system down with a vacuum pump and doing a full recharge. Even when pumping it down, it held the vacuum after shutting off the pump. Yesterday, it was slowly loosing vacuum, but I thought Iíd try filling it anyway before it sucked in more air. Once I opened the knob on the gauges and the coolant started filling the system, I started to hear a hissing noise and turned off the knobs on the gauges and the bottle. The hiss was coming from the compressor, where the pipe to the condenser attaches.
Thanks,
Scott
MgMidget72 is offline   Reply With Quote
Old 04-22-2013, 03:22 PM   #2
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Just take it to a shop. You still have to pay them to draw a vacuum and fill the system.
Bacon117 is offline   Reply With Quote
Old 04-22-2013, 03:48 PM   #3
MgMidget72
Member#: 57926
2003 WRX Wagon
Sonic Yellow
Really?? For an o-ring??
Because of the leak, the system is empty already. I can draw the vacuum and fill the system myself. I just wanted to make sure that there isn't anything more to it than the o-ring, or if other things should be done at the same time.
Thanks,
Scott
Old 04-22-2013, 10:39 PM   #4
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Thanks,
Scott
As mentioned, most people don't invest in a/c equipment to be able to draw a vacuum. I assumed you would be taking it to a shop for this. Just to be clear, you are not just hooking up an R-134a canister from autozone, right? Please take no offense, I just want to be sure.
Old 04-22-2013, 06:52 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
he mentioned a shop since most people don't have their own A/C equipment. If the system has been empty for a while, you might consider a new...drier. whatever the unit is called to remove moisture from the system.
yarrgh is online now   Reply With Quote
Old 04-23-2013, 08:35 AM   #6
MgMidget72
Member#: 57926
2003 WRX Wagon
Sonic Yellow
Yes, I have the vacuum pump and correct gauge set to draw a vacuum down to what is required. Sorry I wasn't clear about that in my first post. Following the shop manual, what I've done before is draw the vacuum with the pump for 15 minutes, let it sit for a while, and then start charging the high side with the engine off. Once the can is empty or it won't take any more, I shut off the high side and charge through the low side with the engine & a/c running until I get the right amount of 134a into the system.
I was able to find an o-ring set for my car at A-Z yesterday. I got some PAG 100 oil in a bottle also to lube the o-rings.
At this point, I think I'll just replace the o-rings on each side of the compressor discharge pipe. yarrgh - thanks for the suggestion about the dryer, unfortunately I'm running low on time and need this to be a quick job. Anything else I should quickly check though? Should I add more oil to the compressor? The shop manual only says to add oil when replacing components, but I wasn't sure if the oil can get lost through a bad o-ring.
Thanks,
Scott
